Question about Toshiba W522 VHS VCR
Recorded audio sometimes staticy
We record by timer through our satellite and also manually by pushing the RECORD button on the VCR. Most of the time, the result is fine. Now and then, however, the recording's sound is loud and staticy, like a TV station off the air. This has happened two or three times, and we can't figure out why.
Thank you!  sheryl rodgers Texas
    Sergeant:
  • 291 Answers
Usually, you have to meny wires connected to too meny things and left 'floating' all over the place.
tie up all the loose wires in the back of the machines.they sometimes act like an antenna.
Posted on Nov 12, 2008
My vcr wont record when programed but will if you just push the record button
When you set the timer see if PDC appears. If it does switch it to off and try setting a record. PDC sometimes doesn't work. And the recorder will sit there waiting for the signal to tell it when to start recording. Which never comes! However you will have to set the time to adjust for it not recording late running TV shows. For example a show to start at 8pm and finish at 8.30pm, will need to be set at 7.59 till 8.35pm. Or you could miss the start or end! Wheras PDC would get it all even if it started at 8.05!
Nov 22, 2010 | Sharp VC-H982U VHS VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
How do I tape onto a vhs from analog tv with converter box?
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
Jan 02, 2010 | Mitsubishi VS-55707 TV
Set the timer to record
Do you have the remote which came with it? Most VCRs of the last 10 years require the remote to setup a timed record, or for that matter, most of the advanced functions- beyond play/rewind/ffwd, etc.
Assuming you do have the remote, and the correct time is set, and the timed record properly setup, some VCRs require a the On-Timed-Record button to be pushed. This sets the VCR in a wait mode, until the time set for the recording to begin.
Consult your owners manual- an online manual may be available if the printed one is missing.
Mar 04, 2009 | Sharp VC-H812U VCR
Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Nov 26, 2008 | Panasonic PV-7451 VHS VCR
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Vcr Samsumg Vr8460
1. Is the VCR coming on in the timed mode and recording? Make an experiment- set up a timed record for just a few minutes in advance. Have a tape in the machine- then wait a few minutes & see if it indeed comes on and records. This should for sure help you diagnose your problem.
Note: When a timed record is set up, some VCRs must be turned off, or a particular button pushed to activate the timed record mode, where it will wait for the specified time and come on by itself..
2. Video source set correctly? If all you get is a blue screen, or a moment of snow, then the timed recording is happening, but there is no signal present.
Jun 17, 2008 | Televison & Video
Toshiba DVD/VCR Recorder
The only thing you can do is to program the recorder to come on and record at a certain time and also program the event timer for the Bell Expressvu.
Mar 13, 2008 | Televison & Video
Toshiba 13 inch tv/vcr quits recording audio
Does the audio "cutout" suddenly, or does it ''drift" off and on?...accordianman
Feb 28, 2008 | Toshiba MV13L3 13 in. TV/VCR Combo
Vcr timed recordings
I'd be pretty certain that every VCR made these days (and of the last 10-15+ years) can be set to do a timed recording. They can be set for a one time recording, weekly or daily record. Whether used with a cable/satellite box, or outside antenna, you must ensure proper hookup. I'm not real familiar with recent cable/sat receiver boxes, but older ones had to be set to the channel you wanted to record, as the VCR will only see that channel. On older cable (no cable box) & outdoor antenna systems, a VCR could tune in and record any channel, while you watched another one. Anyway, check the capability of the cable/sat box, and follow suggested hookup. You will likely need to set the box to the channel you want to record before you retire for the night.
Sep 26, 2007 | Televison & Video
Toshiba W522 VHS VCR Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
