Question about Sceptre 17" LCD Monitor
X7 G-NAGA VI POWER SUPPLY Transistors
The problem in a Sceptre X7G-NAGA VI is the transistors STU 2030 PLS and STU 3030 NLS, but I don´t find the original. Where can I get a similar?
Do an advanced search on ebay for seller techtronsaver he should be able to supply you with the parts you need
Posted on Jun 06, 2010
Testimonial: "I will search ebay, and maybe that´s the best way to find that components,Thank you!"
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Sceptre Monitor P/N X7G-Komodo II displays for about 1 second at a time, then goes black. When I cycle monitor power, I see a perfect display for 1 second. Does anyone have a recommended solution?
When the backlight does not stay on for more than a second, the problem is usually the backlight power supply board failure. Typical failures are blown capacitors, or transistors. A electronic repair shop should be able to fix it.
Oct 05, 2010 | Sceptre X7G Komodo II 17 in. Flat Panel...
At start-up, Sceptre X7 monitor flashes on, then goes black. Must turn computer on and off numerous time before monitor will stay on. How can this be fixed?
Hi Friend,
You need to check your display setting in your computer..i mean to say..you need to click on desktop then properties then display then screen saver then change the time.....
Dec 20, 2009 | Sceptre X7G-Naga 17" LCD Monitor
Spectre x7, at startup, screen blinks on and off. blue light at bottom also goes on and off
leos343872, Black screen type of failure. Is anything still displayed even though screen is black when you hold flashlight 1 inch from lower left corner near start button??? Possible "switch-mode-power-supply" in shutdown mode. Tech or you will need to evaluate further!! Read more of my advice to other owners with BLACK screen monitor problems in my profile. or louie12fix profile. 12fixlouie
Dec 14, 2009 | Sceptre X7G-Naga 17" LCD Monitor
Sceptre X7G Naga VI dissaembly.
I have a bad power supply in mine as well. trick to opening it was popping off the silver caps on the base to remove the base. then using 2 bladed screwdrivers carefully pry the front plastic bezel off the back. there is no glue just locking tabs.
Dec 04, 2009 | Sceptre 17" LCD Monitor
Sceptre X7G-Naga VI
My problem sounds equivelant: The problem is that it will power down after 15 minutes, then take 1/2 hour or more to power back up!I believe I have solved my problem with my X7G! I remember seeing a direction on the only direction papaer I got with it that told me to Turn off ALL POWER SAVING WINDOWS SETTINGS! I think the monitor is set to care for all the monitor/power saving itself. I am going to try it and will get back to you, or just try it yourselfs!
CWD
Dec 22, 2008 | Sceptre 17" LCD Monitor
Sceptre monitor x7g-nagaVI
Problem is 2 Capacitors on the power inverter board, at 1000 uf 16 volt. This one was on the model xg7-naga V 17 inch monitor.
Jan 14, 2008 | Sceptre 17" LCD Monitor
Monitor turned black
Check some of the other posts as it is probably just a bad capacitor or two and very easy to fix if you can do that sort of thing. I did and mine is back up and running.
Nov 03, 2007 | Sceptre 17" LCD Monitor
Replacing Sceptre Power supply
The attached pictures are the back of our TV which is a Sceptre X30SV NAGA III. In ours the power supply is inside the vertical panel on the back right of the TV. The plug goes in the bottom of the panel and you remove the panel with the horizontal louvers with 4 screws to get at the power supply. A replacement power supply is from Delta Electronics part number ADP 180CB B , 24 Volts 7.5 amps 180 Watts that we reordered from here:
http://cgi.ebay.com/Delta-ADP-180CB-B-24V-7-5A-180W-4-Pin-Din_W0QQitemZ160268090373QQcmdZViewItem
Aug 23, 2007 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre 17" Naga monitor
try another monitor on your pc. I suspect bad video source.
Jun 09, 2007 | Sceptre X7G-Naga 17" LCD Monitor
Sceptre 17" LCD Monitor Logo
381 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
