Question about Intex Easy Set Pool 15x36
Hole in blue inflatable ring
I need to repair a 2 inch long **** in the blue ring and no matter what I do I cannot get it to seal right. What kind of patch do I need?????
  • 718 Answers
Check with your local pool center/supply center or maybe,The Great Escape if you have one in your area they will have techs to help.
Posted on Jun 04, 2010
What is the cheapest fishing kayak?
What Does Really Matter:
Stability
Speed
Durability
Maneuverability
Storage/Gear
Best Fishing Kayaks Under $400
Sun Dolphin Aruba SS Kayak
The spray deflectors allow you to take the kayak into fast river and lakes without running the risk that you get with an inflatable kayak. The large cockpit and adjustable foot braces allow for comfort and flexibility to get the most power from your paddle.
A large, comfortable seating part with protective thigh pads. Other facilities involve a P.A.C. (Portable Accessory Carrier) that can be used as a tow behind the storage; a hands-free electronic support; shock cord deck rigging and water bottle holder.
Sun Dolphin Aruba SS Kayak review help you what you need in a fishing kayak, and make a well-informed decision when buying.
  • Brand: Sun Dolphin
  • Overall Length: 10-feet (3.05m)
  • Overall Width: 2-feet 6-inch (76cm)
  • Product Dimensions: 11 x 30 x 120-inches
  • Item Weight: 40 lb.
Best Fishing Kayaks Under $300
Sevylor Fiji 2 person Inflatable kayak is an amazing watercraft that is perfect for beginners who want to learn the sport. Our Sevylor Fiji 2 Person Inflatable Kayak review will tell you what you can find in this best inflatable kayak for beginners. The Sevylor Fiji ships with a five-piece touring paddle and a travel bag.
This Sevylor Inflatable kayak is very lightweight and easily deflates to fit into the carrying bag for easy transport. So, it will be great if you take the Fiji with you during hiking and biking time, or on camping trips. However, this boat is designed for Class I and II water, and it is suitable for ocean surf and flat-water lakes.
  • Brand: Sevylor
  • Model: Fiji 2-person
  • Type: 2-person Inflatable Kayak
  • Size: 10 feet 4 inches
  • Dimension: 34.8 x 35.5 x 124.8 inches
  • Use: Recreational, Fishing (Lakes, Bays, Water bodies...)
  • Material: 22-gauge PVC construction
  • Weight: 23.8 lbs.
  • Weight Limit: 400 lbs.
  • Number of Chambers: Multiple air chambers
Apr 11, 2018 | Boating
Hi, on my JB5538 Wristech, even with brand new batteries, the unit never seems to inflate ! It developed this problem about 3 months ago out of the blue. Keep getting Err message. How do I fix it ? Th
either the compressor unit seals are damaged or you have a hole in the inflatable section either way it is not an easy fix and as they have come down in price dramatically over the past year i would suggest buying a new model & chucking this one away
Nov 12, 2014 | Health & Beauty
1985 Honda CBX 750 F gas and oil coming out the tail pipe
Hi, Anonymous and the usual suspects are:
1. Engine oil system overfilled.
2. Piston rings worn past service specs.
3. Broken piston rings.
4. Piston pin retaining clip failure.
5. Cracked piston.
6. Broken piston ring lands.
7. Hole in the piston.
8. Valve/guide clearance worn past service specs.
9. Worn out valve seals.
10. Crushed or loose valve seal.
11. Gouges in cylinder walls.
12. Cracked cylinder or head.
13. Blown head gasket.
14. Crankcase breather blocked or hose pinched.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda CBX 750 HEELP
How to identify and repair leaks on your motorcycle
Honda 1985 CBX750F Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBX750P Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 14, 2014 | 1985 Honda CBX 750 F
2004 Kawasaki KX 125 leaking oil from the muffler
5. Cracked piston.
Kx 125 Oil coming out of exhaust ALOT
Oil Dripping THICK from muffler exhaust connection
https://www.howtomotorcyclerepair.com/images/Kawasaki-KX125-KX250-Service-Manual-Repair-1999-2000-2001-2002-99924-1244-04.pdf
OEM Parts for Kawasaki
2004 Kawasaki KX125 Owner Manual
Aug 14, 2013 | 2004 kawasaki KX 125
When using the vinyl patch kit to repair a hole in the inflatable ring, should the ring be inflated or defalted to achieve the best results? Also, if you are repairing for the 2nd or 3rd time- is there...
Repair deflated to prevent air bubbles and it will leak... I've used 3M adhesive remover.. Comes in small 6 oz can.. Home Depot. and when repairing, use a clamp similar to this style in the picture I attached.. Let dry for several hrs... Hope this works for you!! If it helps please rate!!!
Jul 21, 2011 | Intex Easy Set Pool 15x36
I noticed my pool was leaking air. I opened the upper ring blow up valve and there is hole inside of it. Can this be repaired? I would hate to get rid of my pool just because the air valve has a hole...
Take a 12 X 12 piece of plastic wrap, wet the pool ring, slide the plastic sheet along until you see the air bubble appear, mark leak with marker pen. Use repair patch. I swear this is better than soapy water!
Jun 19, 2010 | Intex Easy Set Pool 15x36
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
May 20, 2010 | Intex Easy Set Pool 15x36
I have a 15 inch legacy sharp steel 4000w subwoofer. how much air space does the enclosure need to have? and does it matter if it's sealed or ported?
about 1.5 cubic feet for a sealed box and it does matter if its ported.. if you port it you need to find the right size port hole and length to suit the box and suit it to the most common music type you listen to..
Feb 25, 2010 | Car Audio & Video
Have 2 12 inch kicker cvrs the foam or rubber outside ring has a whole how do i fix itcan i buy the whole rubber ring?
you cant buy just the ring. you have to recone the woofer. you may be able to try some home remedys for repair but if the woofers are in a sealed box they are under tremendous pressure and glue may not hold. how large is the hole?
Feb 13, 2010 | Kicker CVR12 Car Subwoofer
Intex Easy Set Pool 15x36 Logo
499 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
