Question about Bosch Tools & Hardware - Others
Removal of tool rest from Bosch PDA 240e sander
I need to replace the tool rest on this delta sander. The sanding plate comes off easily. It clips into the tool rest. To get the tool rest off you have to split the body of the Machine. That's OK. The tool rest is connected to the bevel gear shaft that carries the eccentic weights. The bottom end of this shaft passes through a bearing on the tool rest and seems to be an interference fit. Whatever I do I cannot free the shaft from the tool rest
mikeymiddles
  • 58 Answers
SOURCE: Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Posted on Jan 10, 2009
efs_perpends
  • 1996 Answers
SOURCE: need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
comax
  • 154 Answers
SOURCE: Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
Posted on May 05, 2009
protek480
  • 1714 Answers
SOURCE: my delta 31-250 sander dc drive motor will not
Did the DC drive give you a fault code? It may have tripped on a current over load. Needs to be set to handle load.
Posted on Jun 30, 2009
  • 32 Answers
SOURCE: bosch 3283 dvs sander has unbalanced spin
This means the sander has been droped and the pad support and/or the bearing orbit has been bent, maybe even the motor shaft. Never leave any power tool sitting on a bench, always set it on the floor, it will end up there at some time anyways. You can try replacing a part at a time and spend a lot of money and time, but is it worth it?
Posted on Jul 18, 2009
Please help me to understand a faulty motor
If you go on a Bosch factory web site you should be able to enter your model and down load a parts list. From that you will see that the motor drive an eccentric dog that causes the plate to jitterbug. If you kept the original paperwork you will have had this with it. All Bosch units come with warranty and parts list. Look up your nearest Bosch tools agent, see if he'll strip it if you can't and determine what's needed. You may find its easier and more cost effective to shop around online for a special offer and buy a new one. Not very green I know but may be more practical.
Jul 21, 2014 | Bosch Pex 400 AE Expert 350 W Random...
How do I change the sanding belt on a 31-300 delta sanding center?
it comes with a edjustable screw on it.you will need to adjust screw for it to fit on the right way.
Feb 27, 2011 | Delta Machinery Sanders Sanding Center -...
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
How do I remove the backing pad on the Bosch PDA 100 sander. What does the red slider button do at the front of the pad, on the back plastic side? Does this remove the pad. Do I need to pull it off or...
Piece of cake. Just push the red slider as far as it will go in the direction of the arrow. Look for the seam where the pad attaches to the sander plate, that is where it separates. Give the rubber a little tug, and it should come off quite easily. Pop the new pad on, lock it in place by pushing the slider button as far as it will go (in the opposite direction to the arrow) and job's a good 'un!
Dec 18, 2010 | Bosch Power Tools Sanders Orbital Sanders
Should I buy an old Delta sanding Center? Is it wise to buy an older Delta sanding center 31-730F Not all parts are still available. They want $250.00 for the sander
If it's the kind with a round disk sander and a wide belt sander, as far as I know belts and disks are still available. There is not much else to wear out. Make sure you test it before purchase.
May 12, 2010 | Delta Machinery Sanders Sanding Center -...
2606610901
Hope this helps
May 04, 2009 | Bosch 3107DVS Electric Sanders & Polishers
Jan 07, 2009 | Bosch Power Tools Sanders Orbital Sanders
Tools & Hardware - Others Logo
99 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
