Question about Fisher and Paykel GWL11 Top Load Washer
I have a Fisher Paykel Model GWL 11 washing machine. A couple of days ago the machine was operating, but when it came to the spin cycle it would not enter the cycle. It kept trying, but eventually let out several beeps. In order to find out what is wrong, I need to know how to read the blinking diagnostic lights, but the sheet stored in the board for that info has been misplaced. Can you help please with diagnostic / tech help on this appliance?
  • Fisher and P... Master
  • 713 Answers
Yes I can help.Starting from left to right on the line that the lights are lit the fault code values of each are , Starting from the far left they go 1st=128 2nd=64 3rd=32 4th=16 5th=8 6th=4 7th=2 and 8th=1.Add up the lights that are lit on your machine and reply back and I will let you know what part is faulty.
Posted on Jun 05, 2010
Fisher and paykel model gwl 11 drains but wont high spin
they have a speed sensor at the bottom on side of motor if faulty it wont let motor spin up. sometimes it can be a computer panel issue .
if machine does the check lights and beep ok likely it is sensor
Feb 25, 2017 | Fisher and Paykel Washing Machines
F&P washer stops spin cycle
You will need to check the out of balance switch under the motor controller board for corrosion and replace if faulty.
May 24, 2013 | Fisher and Paykel Washing Machines
My fisher&pakel gwl 11 wont drain/spin
Your motor controller board needs three 332k resistors replaced to make it spin again,Only on Series 11 Models
Jan 28, 2013 | Fisher and Paykel Washing Machines
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Washing Machine Model GWL 11
The power supply needs three resistors removed,R129,R130,R131.
and one 1megOhm put in it's place.
Feb 25, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel GWL 11 is getting the error code 37. Checked for blockages, none found and pump operates normally, no sounds, impeller turns freely. Still will not drain in spin mode. Any suggestions?
Hi just read your posting.Try this,Put a couple of books under each foot of the machine high enough so you can look under the machine at the pump.Now select a spin mode and push the start button.Does the pump turn on its own?Where is your machine draining the water to,Is it into the laundry sink or some place else.Please reply with this additional information and this will help me in diagnosing this fault for you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Suddenly the spin cycle won't work. The motor makes a funny noise. The drum just remaiins still. Model GWL 11. The lights are on and there is no alarm.
Hi just read your posting.Now, does the machine drain?What lights are on?Does the machine fill with water and agitate?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel washer gwl 11 us
ok You have a blown Motor controller module. There could also be another fault that caused this to blow up. eg a faulty drain pump, lid lock or Diverter valve, inlet valve. you'd need to use a ohm meter to test all these. cheers
Mar 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Gwl 10 washer
Check that the pump isnt blocked.
Mar 01, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
642 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
