Question about Sony Alpha DSLR-A300 Digital Camera
Cannot load raw rfiles from camera to computer
    Brigadier General:
  • 11,967 Answers
You need to download them to a folder you create on your desktop. Then import them to a photo editing program with a raw convertor such as Photoshop Elements.
Posted on Jun 04, 2010
I bought a cannon camera EOS 70D, when i use PhotoShop Elements 10, i cannot open the image if the image was taken in RAW.
Hi found a manual for PhotoShop Elements 10 here:
http://help.adobe.com/en_US/photoshopelements/using/photoshopelements_10_help.pdf
It is a pdf file which can be saved to disk for future reference and contains (page 53) a paragraph below:
"Prefer Adobe Camera Raw For Supported Raw Files Ensures that all the supported raw files are opened with Adobe
Camera Raw instead of other software. Select this option if you have added other plug-ins to Plug-Ins folder"
It may be that you have to load the relevant plug-in in order to load these files, or load this plug-in before attempting to load the RAW file.
Hope this helps
Nov 17, 2014 | Cannon Cameras
Why am I no longer able to set my 60D camera to take RAW formatted pcitures
In order to select RAW mode, first check if your camera is in either Manual(M)/(A)/(AV)/(Ev) modes. Then go to setting-picture format-RAW/RAW+Basic.
In order to edit the RAW picture, you need to update the RAW version if you are using Adobe Photoshop for editing your pictures.
Thank you!
Regards,
Pratish Shrestha (pratis010)
Jun 27, 2014 | Canon EOS 60D Digital Camera
I have lost my camera book and need help .when I try to print pics at Walgreens computer will not load pics.it says no photos available.but I can take pics fine and look at them on cf card in camera b
You may download the manual and more from here.
Are you possibly shooting pictures in RAW format? Photo kiosks such as those at Walgreens won't recognize Canon RAW photos, only JPEGs. Check the camera's image quality settings, as described beginning on page 60 of the manual.
Nov 14, 2012 | Canon EOS Digital Rebel XTI Digital Camera
Probably the same problem as cate_cahill on Oct
Your description of the problem is confusing to me. First it seems you are saying your camera doesn't take a raw file in addition to a jpg. Then it seems you're saying when you look at the files using another reader the raw file is there. Usually you can connect your camera to a PC using the USB connection and it will show up as a removable drive, if you do not have the Cannon software on your PC. You can then drag the files into a folder on your hard drive. At some colleges they only use client PC's and applications reside only on their servers. It takes administrative permissions to attach drives or load applications. That MAY be the case where you attend. If this doesn't help you, please clarify whether the raw files can be seen on the Jessops card reader or not.
Dec 04, 2009 | Canon EOS 450D Digital Camera
My 450D thinks it's recording RAW pictures - only JPG on the SD
It is possible that you have set your Camera to RAW+L instead of RAW. Take card out ofb the camera, use a card reader and browse the card using the OS (as auxillary drive) rather than Aperture. I suspect that the RAW files are present, juts not visible on your computer possibly because of some setting in Aperture.
Oct 17, 2009 | Canon EOS 450D Digital Camera
Computer does not recoznise images file
.Nef is Nikon's RAW image identifier. See if there's an update for iPhoto at Mac website. Perhaps your camera (if it's new) is not yet set up to upload to iPhoto. You didn't indicate what camera you're using.
Sep 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Raw Photos
"AW files are usually proprietary to the camera manufacturer and sometimes to the specific model of camera. That means, only the camera that takes the picture can understand the information collected on the camera sensors. That information is then translated by means of firmware (software) built into the camera and the usual result is a more user friendly format called JPEG."
From
Understanding RAW Format
Read also wikipedia :
Raw image format
In substance many software do not manage Raw format, this is normal. The newer photoshop CS3 can manage some Raw format , depending on the camera.
Photoshop 6 does not read Sony RAW format.
You need to export pictures from camera using jpeg, or to use a converter software if pictures are already on computer, see:
Convert RAW to JPG
Aug 20, 2008 | Adobe Photoshop 6.0 for PC
Canon eso 350/PowerBookG410.4.11
The proublem is likely to be driver based, depending on how old the laptop is and the os version ie lepard 9 (this is an example I am not sure which versions of the os the camera is compatible with) you may not be able to get the camera working properly.
Regardless of if the camera says its compatiple try the following.
Try doing the following 1: Try using a compact card reader to see if the files can be transfered onto the computer this way.
2: If the camera is not picking up the files there is a good chance your husband is shooting in raw mode, as such there canon may offer a raw program editor or a pluding / update for the os which would allow you view access or modify the files. Alternitiverly install a trial for the latest version of a package of Adobe Light room of Adobe photoshop, as these packeges have support for the raw files inbuild, and can be used to import photos onto computers.
Alternitverly if you can not find away of using the raw files buy a new compact flash card and shoot in jpg till the computer is back up and running.
Jul 02, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Raw setting
You do need RAW compatable software to read these files.
However this should not prevent you simply saving them to a file.
When you say regular Wizard - is this the Windows scanner/Camera Wizard or the one on the Camera CD
If the latter delete that software and use the Windows version.
If you are using the camera to up load images - not a a good idea think of the battery drain - a Card reader is better.
Reading Raw images?
Do a web search for free software
IrfanView Might as indeed Picasa - two to look at
Nov 09, 2007 | Nikon D50 Digital Camera with Nikkor AF-S...
Sony Alpha DSLR-A300  Digital Camera Logo
35 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
