Question about Westinghouse 19" Widescreen Flat Panel LCD Monitor
Light on monitor turned to blue
Working at my computer when the light on the screen dimmed and then came back less than bright with a blue hue.
  • 53 Answers
Sorry man! You have defective monitor. Consult the workshop
Posted on Jun 04, 2010
Flash goes every time, even when there is no lightning bolt in the screen (for lack of better terms). Also a few photos turn out blue that were taken indoors.
210 wide camera is auto detect the environment. If you face it under bright light, the flash will auto off, if away from bright light, it will auto have flash. for photo have blue hue do show me the image, i take a look
Jan 10, 2014 | FUJIFILM Instax 210 Film Camera
LG W1943SE monitor dimmed
tried first with adjustment at set up menu, select the contrast and brightness and make some adjustment. if you can not get with adjustment i may say that one portion of the screen back light is not working. check for burnt connector at power inverter board or busted back light.
Sep 15, 2012 | Computers & Internet
My samsung 940b it has a clear bright screen ( as normal ) just for 2 seconds then the screen turns dark but you can see very very dim Window logo.Turn off the power ( does not matter for how long ) when...
Shine a flash light onto the monitor, if you can see icons/desktopon the screen then you know you need a new monitor!
You should be covered under warranty!
Mar 02, 2011 | Samsung SyncMaster 940B Monitor
Screen very dim ..how do i turn up the contrast /brightness
Hello !
Test with an external monitor. If it works, there is a problem with the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
May 08, 2010 | Computers & Internet
Gateway 900g monitor will not turn on. When the power button is pushed, the blue light just flashes.
Check the monitor with a known-good cable. Look for bent pins in the connector to be safe. Next, have a bright flashlight handy. Dim or turn off the lights in the room. Turn on the flashlight and hold it very close to the screen. Look around the screen carefully and try to see a dim image in the display--if you can see the computer image, it means a problem exists with either the power supply section or, the actual display section. What is happening in this case is two(2) extemely thin, very bright, fluorescent tubes are failing to ignite. These tubes are usually laid top and bottom on the larger monitors, out of view by the user. Their light is transmitted through a series of specially designed plastic sheets which reflect against a shiny back sheet--this gives you the crisp, bright whites and colors in the image. Warning: if repairable, this is a very involved repair. Have purchasing a new monitor in the back of your mind if you send the unit out to a repair facility for a quote.--Just my thoughts--Rick
Sep 21, 2009 | Computers & Internet
Blue circle cast on top of & through middle of screen
When you start getting like a blue hue-haze-spot, etc. Yes the issue will be with the light engine system
Sep 01, 2009 | Hitachi 55VS69 55" Projection HDTV
The on off button on front doesn?t turn the unit off and on
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
Jul 03, 2009 | Gateway FPD2275W LCD Monitor
The brightness and color have dimmed.
This could be something with the cable or an internal connection if it is intermittent.
Mar 02, 2009 | E-Machines eMachines Monitor E15T4
Monitor gone dull
there is a key on the keyboard which controls brightness. on mine it is the second key on the right, of the bottom row. it has a small sun on it. Press this key at the same time as the function key (on mine, bottom row, second from the left, blue key marked Fn) - and the monitor will brighten up.
Apr 19, 2008 | Computers & Internet
Sony SDM HS93 works fine, but: Monitor will not turn on with power button, if I plug in A/C cord power light goes on, monitor works. Sometimes the monitor comes on too bright, other times, too dim....
i get same..controls not working ,,sometimes menu button works and one arrow button..button "ok" button doesnt work and up arrow...brightness not working.
i get black box in upper left corner...quite diffucult to get rid of.
G
iamthehipster@yahoo.com
Feb 25, 2008 | Sony SDM HS93 19" LCD Monitor
Westinghouse 19" Widescreen Flat Panel LCD Monitor Logo
67 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
