Question about Toro Lawn Mower With Toro Power Tools
Lawnmower won't start has gas & oil - Toro Lawn Mower With Toro Power Tools
  • 718 Answers
You need to check if you have spark! Without spark gas does not ignite, then oil means nothing without ignition.
Posted on Jun 04, 2010
Why won't it fire up?
lawn mower trouble shooting, no start
First check the air filter. Is it getting air and gas? If not lets find out why.
1. Air Filters; There are 2 types. One is made of paper and the other is made of foam. NOTE: (Whenever you lift your lawnmower for any reason disconnect your spark plug and ground it.) NOTE: Do not run your engine or any engine without the air filter, it will RUIN the motor. When lifting your lawnmower on its side, always lift it with the carburetor up. A little oil Will come out, but not enough to hurt anything. If you lift your lawnmower with the carburetor down oil & gas will go everywhere. If your air filter is made of paper the oil & gas will ruin it. If not you will have to clean your foam one.
a. Paper filters cannot be cleaned with gas or any solvent, you can only use compressed air to blow the dirt out. If it's very dirty, it's best to replace.
b. Foam filters can be cleaned with dish washing liquid and water and dried with a rag. Then very liberally, work new engine oil throughout the air filter and squeeze out excess. The oil in the filter is what traps the dirt. If your foam filter is deteriorating or coming apart replace it, it can ruin your engine. Clean every 25 hours under normal conditions. Note: Use the same type of engine oil you use in your small engine to lightly oil your filter.2. Check your gas cap. The gas cap is a source of ventilation for the fuel tank. If your gas cap is clogged it will make your fuel tank vapor lock, and you will have no gas flow. To check and see if the gas cap is bad, loosen the gas cap and see if it will run longer than before you loosened the gas cap. If it continues running, you need to replace the cap, if it does not continue running check further in this troubleshooting guide for more information.
3. Is the fuel line clogged or partially clogged? Example: when you disconnect the fuel line from the carburetor and the gas is steadily flowing there is not a problem. But if it only drips with a full tank of gas replace it after checking the gas cap.
4. Do you have a fuel cut off? If so, is it cut on?
5. Do you have a gas filter? If so is it clear? If not, replace it.
6. Is the gas flowing in to the carburetor? If not you could have a piece of trash in the needle & seat. The needle & seat controls the gas flow that starts & stops the gas. You will have to clean or replace. It's best to replace.
7. The float controls the gas level in the carburetor. If any of these signs occur, the carburetor is overflowing out of your air filter or out of your primer. If you have gas in your oil, you have carburetor problems. NOTE: Drain the oil if there is gas in it, if you don't it can be dangerous. You need to check the needle & seat to see if it has trash or is bad. Is your float bad? To check the float pull the pin that holds your float in place, shake the float and if there is fluid inside of the float, replace it. Don't forget to set the float level.
8. Carburetors with primers represent a large majority of lawnmower and small engines today. They have primers to push or force air in the carburetor and in turn force gas through the center jet to make starting easier. Then look to see if the primer is pumping gas in to the engine.
9. Things to check for if the primer is not working. This applies to several different types of engines. Check for holes or tears if you have a carburetor that has a diaphragm. (A diaphragm is a gas pump located in carburetors that have the gas tank and carburetors assembled together.) Replace the diaphragm if the diaphragm has a hole or has hardened or slightly slid over to one side, or if the engine will not run correctly and is skipping, not priming, or will not run at all. If you have a float type carburetor, the bowl gasket Will not be sealed properly and air will leak past the bowl gasket and will not prime. If you have a air assembly primer box where the air filter box is connected to carburetor, your gasket Will not be sealing correctly. If there is a tear or a hole in the gasket, air will leak past it and will not force air in the carburetor which will not force gas through the center jet. Also your air assembly box Will have a crack and will be warped because it was over tightened. If so, replace it.
10. Some models have chokes. Chokes are used to draw gas through the center jet to run. If the choke is not working properly and it is not closing all the way the engine cannot draw gas through the center jet and will not crank.
11. The throttle cable is what operates the choke on some models and the primer on some others, but it works the speed of the engine. To adjust the throttle that works the choke you need to loosen the throttle and open the throttle all the way, then push it until the choke is closed all the way. To adjust a "speed only" open the throttle all the way and make sure that the engine speed will be all the way open and then tighten the cable back up on the engine. Make sure if you have a kill switch on the throttle cable, that it works when you lower the speed all the way. If not, adjust again. Carburetors: Carburetors are the cause of 99% of all small engine problems. Carburetors are the easiest thing to repair on small engines.
We have videos to that will help you in the repair of your Lawn Mower and Small Engine
Section 2 Troubleshooting safety switch system
1. Spark. There are several things that would keep a lawnmower or small engine from sparking like the safety switches. Lawnmowers and small engines have several different locations where the safety switches Will be. If your lawnmower or small engine doesn't spark you need to get your owner's manual and find out where your safety switches are and then try to trace the problem.
2. Oil sensor. If you have one ... The oil sensor will make your lawnmower or small engine quit running until you fill it with oil to the "full level." This will cause the engine not to spark because of the oil being low. NOTE: This is a safety feature to protect your engine from running out of oil.
3. Stop cable or blade brake. This cable is connected to the handle bar and you have to hold the handle bar down for your engine to run. This cable becomes stretched after some time and needs to be replaced. There is a safety switch on the other end of that cable, on the motor, that Will not be opening all the way and in turn, not letting the engine spark.
4. Coils. Lawnmowers and small engines have changed a lot in the last 15 years. 99% of all lawnmowers and small engines today have electronic ignition coils which means no points. When you start your lawnmower or small engine and it runs until it gets hot and won't start back again until it cools off you Will have a bad coil.
Lawn Mower Repair Troubleshooting Lawn Mower
Jan 16, 2016 | Garden
Overfill oil
Did you turn the mower on end or over? If so change the air filter otherwise It sounds like the piston rings are worn out. Rings are cheep but unless its an expensive lawnmower I would just replace it.
Jul 20, 2013 | Yard Machines 11A08MB006 22Inch 139cc MTD...
Lawnmower starting problems
Clean or replace air filter. Fill oil, 30w. Clean & gap plug or replace.
Remove carb bowl from bottom of carb & clean. If gas is 30 days or more old, use fresh gas with Stabile.
Jun 19, 2013 | Garden
My son put oil in lawnmower gas tank
Drain as much as you can out. It won't hurt thing. May smoke a
for a little bit.
Oct 05, 2012 | Toro Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Lawnmower stored for a year tipped up and all oil leaked out -- Won't start now.
You have most likely gotten oil on the coil, You need to remove the pull start assembly and you will see the coil/flywheel, check for any oil contamination which you can clean up with brake/carb cleaner.
Mar 04, 2012 | Poulan "Poulan" Push Mower
185 cc lawnmower Briggs and Stratton was operated with mixed oil,
Was it blowing out blue-ish smoke before ??
Take the spark plug out and clean it good with gas & wire brush..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
270 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
