Question about Frigidaire GLTF2940ES Front Load Washer
Washing machine wont agitate
The machine fills with water but it never starts agitating to wash the clothes. I had someone look at it and they said it was the door sensor that was bad, is there anything else that would cause this problem?
    President:
  • 1,430 Answers
This is usually caused by the door switch. These are fairly inexpensive and very easy to replace. First unplug your machine. To check you will need to remove the wire ring that holds the front door seal to the front panel. To do this go to the six o’clock position and you will see the spring of the wire clamp, grab this with a pair of needle nose pliers. Grab it right where it connects to the wire part of the clamp and pull it parallel to the front panel. This will stretch the spring so it can be pulled over the flange. Next carefully peal the door seal off of the flange. You do this with a sort of rolling motion towards the opening in the door. Next remove the screws that hold the door switch in place. Make sure you have one hand supporting the switch assembly while removing the screws. Now pull the whole assembly out the opening. Mark wires if you need to and then remove the wires. Now connect your ohmmeter to the 2 wire on the bottom you should have a reading of 1500 ohms no less than 1400ohms. If it is below the 1400 or more than 1700 replace the switch. To reassemble reverse the order of disassembly. Making sure the little arrow on the door seal lines uo with the mark on the front panel. The spring can be a little trick to get back on but grab in same position as removal and use the other hand to push it over and around the seal. Here is a tutorial to walk you thru http://appliancehelponline.com/washerdoorswitch.html . If it is within this range the main control board is at fault. Not inexpensive. You can enter your model # at www.appliancehelponline.com to view diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Jun 04, 2010
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
During filling reaches fL before finished filling and stops
Not sure if this was explained to u but these washers do not fill like the old top loads did... the machine uses very little water, the clothes are rolled over and over through the water as it cascades down and up through the agitator. If you look at the agitator you'll notice it does not have an elongated spindle, it's not required. Although the machine doesn't fill your clothes will be fully washed, this design was developed to conserve water...
Aug 19, 2013 | Kenmore Oasis Agitator 4.5 cu. ft....
When I start the washer it starts agitating immediately. It fills with water as it would normally but at first it is agitating dry clothes. It is a whirlpool with the automatic water level control.
well the auto water control is not working right,,,,it should be,,water first then wash,,
its going to rip your cloths up for you one day?????
Nov 28, 2010 | Washing Machines
Maytag washer wont agitate
Well if it does it in all cycles you can rule out the timer. I would say the agitator is maybe striped out.
Jun 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Jan 22, 2009 | Roper Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
117 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
