Question about Garden
Whice device is used for programing airbag ecu of cars
  • 15,935 Answers
It depends on the manufacturer.
What is the make/model you are searching for?
Thanks!!
Posted on Jun 04, 2010
  • pammyreet1 Jun 04, 2010
    skoda octavia 1.9 tdi . ecu number is 1c0909601
    any find outs
Location of airbag ECU on 2001 (Y) peugeot boxer 2.8 HDI
hi, the airbag ecu is in the bottom of the center of the dash.
cheers
Jan 20, 2014 | Cars & Trucks
How can I reset the drive side air bag light?
You need to access the Airbag ECU (Electronic Control Module) using suitable diagnostic equipment connected to the data link connector of the car in order to erase all faults - DTC (Diagnostic Trouble Codes) memored, unlock and reset the Airbag ECU. Then the Airbag light will turn OFF after approx. 4 seconds, ignition ON.
Oct 28, 2011 | 2003 Volvo S40
Airbag light stay on when you driving the ford escape
Good Luck!
Oct 25, 2011 | 2004 Ford Escape
How to reset the air bag light on audi 1999
First of all you should access the Airbag ECU (Electronic Control Module) using suitable diagnostic equipment (VAS, VAG-COM) connected to the data link connector of the car in order to erase all faults - DTC's (Diagnostic Trouble Code) memored, unlock and reset the Airbag ECU. Then the Airbag light will turn OFF after approx. 4 seconds, ignition ON.
Good Luck!
Oct 17, 2011 | 1999 Audi A6
Air bag light on
For turning OFF your airbag light you must connect a diagnostic scantool to the data link connector of the car. in order to access the Airbag ECU (Electronic Control Unit) and erase all faults memored. In other words reset the Airbag ECU. Then the Airbag light will turns OFF.
Jun 26, 2011 | 2001 Volkswagen Golf
My air bag light is on
You need to access the Airbag ECU (Electronic Control Unit) using VAG or similar diagnostic equipment connected to the data link connector of the car, in order to pull out all DTC (Diagnostic Trouble Codes) memored. Then you will be full informed about bad components, and you will be able to repair & replace bad pieces. After reparation it's necessary to erase all faults from Airbag ECU & reset it. The Airbag ECU warning light can only be turned OFF using suitable diagnostic equipment! Disconnecting the battery will not turn OFF the Airbag ECU warning light!
Good Luck!
May 29, 2011 | 1999 Volkswagen Passat
I am trying to reset the srs light on my 1996 Mitsubishi colt. I have replaced the airbag and rotary switch(springs behind wheel) but cannot seem to locatate my airbag ecu. Where is the location of my...
If the airbag has been deployed, is is necessary to REPLACE the airbag (SRS) ECU. It is located below the center console. (See picture) It must be replaced because on your vehicle, it contains the crash sensors. If you do not replace it and hook-up new airbags and turn the key on, the new airbags will immediately deploy. There is no way to "reset" it.
May 24, 2011 | 1996 Mitsubishi Mirage
Vw golf mk5 airbag fault wires cut under seat reconnected does it require fault reset
You can reset the Airbag ECU only using VAG or similar diagnostic equipment connected to the data link connector of the car, even you had repaired first fault wires cut under seat! After all faults erasing from the Airbag ECU the airbag warning light will turn OFF.
May 23, 2011 | 2007 Volkswagen Golf
Airbag light stays on in a 2003 audi a6 i've replaced airbag module & drivers seatbelt
Good Luck!
May 15, 2011 | Audi A6 Cars & Trucks
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
