Question about Mtd 22" Yard Machine Push Mower
MOUNTFIELD PETROL MOWER WONT RUN
THERE IS A SPARK I REPLACED THE PLUG AND FUEL IS REACHING THE CARBURETTOR. IT WILL ONLY RUN FOR A FEW SECOND IF I POUR PETROL DIRECTLY INTO THE CARB . I HAVE TOOK THE CARB OFF AND CANT SEE ANY BLOCKAGES ,THE MACHINE IS IN GOOD ORDER.ANY HELP WOULD BE APPRECIATED AS ITS AN OLD LADIES MOWER AND SHE REALLY DOESNT NEED TO PAY REPAIR BILLS ,
  • 718 Answers
If there is a float bowl on this model, takeoff the center screw and look for a little pilot hole on the side and take a small pin or the like and clean this pilot hole and try again to start. Good Luck Pal.
Posted on Jun 04, 2010
Fuel filling up the cyclinder, runing out the exhaust. Removed spark plugs and petrol came out. What is causeing this to happen?
It certainly sounds like the needle valve is stuck.
If it is a gravity feed fuel system and a normal carburettor it sounds a particularly bad design not being equipped with a petrol tap to isolate the supply when the machine isn't in use. Gravity fed designs without a fuel tap would typically place the fuel level below the engine inlet ports to prevent that potentially dangerous and/or expensive type of flooding. The surplus fuel would then run from the carburettor float chamber vent which if it presented any immediate danger would be piped away.
As part of the investigation and repair it would be a good idea to change the engine oil.
Feb 28, 2015 | Garden
Put diesal in my petrol lawn mower by mistake but then emptyed it out and put petrol in but it wont start
I hope you have no air in the fuel tubes. A vapour lock will not allow the fuel pomp to bring fuel to the carburettor. So make sure the tubes to the carburettor contain fuel, then I hope everything will be ok.
Almost impossible to damage the motor, it only will run fine in the beginning.
Success
Jul 22, 2014 | Garden
Suffolk Punch 35s not starting
carburetor have a setting level for its fuel , check the floating control adjust fuel level , also check spark plug current is there,just by rotating engine and keeping spark plug out of cylinder , just keeping it with engine body.
Apr 12, 2014 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
Mower been in the shed foer winter,2yr old model wont start,checked the spark plug,fuel,carb checked all moving parts,still only sputters when pulling cable to start
flooded????,,turn off petrol, take out spark plug,,give a few pulls then replace plug turn on fuel and give it a try,,cheers,hope this helps.
Feb 27, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a Mountfield bvs153 petrol mower. The
It fails after it has 10 minutes to warm up right?
I think you should run it till it fails and then test it for spark.
My guess is that your coil is going bad and heat just triggers the failure. After a while even cooling down wont help.
The good news. If you need to replace the coil its a pretty simple job that can be done with a few hand tools and a new coil. It shouldnt be too expensive either. 25-35 dollars for a new one if your shop around online or go to Ebay.
The only thing special you need to do once you have removed the recoil cover and removed the old coil is to take a piece of thin cardboard *(I actually recommend the box the coils usually come in. But a playing or business card will do) Put this paper between the coil and the flywheel to set the coil gap. Tighten on the screws and then pull out the paper. Put the recoil cover back on and you are done!
Good luck and be careful.
Oct 12, 2010 | Poulan "" Push Mower
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Hi, Honda HRG465C Petrol Mower running problem
The first thing to check is the spark plug, is it clean and properly "Gapped" next is are we actually getting spark, does the spark plug actually "Spark". Check. Check Spark Plug lead., Check connections. Do we have Fuel, Check .and Is the fuel getting to the Carburettor? Check. Check the battery. alternator, generator, is providing power. Check the Mixture.
Mar 23, 2010 | THQ The Lawnmower Man
Mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Nov 20, 2008 | Garden
Mtd 22" Yard Machine Push Mower Logo
653 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
