Question about NorStar M7310 Corded Phone
I have a Norstar M7130 phone. The volume for the ear piece has to be reset for every call, whether it's incoming or outgoing. When I pick up the phone I can not hear the caller until I adjust the volume. This just started a week ago. How can I fix this?
  • 31 Answers
SOURCE: Programming a phone to pick up calls
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
Posted on May 23, 2007
SOURCE: nortel norstar m7310 phone caller id problems
did you change extension numbers? Or did your extension number move with you?
Posted on May 08, 2008
SOURCE: Handset problem
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Posted on Nov 20, 2008
cnavarro
  • 2460 Answers
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Posted on Jan 08, 2009
  • 14 Answers
SOURCE: Others can't hear me on the phone
Switch the handset and handset cord with another phone to see if the problem moves.
Posted on Feb 08, 2009
Samsung i577 has no audio on incoming and outgoing calls
ear speaker might be bad; did you try the hands free and still no sound.
Another is plug you ear piece into the jack and see if you have sound; you do then the ear piece speak may need to be replaced.
Jul 18, 2014 | Cell Phones
Norstar m7130
Not to be too obvious, but did you mean Feature*98?
Even then, it should be F*981, or another in that group:
Voicemail Feature Codes Norstar Meridian and Nortel BCM Help Guides
Jun 22, 2014 | Nortel Lands Phones
My Norstar Phone Won't Let Me Pick Up Incoming Calls
Make sure they are Line Buttons, do FEATURE * 0 then press buttons to see what they are/do
Or maybe the key pad inside has failed.
Mar 04, 2013 | NorStar Lands Phones
My iphone 3g does not ring, i can hear the ring if i have on ear phones or an ear piece. the signal seems to be okay. the settings seem to be correct.
Dear Dburnett412.
If you can't hear the ringer when there is an incoming call to your iPhone 3G, you may have overlooked whether or not the ring/silent switch is set to silence the ringer. The ring/silent switch is above the volume switch. If you can see orange on this switch, it's set to vibrate. Switch it to ring and you should be all good.
If this doesn't help, you may want to consider resetting the iPhone.
Jun 30, 2011 | Cell Phones
When I receive an incoming call I have to put them on speaker or I can't hear...same with outgoing calls....
The main reason for this problem is because of the ear piece. The ear piece is something you keep close to your ears while making calls. The speaker is an alternate way to listen music or to listen the caller loud or for ring tone.
Check your ear piece. Either it would have damaged due to water or would have lost the connection to the circuitry.
May 19, 2011 | HTC Cell Phones
Call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
Jan 22, 2009 | NorStar M7310 Phone
Motorola Z3 Blank/White Screen
replaced the flexcable on the phone.
USA - replaced either the flexcable and LCD
Mar 30, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Incoming or outgoing calls no sounds
Turn up the volumes on Ear piece -during- a call (on the side of the phone <===>) and on the speaker at any time. The joy stick does it I think.
Jan 01, 2008 | Samsung SGH-E900 Cellular Phone
Calls problem
Try turning the sound up.
On the side of the phone press <----> during a call to turn the ear piece up/down.
The main button (joystick) turns speaker up/down.
Dec 27, 2007 | Sony Ericsson K610i Cellular Phone
Problem with heaing incoming and outgoing calls unless using speakerphone
I can't hear people that call me unless I put them on speaker phone. Called Motorola and they had me reset the phone but that did nothing. Any other suggestions?
Thanks.
May 30, 2007 | Motorola Mobility RAZR V3
NorStar M7310 Corded Phone Logo
104 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
