Sprint Hitachi P300 Cellular Phone Logo
Posted on Jun 04, 2010
How do you set the alarm on a hitachi KC-55 digital alarm clock
1helpful
Hitachi KC-82 manual available ?
Hello Patrick Allfrey,
By Hitachi... I was seriously abused as a child... SU carburetors are bad enough but when HITACH CORPORATION decided to put out their semi-(MAL)functional... (YUK)...
SMOG-SAFE imitation side draft ... carburetors... on the otherwise GLORIOUS (brand-spanking-new) 1973 DATSUN 240Z...
I my humble opinion! (truth is... otherwise awesome innovators).
HOWEVER:
It does not surprise me that I can search the cyber GLOBE...
and find vast quantities of equipment orphaned to a "LEGACY" GROUP... (but still no sign of your - KC-82)
I was TOTALLY unable to find any KC-82... anywhere.
I did find a "docking station" closely numbered...
attributable perhaps to a dirty/damaged identity plate...
Any chance we are talking about a very clever
"DOCKING STATION" (KC320)...??
Page 18 of 23
http://www.manualslib.com/manual/466470/Hitachi-Kc320.html?page=18#manual
Else I will post 3 dead end avenues... And you can develop your own: GOOD HUNTING.
Search Results Hitachi in
Hitachi OneVision Program Registration Digital Media Division Hitachi...
Hitachi Clock Radio manuals
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 • Watches
Need a free user/repair manual
The glass/plastic over the face may be dull and causing the dim display. Otherwise your VFD is going bad.
http://www.electronic-circuitry.com/e/action/ShowInfo.php?classid=61&id=89934 Here is the manual
The time does not automatically set on my sony alarm clock XDRC706DBP
Afraid I have the same problem and I have to manually set.
good luck !
Hitachi kc-752h diagram
Might not need a schematic. Check the diodes and fuses in the power.
1helpful
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
3helpful
Don't know how to set alarm clock or timer - have set clock OK
To set the Time all you have to do is hold memo/c.adj while on standby, the screen will flash 24hr if you press tune it will flash 12hr pick weather you want 12hr or 24hr and then press memo/c.adj to set the hours press tune then hold memo/c.adj to get to the minutes and then press tune to get the minutes set
2helpful
No instruction manual with item
Hi Ann This is a relatively new product so its not surprising you're struggling to find info online. I'd suggest contacting Hitachi cust services anyway:
http://www.hitachi.com/GlobalSupport/ContactUs?form_type=global_support
Also, go along to Dixons because they do sell this item and just state that you bought one from there but there was no user manual. They can copy one for you there.
2answers
HIT KC-91 clock alarm
If the manual says you can't chance the volume, then you can't change the volume! You might be able to rig something to make it a bit quieter though...
See if you can see where the speaker/sounder is located (there are usually some small holes drilled in the casing to let the sound out, although sometimes there might only be the one.) Try covering some/all of these with a piece of sticky tape. Other than that, there isn't really anything you can do!
Hope this helps,
Matt
Top Sprint Cell Phones Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
