Can you tell me how to open a hp w1907v lcd screen ??
  • RUI MOREIRA
    RUI MOREIRA Jun 04, 2010
    can you tell me how to open the back cover of a lcd 19'' monitor lcd from HP model w1907v ( is not a laptop !!)
  • RUI MOREIRA
  • 19,396 Answers
Disassembly is the same as HP v19 series. Here the service manual.
Posted on Jun 04, 2010
Testimonial: "NO COMMENTS YOU ARE THE BEST GURU ...THANKS VERY VERY MUCH"
  • 4,281 Answers
For that you need to open front lcd panel from laptop all laptop has same methods to remove display.
Click here
Click on above link there is method how to open lcd display from dell laptop.
Same method in hp laptop also.
Let me know if you need further assistance.
Thanks for using FixYa.
  • 2 more comments
  • RUI MOREIRA
    sorry but im not talk about an dell laptop, is a lcd monitor from hp and the model is w1907v, since i dont see no screws on it i !!!
  • Click here
    Click on above this is for all hp model laptop.
  • If it is not a laptop then check in back side of lcd then you can find screws open all screws and remove then it will open.
  • RUI MOREIRA
    because i cant see no screews on the back and no way to open im asking if there is any technical manual i have try on the HP site but nothing..
After 2 seconds my monitor HP w1907v is switching off itself and there's no way to bring it back to life again. If i switch off and on again the monitor shows images for 2 seconds and then dies. I...
Well the monitor obviously works, so I see no reason to open the case on the monitor especially because there are no user serviceable parts within the case. my sugestion is to try the monitor on another PC if that yeilds the same results then I am wrong and the problem lies with the monitor. I believe the are two types of connections for this monitor shane_barnha_2.jpg VGA and DVI shane_barnha_0.png
Next step is to try the one that you have not tried yet if that fixes it then the problem lies in the output conection on the back of PC the input connection on bottom of monitor or the cable itself. If there isn't a second connection like I think then the next option would be to try another monitor, which if you do not have available can be achieved by using most new flat screen TV's If you have a TV With the same conection Just move the PC or TV close enough to try, Use your remote to change TV input to PC then turn TV off connect cable turn TV on and start up your PC if this works you will need to have your monitor repaired or replaced.
Thumbs Up if helpful, Feedback is Appreciated!!!
Good Luck!!!
Jun 18, 2011 | HP w1907 LCD Monitor
When i turn on my pc and window is coming up after 30 seconds or 1 minutes my monitor is going to sleep and then i have to turn it off from case and then turn it on my monitor is hp w1907v please help me...
if you can see the Windows Logo. i think the problem is with the Video card.
try to boot in safemode:
Turn off computer and as the computer is booting tap "F8 Key" Continuously which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
see if your going to have the same problem. if not try to reinstall the graphics driver or see if other application is causing the problem
May 10, 2011 | HP w1907 LCD Monitor
I have an HP w1907v monitor. It is connected to my PC via a blue 15 pin VGA cable. It has now started going into sleep mode when connected to my PC. The monitor came with the PC and is 3 years old. I have...
If the monitor works when connected to another pc then it's good and the defect is in your present pc - its video card is defective and it will have to be replaced.
Apr 18, 2011 | HP w1907 LCD Monitor
I've got a HP w1907v monitor and latly it has been going into sleep mode without warning while i'm using it. All my power saver settings are set to off.
If this monitor is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 18, 2010 | HP w1907 LCD Monitor
I am trying to replace the LCD screen on a HP Pavilion DV7-1020US, but I've never worked on a screen like this before. There is another screen over the LCD screen, where the border is literally glued...
you could try calling place where you got lcd or look online for a place that sells the lcd, and tell them you want to order another one but your not sure how to take the old one out for part number
Apr 22, 2010 | HP Pavilion DV7-1020US Laptop
Monitor says No input signal and going to sleep. Pc is on and running Vista. Hp w1907v monitor HP Pavillion slimline pc. Can you help please?
Try cleaning your RAM it should be the issue mostly 80%
You can check by rremoving the VGA cable if the system shows no signal mostly monitor should be fine
Nov 30, 2009 | HP w1907 LCD Monitor
Stretched images
on your monitor there should be a auto resize. is it dvi? or hdmi or vga?
Jan 03, 2009 | HP w1907 LCD Monitor
Unable to attain 1440x900 screen resolution on my HP w1907v
Does the video card ,in the second machine, support 1400x900 resolution? I am running dual 7600 video cards and that optional resolution is not available to me. Will it change to any other resolution setting?
Nov 24, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
1,024 people viewed this question
David Payne
David Payne
