Question about ICOM Informatique IC-F121 VHF 136-174MHz mobile 128Ch 50W Microphone
When using the OPC617 external cable, what solder pads need jumpered for PTT and mic audio?
    Problem Solver:
  • 5 Answers
To use OPC-617 option cable:1- open your CS-F100 Rev 1.7, read your radio.2- click on Common >> Expert >>EPTT/FTSW change to EPTT, 3- On the main board , look into the left side of the board you see pad D, solder ittogether, if you use pad F, you shou.ld put a 47K ohm resistor.You can follow this link for your pin out connection.http://www.two-way-radio-tools.com/icom-mc1700-mdc.html
and download ver sion Rev 1.7 from herehttp://www.two-way-radio-tools.com/icom-softwares.html
HP
Posted on Jan 30, 2012
3 Suggested Answers
  • 417 Answers
SOURCE: Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Posted on Apr 15, 2010
SOURCE: i have samsung sgh-d600 mic pads destroy. whre i jumper it
I have samsung sgh-d600 mic pads destroy. whre i jumper it
Posted on Jun 08, 2010
Heil icm plug wiring diagram
The Heil "ICM" microphone is designed to be used with certain Icom brand ham radios. These have a 8-pin round plug. Describing the pinout to you will depend upon your perspective, whether you are looking at it from the microphone plug itself, or the microphone socket on the front of the radio. Therefore, from the perspective of looking at the mic plug on the end of the mic cable, note that there is a notch or dimple in the plug that also lines up with the screw. Going clockwise from the notch, the pins are numbered 1 thru 7. Pin #8 is the center pin.
Pin 1 = mic input
Pin 5 = Push-to-talk (PTT)
Pin 6 = PTT ground
Pin 7= Mic ground
From the standpoint of an Icom transceiver, the remainder of the mic connector pins are as follows:
pin 2 = +8 volts DC (output from the radio)
pin 3 = frequency control up/down
pin 4 = squelch switch
pin 8 = audio output (level varies w/vol control)
Hope this helps
Jan 03, 2014 | Heil Sound Audio Players & Recorders
China mic
I wish you provided more information to explain your mic problem. A mic may not be working because of any of the following:
1. cables (inside the mic housing or through out the cable length from the housing to the connector at the end) are not properly connected, either due to bad soldering or cable qualities.
2. problems on the mic switch: electronically (shorted internal components) or mecanically (loose "push to talk" rod or rod is too short so pressing the outter ptt bar does not activate anything).
Hope it helps. Goodluck, es
Jun 09, 2013 | Radio Communications
The short is by the speaker wires it will transmit but the break is in the rec side of the ant
Since you said that the problem only occurs during the receive mode then there is no problem in the antenna,cause if you have a problem in the antenna,you wont receive or transmitt and it will eventually burn your output transistor.So try checking your mic cable first.Since the cable has most of stress in use due to constant movement,so do a continuity check on the cable.Open the mic handle housing and do a point to point continuity check from the connections in the mic switch to the mic plug (of the mic cord).Next check the PTT switch.If the cable has an open connection,do some soldering work to reconnect the open wire.If the PTT is not working-replace with the same part.
Feb 02, 2011 | Galaxy Radios DX-929 40-Channels Base CB...
Nokia 6020 Earpiece jumper seting
i don't know why you need make it jumper to earpieces, if you one of PTT user likes Malaysian people, it's so simple, open your box of your hand free, directly solder 1 wire from negative lead of Mic and shot to negative lead of earphone.
Vote me if this instruction solve your problem. :p
Jun 11, 2010 | Nokia Handsfree For 6020, 6101, 6102...
Cobra 18 wx st receives-wont transmit
Take the cover off, flip it over solder side up, check all solder joints for cracks, cold solder joints, check the safety diode where it comes in the radio, before I go further, can you pick up the weather channel?...Does the PA work?...need to check the pre-driver and finals,audio chip, hook up the power meter using a coax three foot jumper from the output from radio to the input of the watt meter, then the antenna, first check the SWR, on the scale on the meter to cal/swr mode,adjust it to spec, then while still keyed down turn the dial to SWR,if it is the safe range your ok,then turn the Dial to 10 or 20 watt scale and key the mic. Does it have any wattage? If not suspect the finals, they are located on the back rail, if it does have RF then its the audio chip, its located on the right side rail facing you,closest to you.remove it and replace it with same ....hope this helps....
May 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Heil microphone gm series wiring diagram to suit kenwood ts 450
This is the pinning of the GM-series.
pin 1- Ground / shield
pin 2 - Mic (audio)
pin3/4 - PTT
On the 450 the next;
pin 1 - Mic (Audio)
pin 2 - PTT
pin 7- Ground (Audio)
pin 8- Ground (PTT)
Good luck,
Gerard
Jan 21, 2010 | Heil Sound PR-40 Professional Microphone
Transmit button on the lapel mic will not key the radio
Two things which come to mind, one would be if the PTT on the remote mic is bad/defective, second would be you are plugging the audio device in with the radio turned on.
If your remote mic is failing, the PTT is a repairable item, as is the cord on most models.
Mar 30, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
ICOM IC-A6 Feedback type interference
The problem is caused by the microphone preamp in the headset demodulating the AM transmission. Sordin MSA headsets also have the same problem. What you require is a headset with no electronics in it and a dynamic microphone.
Mar 16, 2009 | Radio Communications
I dont know what kind of radio i have
Hi and welcome to FixYa,
Initially, a CES- 600L is a DTMF encoder microphone with lighted keyboard. For your need:
  • almost always, the simplest requirement would be a 600 ohm mic and a PTT switch;
  • minimum of 3 wires are needed for a 2-way radio microphone to work;
  • 1-mic audio;
  • 2-PTT switch (must go to ground when PTT pressed to TX);
  • 3-common/GND;
  • in some, 4-RX audio (not needed if radio receives with no mic).
Having said the above, then any replacement microphone with appropriate microphone plug/jack could be wired to match the GE. A generic example is shown below.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 07, 2009 | GE Radio Communications
Ear bud/ptt, not working
Two things to check for:
1) The radio is shut off when you plug the earpiece into the radio.
2) Your VOX feature is shut off, or set to zero. (The XTN radio will sense an audio device is plugged into the jack and sometimes cause problems such as you are having.)
Lastly, be certain the accessory is designed to be used with the XTN style radio.
Nov 21, 2008 | Motorola XTN and Spirit Pro Replacement...
509 people viewed this question
Top ICOM Informatique Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an ICOM Informatique Audio Player and Recorder Expert? Answer questions, earn points and help others
