Question about Jenn-Air JXT9048CDP Kitchen Hood
WHAT KIND OF MOUNTING BRACKETS,AND CAN WE GET THEM FOR JENN-AIR JXT9048CDP 48" HOOD
  • 8,197 Answers
You can get the manual on the link below to see what parts you will need. page 8 will show you.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208110P262-60-R5.pdf
Then on this link below you can order the parts that you need. pif the part is out of stock then call them to see when it will be in stock.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170251
Or you can go to Jenn-Air on this link below.
http://www.jennairpartsonline.com/SingleModel.aspx?mp=171562
Good Luck
Good luck
Posted on Jun 04, 2010
How do you recommend cleaning your stainless range
cream of tartar moistened with water and a paper towel
Aug 08, 2013 | Jenn-Air ® 48" Professional Over The...
I have a vespa px cutdown and i want to mount a spare wheel on the legshields what mounting bracket could i use?
Hi there! Older largeframe mounting brackets bolt directly to frame, and your PX is not prepared to justplug it in. If you are willing to mess with your frame, I would choose another option for the spare tire... (or just live with a emergency anti-flat spray) If you do want to use the classic mounting brackets (they will look better than any other option), try to measure on another Vespa where the holes are located. Sprint, GTR, etc use this kind of spare tire bracket.
Sorry if I didnt get you the answer you most wanted... (and please be kind when you rate me ;) )
Regards!
Mar 07, 2011 | Peg Perego Vespa Scooter
How do you recommend cleaning your stainless range hoods? The outside especially is very greasy, with a nice mixing of dust caked into it. Last owner obviously didn't keep it up!
wash rough dirt off first. Then use a rag and lots of soap to get rid of the grease. Then slightly soak a rag with vinegar. That should put a sparkle on things for you. Also, I use windex but instead of a rag or paper towels, I use newspaper. Just crumple up a piece and use it like a rag. This shines lots of stuff up and works best for cleaning windows inside and out.
Oct 16, 2010 | Jenn-Air ® 48" Professional Over The...
Trying to install the rotissere on our Jenn-Air outdoor grill. Instructions lost and the installation seems impossible!! Help!
I have instructions for model# 720-0093 Jenn-Air rotisserie, pretty simple, 4 bolts total. Must admit, I had to go back to Lowes for help since I was trying to install brackets the wrong way. Will be glad to email these to you, let me know @ caycebugs@sc.rr.com
Aug 16, 2010 | Jenn-Air Grilling
I do not have the stainless steel backsplash, I had a custom stainless steel piece made that keeps the back flat into tile. When I am using the burners, and than turn on the oven, the burners go out and...
backsplash will not cause a problem unless this was the only open air space of the oven, if both left and right and back of oven are closed, this may cause a shortage of air to the oven. half inch to right and left of oven should be enogh. let it breath.
Sep 03, 2009 | Jenn-Air ® 48" Professional Over The...
JENN AIR RANGE HOOD JXT8136ADS
make sure the fan blade not touching anything. make sure are clean the grease sticking to the blades can make the fan go out of balance
Jul 04, 2009 | Jenn-Air JXT8136ADS Kitchen Hood
Surport(mounting) brackets for window air con
You will have to contact the manufacturer to find asessories for your brand. They should also have a link for where you can find them in your area.
Apr 05, 2009 | Haier ESA3243 Thru-Wall/Window Air...
I cant get it to turn on
Hi lillady909,
I'm Harvey the Master Plumber.
Your problem is: you cant get the lights or fan to turn on anymore is there a reset switch
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 23, 2008 | Jenn-Air ® 48" Professional Over The...
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Jenn-Air JXT9048CDP Kitchen Hood Logo
94 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
