Question about Aurora Electronics HC212 Calculator
How do I find margin using my aurora hc212 - Aurora Electronics HC212 Calculator
How to type in Landscape form of paper .
Roll the paper in sideways. Use the Margin Release key to allow you to backspace to the left of your left margin, then touch the Left Margin key to set the margin at the new location. Go to the right margin and use the Margin Release key again to allow you to space past the right margin, then touch the Right Margin key to set the new margin there.
Type.
Aug 18, 2011 | Brother GX-6750 Typewriter
Windows driver
.Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;} .Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;}
The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn aniso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Apr 03, 2010 | Radio Shack VGA PC Camera Webcam
I lost the CD for my VGA PC camera webcam can you help me?
.Normal {margin:0.0pt; margin-top:0.0pt; margin-bottom:0.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Times New Roman"; font-size:10.0pt; color:Black; font-weight:normal; } H1 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:18.0pt; color:Black; font-weight:bold; } H2 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:16.0pt; color:Black; font-weight:bold; } H3 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:14.0pt; color:Black; font-weight:bold; } The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn an iso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Mar 30, 2010 | Radio Shack VGA PC Camera Webcam
How to clear margin when in use
Left margin...use the code key (colored)
Move the carriage to where you want the margin, use margin release if you have to go beyond the present margin, and use the margin set key to set.
You have to reset a margin. can't just clear one.
Can set margins at each end of the typing line, then you will have no margins.
Hope this helps!!!
Dec 16, 2009 | Smith Corona Wordsmith 100 Typewriter
How can i install my gigaware 25-157 cam if i lose the disc
.Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;} The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn aniso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Jul 31, 2009 | Toshiba Installation Software
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
Vga web cam gigaware
Apr 21, 2008 | Radio Shack VGA PC Camera Webcam
Gigaware webcam with mic
Its a plug and play webcam. I think it has got damaged or your operating system contain some virus. Check it out by connecting this web cam to another computer running xp.
Then let me know
cheers
Apr 03, 2008 | Radio Shack VGA PC Camera Webcam
Margin Settings
You must position the carrier to where you want the margin then press the left or right margin set button depending on which one you want to set. Use the margin release button to get past the current margins. You may have to use the code button with the margin button to set the margin. Lawrence
Mar 18, 2008 | Brother EM-630 Typewriter
Lost my manual
http://www.aurora-ltd.co.uk/OpInst/CSM.htm
Jan 07, 2006 | Aurora Electronics HC212 Calculator
Aurora Electronics HC212 Calculator Logo
60 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
