Aspire 5920 when computer is on for 5 minutes or so it freezes up. When you press alt/delete it doesn't respond. YOu then have to hold power button down to shut it off. I am not using that laptop to communicate with you.
    Sergeant:
    Champion:
  • 293 Answers
Format the hard disk and reinstall the os
Posted on Apr 09, 2008
Acer Aspire One D257 13450 with windows 7 starter will start up in 5 minutes will freeze control alt delete mouse or curser freezes only way to shut down is hold the power button until it shuts off.
Have you checked how much space you have left on your drive? When I went over one time that happend to me..so I deleted 100GB and it was fine after.GOOD LUCK
Jun 06, 2015 | Acer Computers & Internet
Tip
How to Check your Computer when a Page Freezes
<p>1. Press the "Esc" once or twice and see if the computer returns to normal. If nothing happens, press a few times. If your computer does not respond, try the next step.<br /> <p><br /> <p>2. Press "Ctrl, Alt and Delete keys simultaneously and select Start Task Manager". Select Programs "End Task" to a status of "not responding" one by one and click OK. The programs should be automatically closed. If your computer is not responding to anything, press the button until the computer turns off.<br /> <p><br /> <p>3. Wait a few minutes before the computer. If the computer is in use for a long time, let cool before again. Overheating can some hardware components do not work anymore, because too much heat.<br /> <p><br /> <p>4. Deleting files or programs you no longer use, especially if the disk is almost full. When the computer tries to find a complete unit of information, they can freeze and become unresponsive.<br /> <p><br /> <p>5. The use of anti-virus software on your computer for malware, adware and viruses. Remove the virus. You can stop computer processes and cause a computer to freeze.<br />
on Jun 21, 2011 | Computers & Internet
How do I get the green keys on my acer aspire 5920?
OK, have you "pressed AND hold down" one ALT key while pressing the other green-key you need?
Is the CAP LOCK on?
Hope this helps.
Topbarhive
Jan 02, 2015 | Acer Aspire 5920-6335 Laptop
My Acer aspire 6920 laptop keeps freezing . It will load up fine and then after about 5 or 10 minutes it freezes and says the programme is not repsonding. Noting will work i.e. the mouse won't move,...
HI, what program is show this message? is it always the same program? if so try uninstalling that program and reboot the laptop to see if it will freeze up.
Dec 20, 2010 | Acer Aspire 6920-6621 Notebook
Computer freezes after about 5 minutes of turning
Looks like the Laptop is running some backend program which could be either a service, an application running at the stealth mode, or a driver program that seems to seize the Memmory resource allocated to the Kernal. Did you try check the system log by going to Start - Run - eventvwr.exe wherein you will find two heives namely Application and system. On the second start try to go through this event viewer which is opened as i said before and find out if you can locate any memmory related critical error or any application related critical error which lead it to a hung state and a restart registered later.
If you cant find that please boot in a safe mode and see if this is happening. It should not happen ideally speaking. Still if this is happening, try to restore the OS or run the repair disk of Acer Aspire. This should resolve the issue. Still if you cant resolve this issue its surely due to a hardware problem. I would advice you to go ahead tappering the chances of problems starting from an OS monitoring to Hardware Troubleshooting as per the steps i have explained here. Good Luck.
Feb 14, 2010 | Acer Aspire 5610-4648 Notebook
My Acer Aspire 5920 won't fully recover
is hardware problem send to repair or a new one
Dec 29, 2009 | Acer Aspire 5920-6335 Laptop
Sir, i have bought a acer laptop model aspire 5920 but when i was working on it suddenly it shut down and till now i cannot made it power on can you tell me the problem
Remove the battery and the power adapter, wait 5 minutes, plug in the power adapter and try turning it on, if it doesn't turn on, remove the power adapter, plug in the battery and try starting up again, if it still doesn't work plug in the power adapter, try starting up.
Is the power adapter working? does it have a green led on it that shows that its powered?
Sep 10, 2009 | Acer Aspire 5920 Notebook PC
The system cannot find the specified file
It seems as though your windows is corrupted. To solve this I would recommend a recovery back to factory settings but this will delete all the data of the computer.
You can save your data by
using an IDE/ATA to USB adapter on another computer or take it to computer store.
To begin the recovery
Remove all external devices like printers, mp3 players etc
Ensure the laptop is running on ac power
You can start the Recovery from outside Windows by holding down ALT and F10 on the Acer BIOS splashscreen on power up.
Jan 19, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
