Question about HP PSC 1210 All-In-One InkJet Printer
The paper won't feed through the printer- anything I can do for that?
    Master:
  • 149 Answers
Clean & inspect: Unload the paper stock. Turn printer off & unplug its power cord. Open the rear access door by pressing the tab on its left edge towards the right as you swing the door out. Remove & discard any jammed &/or crumpled objects. Clean, turn, & inspect the rollers with a soft towel that has been lightly moistened with water. Rollers that do not turn freely could require replacement.
Prepare printer for use: Restack & reload the paper stock into the paper supply tray, but do not continue to push the paper in after some resistance is felt. Reattach the rear access door by lining up the two pins on right side with their respective holes (near the ports for power & USB connections) & swing the door back into place—pressing gently but firmly until it locks into place. Reconnect the power cord & turn the printer on.
Posted on Jun 04, 2010
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Paper goes in crooked and won't go down into the printer to print. This is a Cannon bjc-2100.
In most cases there is an obstruction in the paper path causing this. Sometimes by lifting the printer upside down and shaking it can remove the obstruction. If this does,nt work get a torch and look down into the paper path and see if you can see anything foreign.
I have also dislodged the objet by using a A4 cardboard ( folio ) and feeding it back in from the inside of the printer to where the paper usually sits.
I have found hundreds of varied objects that have dropped into printers.
Jul 17, 2011 | Office Equipment & Supplies
The printer won't feed the paper in properly. It turns crooked and then doesn't load in. Printer thinks there is either no paper or a jam. Can see anything physically in the way blocking the...
Hi Trevo
First, check the the paper guide in the feed tray is up against the edge of the paper. If it is not snug then the paper will skew.
If it is OK then check with a torch both sides of the paper path - where it goes in and where it comes out.
I've found bits in the path before now that are not seen at first.
This printer may have a removeable panel at the back where you can check a bit more easily.
May 25, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
Paper feed problem
Just open up the printer lid, don't be afraid, you won't break anything. Usually inkjet printers have a panel on the back aswell which you can open by twisting a big knob. It's there especially for unjamming paper. Also, make sure the paper in the tray is arranged in a neat stack and the things that keep the paper in place are tightly placed against the paper.
May 03, 2011 | Office Equipment & Supplies
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
Paper feed rolls is rolling over the paper...how to get access to those rolls
  1. Feed the paper manually into the printer:
    1. Place a sheet of plain A4 paper in the paper feed tray.
    2. Move the paper support on the left-hand side to the left end of the paper.
    3. Press the paper feed button.
    4. If the paper does not feed, continue with step 2.
  2. Check for any obstructions in the paper feed path:
    1. Disconnect the cables from the back of the printer.
    2. Open the front of the printer and check for anything that may be blocking the paper path.
    3. Close the front lid and remove any paper from the paper feed tray.
    4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
You can clean with special cleaning paper which ca be used clean the rollers............
Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x3350
Nov 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
135 people viewed this question
Seeker5211
Seeker5211
