Question about Pelonis KCD-25YI Air Conditioner
How do i run a continous drain for the condensate i am not very mobile and have trouble emtying the container, especially at night. it always seems to fill up at 4 am, at which time the a/c turns off and the room becomes unbearable.
    Welcome Back:
    Visited the website for 2 consecutive days.
The owner's manual available at:
http://www.appliancefactoryparts.com/content/pdfs/127116-1.pdf
explains how to do this on page 11
Posted on Jul 08, 2010
    Sergeant:
  • 338 Answers
I would try to plumb it into a sink drain because this looks like it portable unit.
Posted on Jun 04, 2010
Getting unit ready to store.....should I take the drain plug out of the unit while I run the unit 3 to 4 to dry the inside of the unit
first of all you're talking about the humidifier correct? You should always drain things out if your especially if you're going to store them outside as you don't want them to freeze. Running it for little bit should have running it for little bit should not be necessary as the moisture just collects on the condensing coils and drips into the receptacle below so running it for a while will do nothing but cause them to collect condensation on the coils which then you have to drain back out again.... so in short to store it remove the air filter if it has one and most to wash it was soap and water let it dry empty the condensate tank let it dry put it all back together and store. I hope this helps you.
Aug 31, 2017 | Heating & Cooling
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Jul 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
My portable air conditioner is leaking water from underneath ...I have had it 2yrs...I have never even had to empty it as it has always been dry...This problem has been soaking my apt...I have tried all...
All aircon units condense water, and if it's especially warm moist air in your apartment, the condensed water will overflow from the 'capture tank'. Check for a rubber bung/pipe behind the unit at floor level. Every portble AC unit will have one. Unplug the bung and empty it into a container. Best to do this on a table so that the container can be left on a chair beneath the machine. You may need a bucket.
Sep 07, 2017 | Cars & Trucks
This is a D945E - when on continous drain, condensation runs out of the drain but also leaks all around the unit
You need to check the position of the drain tray, it could be tilted and fill up before reaching the drain pipe
Jul 11, 2011 | Amana Dehumidifiers
On cooling the pan fills up in 2 hours. gets hot in the night having to empty it all the time plus no sleep.
I cant help you with the sleep part ... is there a way you can fasten a drain hose to the collection container?
Eventually, you will get the water out of the air in the space you are cooling and the filling of the container will slow down.
The way I see it your options are: (1) keep doing what you are doing (2) get a bigger container (3) find a way to drain the condensate away to a drain or other place where the water can be collected and pumped away.
You could turn the AC off at night ... that way there would be no condensate produced.
Thanks for your question @ FixYa.com
May 30, 2011 | Heating & Cooling
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
My air conditioner is leaking water
The air conditioner have water runs into the plastic container and when the container is full of water the weight will switch off the whole unit until you empty this container.
The tube that deliever the water into this plastic container blocked up with dirt that stop the water runs into the container and overfill the condenser drain pan that water runs all over the floor. Clean this condenser pan outlet and the connecting tube then you will be ok.
Jul 01, 2009 | Movincool Classic Plus 26 Air Conditioner
Unit never seems to stop running, always running
There are several things that could cause this issue. If you have a condenser fan underneath the fridg that has stopped running due to poor lubrication, maybe debris blocking the fan blades or a dirty condenser especially if you have pets. You can clean the **** from under the fridg (remove the grill on the front and vacuum out) or if the fan is not running with the compressor as it should repair or replace it the fan motor. Also a worn out door gasket can cause excess run time.
Jun 26, 2009 | GE Refrigerators
Water leaking underneath when drying,whats the problem
Hello!
If leaks only on drying, then it might be the condensing system, maybe the fittings of the condenser on the drum got loosed. Remove the back panel and inspect after leaks on the left side where the condenser is.
Feb 27, 2018 | Washing Machines
Always defrosting GE Model 20
clean the condenser coils at the back and make sure the condenser fan by compressor is running if is not running you mightg need to call a tech to trouble shoot it or if you want repl both the motor and main board like i said you might need a tech to trouble shoot it
Oct 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
Pelonis KCD-25YI Air Conditioner Logo
444 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Bruce Showalter
Craig Butler
Craig Butler
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
