Question about Dometic Rooftop RV Air Conditioner
A/c hums when you turn on. a/c ran before then when shut off all it does is hum
Two things to check. One: look for the start capacitor and make sure it is not blown out the top or black and burnt. There is an anticipatory on top of the capacitor also that could have burnt out.
Then make sure nothing on the out side stuck the fan blade in place and not let it turn. That is really three things, But the charge is never the problem on Roof top air for RV's. Small amount in the system leaks out fast if line bad. AC unit has no taps because it is a closed system not designed to recharge. That doesn't you can't charge the system, it just means someone telling you to tape the line just to test pressure is not really going to fix the problem. Air flow and cleanness of unit on evaporator and condenser is important. You can hear the compressor running if is working. If fan not turning check for being stuck.
Posted on Jun 06, 2010
2 Suggested Answers
  • 51 Answers
SOURCE: duo-therm mod # 57915 not cooling fan?????
need to get at the capacitor for the fan. Try spinning blower when it hums. If it runs then the cap is bad if not the motor.
Posted on Aug 14, 2009
My 2001 chevy malibu had been working fine up until this afternoon it turns but wont start,itmakes ahumming noise even when i turnoff key.
That humming noise may be your fuel pump burning out. Try turning the key to the on position while someone else listens near the gas tank. The humming should only hum for a few seconds so you won't have time to listen yourself unless you can hear it from inside. If the hum continues and doesnt shut off, it is likely a bad fuel pump. It is normal to hear a small hum for a couple of seconds , but when it starts getting weak, it will hum louder, longer, or not at all
May 11, 2015 | 2001 Chevrolet Malibu
My water pump is only humming not working
the humming means the power is getting to it, but for some reason it is not spinning, if it ran dry too long the impeller may have melted.
Dec 26, 2014 | Goulds Pumps Pump Centrifugal 1/2hp
I have a Goodman a/c unit. Fan stopped shut off
replace the motor the bearing has seized up.
Aug 27, 2014 | Heating & Cooling
Motor hums but blade will not rotate
Sounds like a start capacitor.
Feb 19, 2012 | Saws
Something is draining the battery in my Trailblazer
The hum could be your fuel pump. Listen to see if the pump is shutting off. Sometimes they'll run for a little bit after the car is off. If it isn't stopping, then it may be a fuel pump related issue.
Nov 30, 2009 | Computers & Internet
Duo-therm mod # 57915 not cooling fan?????
Aug 13, 2009 | Dometic Rooftop RV Air Conditioner
Autoleveling system in '89 Town Car is hissing and humming. Is there a fuse shut off or manual way to set this? Never tow with car, never will, and will never have heavy loads...ran battery down, is...
the hiss is probably an air leak in the system and humming is the compressor...if you shut it off the car will probably lower to the ground and be undrivable
Jun 14, 2009 | 1997 Lincoln Continental
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Dec 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Dometic Rooftop RV Air Conditioner Logo
183 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
