Question about Dell Inspiron E1705 (DNDWGA3) PC Notebook
Dell inspiron laptop screen colours inverted (negative)
I’ve got a Dell Inspiron 1545 and the colours on the screen are inverted! This happens in the bios and continues through to windows. Dell diagnostics seem to show the displays working OK but theres a few colours on the test colour strip that appear a bit darker. When it plugs into an external monitor its fine so I’m assuming the graphics card is OK. I’ve replaced the hard drive, reseated the RAM and installed windows 7 updated all the drivers and bios with still no avail. Also unplugged the monitor to motherboard connector and cleaned it.
Ive run out of things to testdo! Im a PC technician so please feel free to give a technical explanation ix
Thanks guys
Rory
  • Bob  Adam
    Bob Adam Jun 05, 2010
    If it happens in Bios it has nothing to do with the OS. I am a little confused about the test strip showing darker colors, are they inverted, or no? I've never heard of a screen failing in this way, but theoreticaly the board that tells the LCD what color to put up could be damaged. This is the board on the back of the screen itself. A similar situation when a failed LCD puts up a single pixel line.
    Guru:
  • 868 Answers
If the same issue occurs in the BIOS your soluton is to have your LCD screnn replace or have your LCD inverte cable checked/replaced ^_^ this has nothing to do with the BIOS vodeo card drivers do not function in the BIOS to be able to do such in the BIOS screen
Posted on Jun 05, 2010
Dell inspiron screen went black but if use flashlight you can faintly see desktop
sounds like the inverter has gone. local shop should repair easily and quite cheap.
Oct 14, 2014 | Dell Inspiron 1545 Notebook
I have a 18 month old inspiron 1545 and suddenly its display went to dead black. But still windows is loading up i can hear sounds and music but can't see a single blink on the display. Don't know...
Hi paramvirgull...
Hook your laptop to an external monitor and see if the screen comes on...if it does then your lcd screen is faulty and needs replacment.
If it does not come on then re-download your video driver/s. If that does not work.
Maybe your lcd inverter or backlight bulb is faulty and needs replacement.
Please take time to rate me thumbs up
Sep 16, 2011 | Dell Inspiron 1545 Notebook
Hi i recently started having problems with my dell inspiron 1545 screen. At first it started to freeze and fade to bright white, eventually after a few days it became stuck white even after booting the...
Hi lewis haywar,
Try to replace the LCD inverter in your laptop. Most common issues on LCD are due to failing LCD inverter. It fails more often than LCD cable or LCD backlight does.
Please let me know if this solution helped to resolve your issue.
May 11, 2011 | Dell Inspiron 1545 Notebook
Where can I buy a new 15in screen for a dell inspiron 1545?
You can buy it in dell outlet or else you can buy it in eBay
Mar 11, 2011 | Dell Inspiron 1545 Notebook
I have recently changed the LCD screen on my Dell 1545 Inspiron laptop and having carefully refitted the new screen- LTN156AT01 (same as original) refitted the battery and turned on all we get is a...
Are you sure the new screen was working before you fitted it? What was the fault with the original screen? Have you tried connecting an external monitor to see if the Laptop is otherwise working correctly?
Feb 16, 2011 | Dell Inspiron 1545 Notebook
My Inspiron 1545 turns off when I unplug it from adapter, and when plugged in, the power light on front flashes four times orange and one time white repeatedly.
Does the battery for dell inspiron 1545 plug in. It maybe because the battery pack is too hot ,you can turn off the laptop,let the pc notebook and the laptop battery both cooled down.Then try turn on it to see. If still happen to the matter,it must because the wrong turn off did harm to your Inspiron 1545 laptop adapter.
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
Oct 12, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
Feb 07, 2010 | Dell Inspiron 1545 Notebook
The screen on my dell inspiron 1545 64 bit windows vista is darker on one side than the other and sometimes flickers and progressively gets darker, could it be a driver? or something that i can fix online...
The CCFL [cold cathode Fluorescent] bulb is dying. Manufacturers use these thin 'tube' style lights at the edges of your display for laptops and LCD monitors & TVs. Don't let it go too long or you will possibly destroy the inverter that provides the power to light the bulb.
tom
Dec 22, 2009 | Dell Inspiron 1545 Notebook
Dell Inspiron E1705 (DNDWGA3) PC Notebook Logo
871 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
