Question about NetGear WGR614 Wireless Router
Office network At the moment i'm running a small office network. When user hop on there computer and want to access the shared files on the network they have to type in a user name and password. I have 2 salesman that come and go quite a bit. So i thought for ease i'd add a wireless router. Went out and got me a Netgear WNR3500 router. Placed it between the modem and my other router. I have 2 issues, one laptop connects fine but when he trys to access the server it does pop up with a log in window like it used to. Just tells him he doesn't have permission. The other laptop says that windows was unable to find a certificate to log on to the network. I'm lost on both... any help would be appreciated!
  • 7 more comments
  • Gishmou Apr 09, 2008
    I have to leave the old router connected due to to many computers for the new one. I got the one to access files through a simple protocol switch... the problem i'm having now is that windows was unable to find a certificate to log on to the network on the other laptop...
  • Gishmou Apr 10, 2008
    ok my issue now has nothing to do with connecting to the server. I 've solved that problem. The problem I have now is that one laptop won't connect to the wireless router. When i go out and search for wireless networks i find it. RIght now the network is called NETGEAR. I try to connect to it and windows gives me this message "windows was unable to find a certificate to log on to the network NETGEAR"
    i can connect with it wired... but no wirelessly lol
    yes i use it at home wirelessly and it works great
    all steps are done... it says its connected to my wireless network but that its identity
    i reread what i typed... i meant to say that its validating identity and i'm using dynamic
    ok I've done everything but step (4) up to this point. My entire netowrk is dynamic. The router address is 10.0.0.1. When i pull up my wireless connection window on my laptop it says that its valitidating identity
  • Gishmou Apr 11, 2008
    ok... wipe out the whole situation and lets start over.... its a toshiba laptop with windows XP on it... it works at my home network and all i did on this network was install a wireless router.... no i'm getting the error bubble on my taskbar that says "windows was unable to find a certificate to log on to the network NETGEAR" and then when i got to network connection on the laptop it says that its connected but its validating identity....
  • andrewjgriff May 17, 2009
    Mine is a Belkin router... and I havent had the 'certificate' problem before but have just reinstalled the PC and I'm getting the certificate error. The wireless adapter connects to the network with very good signal strength (but nothing works), then it disconnects/reconnects 3 times then gives up.
    My theory? I've not got any XP service packs installed yet and I think the problem is because the router is running WPA-PSK and my new install isnt compatible so they cant handshake properly, even with the encryption key entered correctly.
    I'm going to try assigning an IP manually outside the DHCP but not convinced it will do the trick.
    Thanks,
    Andrew G.
    Sergeant:
  • 202 Answers
Hi Gishmou,
You don't need the older (wired-only) router any longer. You can use the newer router for your entire LAN - just as you did w/ the older one.
"Wireless" routers are capable of both wireless AND wired connectivity. "Wired" routers, however, can only manage "wired" connectivity.
Perhaps this is where the confusion lies? Please, let me know if I am misunderstanding the issue you are experiencing.
If I understand your issues correctly, the 1st thing you'll need to do is take the older router out of the picture.
(01) Disconnect all connections from the old router and remove it from your network.
(02) Remove power from the new router and the cable modem.
(03) Connect the WAN port of the new router directly to the cable modem.
(04) Connect the new router (via an Ethernet patch cable) from one of the LAN ports of the new router to the computer you would like to use for setting up the router.
(05) Restore power to the cable modem and wait for approximately 1 to 2 minutes (or until you get a solid (always on) Internet or WAN led lit).
(06) Once you're sure the cable modem has established connectivity w/ your ISP (Internet service provider), then restore power to the new router.
(07) Give it a minute or so - it will need time to p/u the cable modem connection.
(08) Now, from the computer you have directly connected to the router via a patch cable, enter the router setup utility by opening a browser and entering the router's LAN IP address or by using the setup CD that came w/ the router.
IF the reason you were attempting to keep the older router along w/ the newer router was you needed more than the (usually) 4 or 5 LAN ports available on your new router?
If that is the case, install a network HUB or SWITCH and connect it (usually w/ a Cross-Over cable) to one of the LAN ports on your router. (If you choose to do this, we'll help you set it up and wire it properly.)
The older router you are using is quite possibly not capable of being set up as an "Access Point" (rather than a router). There needs to be one router then you can use an access point or a hub or a switch to increase the number of nodes on the network that will be supported.
If you'd like assistance finding the documentation and setup instructions for this router, please, let me know.
Please, post back here w/ any questions at all you might have and w/ the results of the steps you've taken. We'll continue to work w/ you until your network is up and running properly. @:)
* If the information I provided you w/
* resolved your problem or lead you
* to a resolution for your problem or
* an answer to your question, then, a
* "FixYa" rating would be most
* appreciated. @:)
* (You can assign the same rating to
* more than one expert who participated
* in solving your problem.)
* It is best to wait until the problem
* has been resolved b4 rating the experts'
* solution(s). Once you enter a rating,
* the problem will be closed and we will
* not be able to continue to assist you.
* Very often it will take more than one
* exchange of information between you
* and an expert in order to resolve your
* problem. If a proposed solution doesn't
* work for you, don't rate it yet. Instead,
* post back here letting us know and we'll
* continue to work w/ you until we find a
* solution that does work for you.
* Thank you
* BJ @:)
Posted on Apr 09, 2008
  • 14 more comments
  • B Joan Rapier
    B Joan Rapier Apr 09, 2008
    Hi Grismou
    I see what you're saying. You still might have a configuration issue, though.
    I'd rather use a router and switch but according to this next article, two routers should be fine IF one can be set to "client" or "access point" mode. Now, this is for a home network, mind you. No servers involved requiring authentication.
    HERE is a nice article on configuring routers on the same LAN. The caveat is, you must be able to set one of the routers in "client mode" or as an "access point". That router must be "secondary" router while the one that remains set to function as a router is the one on the front end - behind the cable or DSL modem. IOW, they can't both live happily on the same LAN thinking they're routers...
    Hmmm, now if THIS fellow is right, I may just have to eat my hat! (when it comes to one having to be in client or access point mode and the other in router mode). Router + Access Point (or switch or hub or combination thereof) is how I was taught. That's my story and I'm sticking by it! @:)
    I'm just kiddin' around.
    (01) Can either of these laptops authenticate through the server then connect to the LAN or WAN connected to the secondary router *hardwired*? I'd get them working wired b4 tackling the wireless end. Might help you pin down the problem better. Wireless is messy - too many variables. Save it for last (if you haven't already).
    BJ @:)
  • B Joan Rapier
    What OS is the server that's doing the authenticating running?
    What OS is on the laptop(s)?
    What method of authentication are you using?
  • B Joan Rapier
    THIS is the configuration I have in mind (just on a much smaller scale, of course).
  • B Joan Rapier
    B Joan Rapier Apr 10, 2008
    It's possible you're trying to connect to someone else's router. I've seen this a number of times. Wireless router's now-a-days have huge ranges. Folks very often don't change the default SSID. So, they're accidentally (and not-so-accidentally) connecting to each others' wireless radios all the time.
    "Netgear" is the default SSID on most of their wireless-enabled routers. Change the SSID to an unique one (via one of your wired connections) and try again - this time choosing the new SSID. Let us know if the issue persists.
    Be sure to set up wireless encryption, too. AND change the setup login password on your router.
    But do these things until you've gotten the laptops to connect through and authenticate OK wirelessly.
    We don't want to through any more variables than necessary into the mix.
    Is that same laptop able to connect OK to the new router wired? (and acquire a certificate?)
  • B Joan Rapier
    My apologies for the typos... Please, don't set up wireless encryption or a new router login password until you've gotten the laptops connecting OK through the wireless-enabled router.
    W/ the laptop that isn't getting its certificate, trouble-shoot the issued via its wired connection to that router so as to keep the variables to a minimum. Once you have it working wired, then try it wirelessly.
    If you have the wireless access list security enabled on the router (access to the router restricted by MAC address), disable it for now.
  • B Joan Rapier
    That's great actually. That fact really pins down the problem.
    (01) Is the laptop able to connect to any other wirless network (wirelessly)? (e.g. an Internet cafe, college library, etc.)
  • B Joan Rapier
    I suspect the laptop is attempting to get its certificate regardless of whether or not there is network connectivity.
    (01) Ensure that the wireless radio is enabled on the laptop (usually there's a switch on the front or one of the sides or a button below the monitor).
    (02) Check your IP configuration for that laptop's wireless connection. Make sure its configuration is compatible w/ your network.
    (03) Compare the TCPIP configurations for the wired and wireless connections on that laptop. If it isn't all dynamic, set up the wireless TCPIP configuration w/ that of the wired configuration (you'll have to change the wired configuration or it'll fuss at you (using the same IP on two connections))
  • B Joan Rapier
    If the laptop works fine (wirelessly) at home then that points even more at it being a TCPIP configuration issue.
    (01) Do you have wireless access security enabled on that router? If so, temporarily disable it.
    (02) Did you change the router's SSID? You shold do this anyway as - at anytime - other "Netgear" SSIDs can start showing up in your wireless range. It'll get confusing choosing which one to connect to.
  • B Joan Rapier
    (03) Are you using static or dynamic IP assignments on your LAN?
  • B Joan Rapier
    I'm not quite sure what you mean by your last comment. "...that's its identity..." ?
    Which steps have you taken? (I've thrown a lot out there. Just want to be sure where we are.)
  • B Joan Rapier
    What is "validating identity"? Do you mean the server? Do you mean the wireless connection to the router?
    Are all the connections on your LAN using dynamically assigned IP addresses?
    What is your router's LAN IP?
    (04) Assign a static LAN IP to the laptop's wireless config. Use an IP outside the DHCP range. Now lets see what happens.
  • B Joan Rapier
    (05) What utility are you using to access your wireless router from the troubled laptop?
    IOW, is it the Windows Wireless management utility or is it a 3rd party wireless management utility, (often bundled w/ laptops' software).
    (06) What OS is running on the laptop?
    (07) Are you running Novell Netware by any chance?
    (08) "Validating Identity" is not being generated by your router I'm fairly certain. Again, unless you've set up some sort of restriced access (e.g. by MAC address). But that usually doesn't have any messages associated w/ it.
    (09) I think the message is being generated by your server or you're using a networking client on this laptop (and server) I'm not aware of.
    (10) Start comparing configuration etc between the laptop that is being allowed to access the LAN wirelessly and the one that isn't. Something is different there either in the configuration on the laptop or the server. At this point, I don't think your issue has anything do do w/ the router (IF all is well w/ another device on the same router connecting successfully (and wirelessly)).
  • B Joan Rapier
    B Joan Rapier Apr 11, 2008
    (11) Do a hard reset of the router. (if you don't know how to do this, please, let me know)
    (12) P-L-E-A-S-E, assign a **DIFFERENT** SSID to it. We have to rule out the possibility of the laptop trying to connect to the wrong router. (You should never leave the SSID at its default name anyway (NETGEAR))
    (13) Disable ALL wireless security on the router (including MAC address and WEP or WPA encryption, etc.)
    (14) Configure it to work w/ the other router again and get at least one of the computers working through it via a WIRED connection.
    (15) Once you have the wired connectivity working, try the wireless again.
  • B Joan Rapier
    (16) Please, post back here w/ any error messages you see **verbatim** (exactly as they appear).
  • B Joan Rapier
    (17) Does THIS help at all?
    I would be surprised if it does it this laptop is connecting through the same router fine when it's using a wired connection and only experiencing apparent "certificate" issues when it's using the wireless connection.
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello Gishmou
    How did it go? Did the certificate issue w/ the laptop get resolved in the end?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to work w/ you.
    If it is the case and my assistance contributed to the resolution of the problem, would you kindly take just a moment to assign a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
Make my Lexmark x5340 be wireless'
Is this a wireless printer? Is it being used for a large office or a small home type office? If you are using it for a home office and have multiple pcs, then you can setup a homegroup. A homegroup is like building your own personal small network. You will be able to share and print documents between your computers. Once you setup the homegroup, on one computer, then you will have to add the other computers to the group using the access code that the first computer will provide. Be sure to enable printer and file sharing when setting-up the homegroup. Once setup, you will be able to print your documents from any connected printer on your network. It's not wireless but it might help to solve a print sharing problem. Good luck. How To Set Up Homegroup Sharing Plus Printer Sharing
Dec 22, 2014 | Lexmark X5340 AllInOne InkJet Printer
HP1020 problem with a livebox and WIN7 configuration
I found it somewhat difficult to completely Unshare files and folders on my HomeGroup Network and still allow Printer sharing in Windows 7 (Home Premium).
Initial UnSharing still allowed files like those below to be viewed on other home network computers:
C:/Users/
{user x} (folder)
AppData (folder)
Default (folder
Public (folder)
desktop.ini (file)
Other computers on the home network could step through many levels of hiarchy in the AppData folder and appeared to have "Delete" access!!
To completely decouple the computers, I had to go through the following several different Sharing/Unsharing assignment locations, till I could completely break the linkage.
I would appreciate any clarifications or simplifications.
File UnShare Confusion on HomeGroup Network
There are several different Network Sharing/Protection assignment locations in Windows 7.
To prevent all sharing between computers on the Homegroup Network, but allow Printer Sharing:
1) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options.
Uncheck sharing boxes that you don't want to share. Save changes.
2) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Click "Turn off Public folder sharing (people logged on to this computer can still access these folders)".
3) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Choose Media streaming options.
Click "Block All" button. Turn off. Click OK.
Anomaly Note: You have to close Control Panel and repeat all step 3 again for the change to take effect.
4) Open Windows Explorer.
a) Select "C:/", select "Users" folder with single click, then click "Share with" in toolbar.
b) Select Advanced sharing.
Under Sharing tab, select Advanced Sharing. Uncheck box labeled "Share this folder". Apply and close.
5) Open Windows Explorer.
Select "C:/Users/", select all folders and files under "Users", then click "Share with" in toolbar, then click "Nobody".
6) Verify success by going to other home network computer(s) and trying to access your files and folders. You should only be able to see there is a computer and not be able to see any folders of files.
smooth printer service
Dec 16, 2012 | HP LaserJet 1020 Printer
Can't Share Files/Folders over home network
That sounds more like the security settings on the pc are not set correctly. Should be nothing to do with the card or the laptop. This is just a windoze thing.
Share a drive or folder on the network To share a drive or folder on the network
  1. Open shortcutcold.gifWindows Explorer, and then locate the drive or folder you want to share.
  2. Right-click the drive or folder, and then click Sharing and Security.
    • If you are sharing a drive, on the Sharing tab, click If you understand the risk but still want to share the root of the drive, click here.
    • If you are sharing a folder, go to the next step.
  3. Do one of the following:
    • If the Share this folder on the network check box is available, select the check box.
    • If the Share this folder on the network check box is not available, this computer is not on a network. If you would like to set up a home or small office network, click the Network Setup Wizard link and follow the instructions to turn on file sharing. Once file sharing is enabled, begin this procedure again.
note.gif Notes
  • To open Windows Explorer, click Start, point to All Programs, point to Accessories, and then click Windows Explorer.
  • When you share a drive or folder, anyone who has user access to the network can read the contents of that drive or folder. If you want to remove the drive or folder from the network, follow steps 1 and 2 above to get to the Sharing tab. On the Sharing tab, in Network sharing and security, clear the Share this folder on the network check box.
  • To allow complete access to the contents of your shared drive or folder, follow steps 1 and 2 above to get to the Sharing tab. On the Sharing tab, in Network sharing and security, select the Allow network users to change my files check box.
  • To change the name of your folder on the network, in the Share name text box, type a new name for your folder. This will not change the name of the folder on your computer.
  • If you are logged on as a guest (a guest account provides access to the computer for any user who does not have a user account on the computer), you cannot create a shared folder.
  • The Sharing option is not available for the Documents and Settings, Program Files, and WINDOWS system folders. In addition, you cannot share folders in other user's profiles.
Apr 05, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
MAC OS 10.4 Shared Folder problem
The user has to connect to the mac on which the folder is shared, only after that can the user access the file. I t would be helpful if you could tell me the os type of the other machine.
Jul 02, 2009 | Apple Mac OS X 10.4 Tiger for Mac
Windows Vista
In the start menu click network,on the bar on top click network and sharing center,scroll down and enable network discovery.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
Network access denied
Follow the steps to Sharing the files
Your computers are already connected to a network — i.e., they’re all already able to browse the Internet using the same router..
1 : Open the Network and Sharing Center window by clicking on the Windows orb in the lower left corner, and then either right-clicking on Network and selecting “Properties”, or opening the Control Panel and double-clicking “Network and Sharing Center.
2 : If your network type is “Public,” you need to change it to “Private”:
  1. To the right of the network name and location type, click Customize.
  2. In the Set Network Location dialog box, click Private, and then click Next.
  3. In the Successfully set network settings dialog box, click Close.
3 : Under “Sharing and Discovery” in the bottom half of the Network and Sharing Center window, you need to turn all the settings from “Off” to “On” by clicking on the down arrow next to each setting, clicking on “Turn on …”, and clicking on “Apply.” But see some pointers below:
  1. For the “Password protected sharing” setting: you may want to leave this “On” or turn “Off” at your discretion. (I turned mine off.)
  2. For the “Public folder sharing” setting:
    1. If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    2. But if you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
4 : You’re done with the Network and Sharing Center window. Close it via the “X” button.
5 : Click the Windows orb at the lower left corner of your computer, and click on Computer
6 :
n the Computer window, navigate to the folder containing the file(s) or folder(s) that you want to share — e.g., “Pictures” or “Documents” or a specific file or folder within. Note: don’t open the folder itself that you want to share — just navigate to the folder that contains this folder.
7 : Right-click the folder that you want to share, and then click Share. The File Sharing window is displayed. (Click picture for a larger version.)
8 : If you have password protected sharing enabled: Use the File Sharing window to select which users can access the shared folder and their permission level. To allow all users, select Everyone in the list of users. By default, the permission level for a selected user is Reader. Users cannot change files or create new files in the share. To allow a user to change files or folders or create new files or folders, select Co-owner as the permission level.
9 : If you have password protected sharing disabled (like I do): Click the drop-down arrow inside the blank field in the File Sharing window, and select the Guest or Everyone account. Click “Add.” Then for that new account, click on the down arrow under “Permission Level” to change it to Co-owner (if you want anybody to read and modify files) or leave it at “Reader” (if you want other computers to just read but not modify your files).
10 : Click “Share”, then “Done.”
CRITICAL NOTE: If you selected “Everyone” when sharing a folder, you’re also making its contents available to any computer that joins this network. Many households, including mine, have wireless Internet via a wifi router. If you don’t have WEP encryption turned on, then I could just drive up and park on the street near your home, open my laptop, let it join your network via your wifi, and then nose around through your files. It’s particularly important that you have WEP encryption turned on for your wifi network.
Feb 18, 2009 | SAMTRON 55V 15" CRT Monitor
File sharing
it is possible
If you have multiple computers in your home and they are connected through a home network, you can share files among your computers. That means you no longer have to copy files to a floppy disk or USB flash drive to transfer them to another computer. Once you configure your computer to share files, you (or another user with the appropriate permissions) can, by using Windows Explorer, open them from other computers connected to the network, just like you’d open files that are stored on a single computer. You can also choose to have folders visible—but not modifiable—from other computers on the network.
To share files on your computer with other computers on a network, you need to:
Share a folder on your computer. This will make all of the files in the folder available to all the computers on your network (you can’t share individual files).
Set up user accounts on your computer for everyone who needs to connect to your shared folder. If any of the accounts are Limited User accounts (unless an account is a Computer Administrator account, it is a Limited User account), follow the steps in Set permissions for files and folders to enable them to open your files.
To access shared files that are on another computer on your network, you need to:
• Connect to the shared folder from other computers on the network. This procedure is described in Map a network drive.
Note: By default, file permissions only allow your user account and administrators on your local computer to open your files, regardless of whether a person is sitting at your keyboard or at another computer. It may help to keep these three things in mind when setting up file sharing:
• Files have user permission settings.
• Every computer has its own user database.
• Some accounts are administrator accounts and some aren’t.
Configure your computer to share files To share a folder on your computer so that files stored in the folder can be accessed from other computers on your home network
1.
Log on to your computer as an administrator. For more information, see Access the administrator account from the Welcome screen.
2.
Click Start, and then click My Documents.
68599-click-my-documents.gif 3.
Right-click the folder that you want to share, and then click Sharing and Security.
68599-click-sharing-and-security.gificotip.gif Tip: If you want to share your entire My Documents folder, open My Documents, and then click the Up button on the toolbar. You can then select the My Documents folder.
4.
If you see a message that reads, As a security measure, Windows has disabled remote access to this computer, click the Network Setup Wizard link. Then follow the instructions in How to set up your computer for home networking. On the File and printer sharing page of the Network Setup Wizard, be sure to select Turn on file and printer sharing. If you do not see this message, skip this step and go to step 5.
68599-click-network-setup-wizard.gif Note: If you do not see the Network Setup Wizard link or the Share this folder on the network check box, your computer probably has Simple File Sharing disabled. This is a common change made to computers used for business. In fact, it happens automatically when a computer joins an Active Directory domain. You should follow these instructions to share a folder instead.
5.
In the Properties dialog box, select the Share this folder on the network check box.
68599-click-share-this-folder.gif 6.
If you want to be able to edit your files from any computer on your network (instead of just being able to open them without saving any changes), select the Allow network users to change my files check box.
68599-click-allow-network-users-to-change-my-files.gif 7.
Click OK.
68599-click-ok.gif Windows Explorer will show a hand holding the folder icon, indicating that the folder is now shared.
To connect to the shared folder from another computer, follow the steps described in How to map a network drive.
Note: By default, only you and other people with an administrator account on the computer sharing the folder will be able to open your files. To limit access of specific users with an administrator account on the computer sharing the folder, read How to set permissions for files and folders.
Aug 14, 2008 | Microsoft Windows XP Professional
To share files on network using xp, but only allow certain users over the network from several computers to have acceess to certain files. looking for a user and password prompt to access certain shared...
only the administrator has the access for sharing files on network if you are the administartor on the computer you will be able to share any files If you are working in a corporate enviornment you will have to seek permission to share files hope this solution helps you
Aug 14, 2008 | Computers & Internet
"delayed write failed" in office 2003
You will get a delayed write failed when the network is no longer connected and the user tries to save the file. are you noticing any other issues on your network?
Sep 09, 2007 | Microsoft Office 2003 Basic Edition...
NetGear WGR614 Wireless Router Logo
232 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
