Question about General Electric Advantium SCB1000M 975 Watts Convection / Microwave Oven
Micro will not heat,blows air ,lites up,takes time commands but n
Micro wave MFL 31918601 BUILT IN lights up ,blows air but will not heat
    Problem Solver:
  • 11 Answers
Chek the H V fuse,Diode&Magnetron
Posted on Jun 04, 2010
Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
Had a problem with voltage (edison) smelt something burning while micro-wave was in use. now the lite+time works but nothing else. jenn-air jmc813odds
If you open the door of the microwave can you smell an odd odor? if yes the magnetron is probably fried "heats food" the other parts that need to be checked are the high voltage capacitor and diode. I recommend appliance repairman or tv technician to further check with an estimate.
Jan 30, 2011 | Jenn-Air JMC8130DDS Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
HOW DO WE VENT THE EXHAUST OUT THE TOP OF OUR MICROWAVE when we turn the exhaust fan on it blows out the front but we thought it went out the top so we could vent through a cupboard, attic to the outside
You will have to remove the micro wave from it's mount. Once you have it down, look at the top of the micro wave. There will be a panel that you will have to move from one place (where it is now) to another. This panel will either be on the top of microwave or if the mounting kit has a top plate, it will be on it. The panel normally has two screws holding it in. When you remove it, you will need to re-install it so that it blocks the air flow from coming out of the front. There should already be screw holes where you are to install it. When you have it moved, re-install the micro wave.
I hope I didn't confuse you. The only reason it's not blowing out the top is because whom ever installed it didn't move the panel. All over the stove micro waves come with this movable panel so you can vent it either way you want. If you have the installation papers, it will explain this better. Good luck.
Oct 17, 2009 | Frigidaire Microwave Ovens
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
General Electric Advantium SCB1000M 975 Watts Convection / Microwave Oven Logo
134 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
