I have a hp 1350 all in one printer and it displays and E error on the lcd and the cartridge light keeps blinking. I jusr installed a new oem cartridge and the problem persists
  • yan dikshteyn Jun 05, 2010
    thanks ill try and if it doesnt do it?
    Is that the most likely solution to this problem??
  • 5,081 Answers
Remove both cartridges and clean the cartridge and carriage electrical contacts with a cotton swab and alcohol.
Posted on Jun 04, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Jun 05, 2010
    Yes it is the most likely cause
Hp 1350 does not copy
Hi Steve,
Does the printer give you any error message ? the best you can try on HP PSC 1350 is, Remove the cartridges and clean the electrical contacts ( golden points ) on the cartridge and put the cartridge back in. IT should go thru alignment process. IF it does not go, It should display some error. I hope the cartridges have ink in them.
Regards,
Suhail
May 14, 2012 | HP PSC 1350 All-In-One Thermal Printer
Check printer cartridge light keeps flashing
I'm sorry that the Printer Cartridge light is blinking. Please click here to get the information about different causes of this blinking and it's solutions.
Thanks for understanding. Please let me know if you require any clarifications.
Sep 16, 2011 | HP PSC 1350 All-In-One Thermal Printer
HP Deskjet 6940 Series Printer: I'm on my second brand new color cartridge for this printer. The printer simply doesn't recognize that the cartridge is installed. Sometimes the color cartridge...
if you are not buying NEW OEM cartridges they will never work properly. and once installed if they are oem they will not work the second try either .
Nov 16, 2017 | HP Deskjet 6940 InkJet Printer
The Check Your printer light keeps coming on. I
did you change the cartridges with O.E.M. or aftermarket? If with O.E.M inks then there is a problem with the waste ink container and it needs to b cleaned.. requires removal of the waste in station which is under the inks on the right side of the printer
Mar 31, 2010 | HP PSC 1350 All-In-One Thermal Printer
Blinking light in verifier cartouche d' enhcre
I understand that you are Check print cartridge lights are blinking on your printer.
To resolve this Click Here and go through the instructions mentioned in the HP website.
May 22, 2009 | HP PSC 1350 All-In-One Thermal Printer
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
Replaced HP LaserJet 2840 catridges and now [?][?][?][?] ! error
The OEM cartridges have a chip on them. If the aftermarket supplies do not have the right chip, missing a chip, etc., the machine will not recognize. Placing the old cartridge back in without any toner can give off the same message.
Try rebooting the printer without a cartridge in. Then install the cartridge, either one, and see if that helps. If not, wait for the OEM to arrive.
Jan 27, 2009 | HP LaserJet 2840 All-In-One Printer
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Dec 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
All lights are blinking, printer doesn't work. What does this mean?
This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one.
The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem:
Disconnect the power cord.
Lift the scanner4.gif lid and carefully line up and install the front panel overlay.
Plug the power cord in.
let me know if this solves your problem wendy.
Dec 18, 2007 | HP PSC 1350 All-In-One Thermal Printer
20 people viewed this question
k24674
jasbo
jasbo
