Is there a procedure on the web that illustrates how to replace the drum and blade for a Ricoh Aficio 2045 or can you instruct how to do this
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please follow these step by step instructions on how to install drum unit:
1. Open front cover of copier.
2. Rotate lever (maybe blue) to lower transfer/transport assembly.
3. Rotate Developer/Toner assembly handle to move assembly away from drum unit. There is either a Phillips screw or a plastic gripped screw that needs to be removed.
4. Then, carefully, pull the drum unit 2/3 of the way out. At this point, the back half of the unit needs to be supported while pulling the rest of the way out.
5. Open new drum unit.
6. Remove all packing materials with red tag attached...especially black paper covering new drum surface.
7. The new Drum Unit has guides on top that line up with guides in the machine....carefully insert unit in copier until it seats FULLY.
8. Reinstall screw to front of unit.
9. Rotate Developer/Toner Assembly lever to cam back against Drum Unit.
10. Rotate Transfer/Transport Assembly lever to lift assembly upward and latch.
11. Close the front cover and we are done.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 04, 2010
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Replacing the drums of ricoh mp 2000
You can download the cleaning blade replacement instructions from here:
http://businessneedz.com/Info/?p=540
Jun 07, 2012 | Ricoh Aficio MP 2000 Black and White...
My problem is , to many black lines in image in aficio 2045
the black lines ( narrow ones ) can occure because of worn out charge roller and drum cleaning blade.
First of all You need to replace drum, drum cleaning blade and clean the charge primary roller or replace it.Also if the times was came for drum section, repace also the developer and do the preventive maintenace on copier.
Call service!
Hope that helps!
Sep 10, 2011 | Ricoh Aficio 450 Copier
Km2030 printing coomes out with doted lines throughout the document
Causes Check procedures/corrective measures
1. Dirty or flawed drum. Clean the drum or, if it is flawed, replace it
2. Dirty contact glass. Clean the contact glass.
3. Deformed or worn cleaning blade. Replace the cleaning blade
Jul 30, 2011 | Ricoh Aficio 1018D Copier
Plz tell me code solution Ricoh Aficio 2045 is problem sc 303 code
That is an error in the yellow drum charging unit.
You can have an arching yellow charge, a bad contact, etc.
It is the high voltage portion of the yellow drum unit.
Nov 10, 2010 | Ricoh Office Equipment & Supplies
Sc 990 ERROR PROBLEM ON RICOH 2045/2035. how can i solve this problem..
replace drum, drum cleaning blade,charge roller. this will sort Sc 990
Sep 14, 2010 | Ricoh Office Equipment & Supplies
I need to know the part number for the toner replacement bottle for the Ricoh Aficio 2045 PCL 6
Ricoh Aficio 2045 copier/printers take the Ricoh Type 3110D Toner Cartridge. Go with OEM toner on these machines. The generic version tends to make them run dirty.
Sep 09, 2010 | Office Equipment & Supplies
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio 1018 printing lines, seems to be photoconductor
Cleaning the drum will not help. Depending on many factors including drum condition, number of pages printed etc, you will need at least to replace the drum cleaning blade. This is a common cause of black streaks. The drum should have been clean. The fact that it has toner on the surface is pretty good proof that the cleaning blade is bad. The part number for the blade is B0392289. I would do a search for this part and get one before you even think about trying to deal with the streaking problem. Once you get the blade, if you are mechanically inclined then replacing the blade is not difficult.
Good Luck and Thank You for using Fixya.
Apr 30, 2010 | Ricoh Aficio 1018D Copier
RIcoh Aficio 2045,turn off fax delivery report
download the manual from the www.ricoh-usa.com web site for the fax advanced features.
Refer to page50, from the pdf numbering.
Or at page147, from the document it self numbering.
Here is a link for quick find:http://www.ricoh-usa.com/downloads/manuals/bw/aficio2035/manuals/FaxAdvancedFeatures_PartII.pdf
Jan 21, 2010 | Office Equipment & Supplies
k24674
