Question about Schwinn Midmoor 700c Men's Hybrid Bicycle
Front bearings How do i tighten the front hanle bar bearings?
  • 718 Answers
There is usually a nut just below the stem, at least
1" or bigger put a wrench on that nut. Good Luck Pal.
Posted on Jun 04, 2010
What the torque settling on a 1.8spi vauxhall cavalier 1994
Cylinder head Renew bolts: Yes Tighten: 25 Nm Tighten: 90° Tighten: 90° Tighten: 90° Other engine tightening torques Main bearings Renew bolts/nuts: Yes Main bearings Stage 1: 50 Nm Main bearings Stage 2: 45°-60° Big end bearings Renew bolts/nuts: Yes Big end bearings Stage 1: 35 Nm Big end bearings Stage 2: 45°-60° Oil pump to cylinder block : 6 Nm Sump bolts : 15 Nm Sump drain bolt : 55 Nm Flywheel/driveplate :
  • Use new bolts and tighten as follows:
      • 1,4/1,6 = 35 Nm + 30° + 15°
      • 1,8/2,0 = 65 Nm + 30° + 15°
  • "Pot"-type flywheel = 65 Nm + 30° + 15°
  • Tighten drive plate to 60 Nm.
Clutch pressure plate : 15 Nm Crankshaft pulley/damper centre bolt : Use new bolts. Tighten centre bolt to 130 Nm + 40°-50°
Camshaft sprocket/gear : 45 Nm Camshaft/rocker cover : 8 Nm Inlet manifold to cylinder head : 22 Nm Exhaust manifold to cylinder head : 22 Nm Spark plugs : 25 Nm Lambda sensor (Oxygen) : 30 Nm Chassis tightening torques Front hub :
  • Tighten nut in three stages:
    1. 130 Nm
    2. Slacken off
    3. 20 Nm + 80°-90°.
Steering track rod end : New nuts 60 Nm Brake disc to hub Front: 4 Nm Brake caliper to carrier Front: 30 Nm Brake caliper/carrier to hub Front: 95 Nm Brake caliper/carrier to hub Rear: 80 Nm New bolts ABS sensor Front: 8 Nm ABS sensor Rear: 15 Nm Road wheels : 110 Nm
There you go pretty much covers everything hope that helps
Jan 11, 2015 | Vauxhall Cars & Trucks
How to adjust front fork steerng bearing on 95 honda shadow
Tighten the nut until you feel some resistance on handle bar.
There must be NO free play in bearing, when you squeeze front brake and shake the bike forward and backward.
May 18, 2014 | 1984 Honda VT 500 C Shadow
What does the control arm on the front left driver side supposed to look like fully assembled
Hello! First diagram is the lower...Second is the upper..Guru...saailer
LOWER IDENTIFICATION:
Item
Part Number Description 1
5495 Stabilizer Bar Link Bolt and Bushing Assembly 2
18A192 Nut, Washer and Bushing Assembly 3
808264 Bolt 4
5005 Frame 5
5B326 Torsion Bar (LH) 6
5B327 Torsion Bar (RH) 7
620481 Nut 8
5C491 Nut and Washer 9
3079 Front Suspension Lower Arm (LH) 10
3078 Front Suspension Lower Arm (RH) 11
3A130 Tie Rod End 12
808166 Nut 13
808167 Nut 14
5K483 Front Stabilizer Bar Link 15
5482 Front Stabilizer Bar 16
5484 Front Stabilizer Bar Bushing 17
3B353 Front Stabilizer Retainer 18
N807396-S100 Bolt A
- Tighten to 40-55 Nm
(30-40 Lb-Ft) B
- Tighten to 150-200 Nm (111-148 Lb-Ft) C
- Tighten to 21-29 Nm
(15-21 Lb-Ft)
UPPER IDENTIFICATION:
Item Part Number Description 1 3C156 Damper Assembly (RH) 2 805348 Nut and Washer 3 - Shock Absorber Insulator
(Part of 18198) 4 3C157 Damper Assembly (LH) 5 3020 Front Suspension Bumper 6 3083 Front Suspension Upper Arm Assembly A - Tighten to 34-47 Nm
(25-35 Lb-Ft)
LOWER DIAGRAM FOLLOWED BY UPPER:
Feb 12, 2012 | 1996 Ford Explorer
We purchased a Radio Flyer Stroll and Go but during assembly the front wheel was put on but was put on 90 degrees the wrong way. We are not able to get the wheel off so we can correct the wheel.
Where you inserted the handle bars into the bearing assembly on the frame there is a fork clamp you had to tighten to secure the handle bars and front fork. Loosen this and you should be able to disassemble the front end. While reassembling be sure the you line up the notches on the fork with the grooves in the bearing assembly and that the handle bars are properly aligned before tightening the fork clamp.
Apr 03, 2011 | Cycling
Front brake when pressed has sever wobble from left side
Check your tire pressure and increase to 35 PSI (front and rear). If you have over 20,000 miles on your bike your may want to replace your wheel bearings (front and rear). Short wheel bearing life is common on GL1200 models. You should also consider tightening your steering neck bearings. Loose neck bearings is a common problem on any motorcycles. Disassemble the upper triple clamp far enough to turn the steering head nut and tighten it just to the point of binding and loosen it just enough so the bar turns smoothly with out binding. Most mechanics are to lazy to make the adjustment during the 600 mile check up. If you notice bumpy or ratcheting when you turn the handle bar from lock to lock and a tendency for the handlebars to stop or gravitate to the straight ahead position then you need to replace the steering head bearings in the frame neck. One or all of the things listed above can or will contribute to the condition you describe. Consider a thorough inspection and repair of all the necessary issues before riding this season.
Mar 31, 2011 | 1986 Honda GL 1200 Interstate Gold Wing
Not sure whats loose-solution to tighten everything ok or not ok
well if he tighten the wheel hub bearing nutt to tight it will cause the hub bearings to burn out.....But he is a tec write, So im sure he did it right. Also the noise from the rear mabe something you are heareing now because no noise in the front is gone and the back noise is heard at this point......
good luck to ya.
Aug 01, 2010 | 2009 Hyundai Elantra
Replace broken sway bar for a 1996 ford windstar
Section 04-01: Suspension and Wheel Hubs, Front 1996 Windstar Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise and support the vehicle. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the 6 mm drive hole in the front stabilizer bar link ball stud, do not use an Allen wrench to break loose or tighten or final tighten the front stabilizer bar link-to-shock absorber nut.
    Using care not to damage the front stabilizer bar link ball stud seal, remove the RH and LH front stabilizer bar link-to-front shock absorber nut.
  1. Using care not to damage the front stabilizer ball link stud seal, remove the RH and LH front stabilizer bar link-to-front stabilizer bar nut.
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage the ball joint boot.
    With another set of support safety stands under front sub-frame, remove two rear sub-frame retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar bracket bolts, stabilizer bar brackets, stabilizer bar bracket insulators and front stabilizer bar (5482) as required.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar bracket insulator installation position.
  1. Lubricate inside diameter of new stabilizer bar bracket insulator with Rubber Suspension Insulator Lube E25Y-19553-A meeting Ford specification ESF-M99B112-A or equivalent. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber stabilizer bar bracket insulators.
  1. Install new stabilizer bar bracket insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on stabilizer bar bracket insulators and install new bolts. Tighten to 55-63 Nm (40-46 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Tighten to 115-132 Nm (85-97 lb-ft).
  1. Install front stabilizer bar link (5K483) to front shock absorber. Use care not to damage link ball joint boot seal.
    Install a new front stabilizer bar link-to-shock absorber nut. Tighten to 90-100 Nm (66-74 lb-ft).
Apr 28, 2010 | 1996 Ford Windstar
I have a bad wheel bearing how do I replace it
Hub and Bearing Assembly
ani_caut.gif CAUTION: Do not begin this removal procedure unless the following parts are available:
  • A new front axle wheel hub retainer (3B477) (Step 1).
  • A new inboard halfshaft joint stub shaft circlip.
Once removed, these parts must not be reused during assembly. Their torque holding ability or retention capability is diminished during removal.
Removal
  1. Turn ignition switch to the OFF position and place the steering column in the unlock position.
  1. ani_caut.gif CAUTION: Discard the front axle wheel hub retainer. It is a torque prevailing design and cannot be reused. If loosened, the retainer must be removed and a new one installed.
    Remove and discard front axle wheel hub retainer (3B477).
  1. Raise vehicle on hoist.
  1. NOTE: Make sure steering column is in the unlocked position, and do not use a hammer to separate tie rod end (3A130) from the front wheel knuckle (3K185) . Use extreme care not to damage boot seal.
    Remove cotter pin from tie rod end stud and remove slotted nut. Discard cotter pin and nut.
  1. Using Tie Rod End Remover 211-001 (TOOL-3290-D) or equivalent and Tie Rod End Remover Adapter 211-087 (T81P-3504-W), remove tie rod end from front wheel knuckle.
  1. ani_caut.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to remove the nut, or bearing and seal damage will result. Loosen the nut first, then remove nut from stud using the hex hold feature.
    For SHO vehicles, remove vinyl cover from upper link stud.
    Remove stabilizer bar link (5K484) from front shock absorber (18124) .
  1. Remove disc brake caliper (2B120) and support with wire to obtain working space. Do not allow disc brake caliper to separate from the front disc brake caliper anchor plate (2B292) to prevent contamination of the disc brake guide pin journals. Do not allow disc brake caliper to hang from front brake hose (2078) . Remove front disc brake rotor (1125) . Remove front disc brake rotor from wheel hub (1104) by pulling it off the lug bolt (1107). If front disc brake rotor is difficult to remove from front wheel knuckle , strike front disc brake rotor sharply between lug bolt with a rubber or plastic hammer.
    If front disc brake rotor will not pull off, apply Rust Penetrant and Inhibitor D7AZ-19A501-AA or equivalent meeting Ford specification ESR-M99C56-A to inboard and outboard rotor/hub mating surfaces. Install 3-Jaw Puller 205-D027 (D80L-1013-A) or equivalent and remove front disc brake rotor by pulling on front disc brake rotor outside diameter and pushing on hub center. If excessive force is required for removal, check front disc brake rotor for lateral runout prior to installation. Refer to Section 06-00.
  1. Remove anti-lock brake sensor mounting bolt and front brake anti-lock sensor (2C204) .
  1. Remove and discard lower ball joint nut. Using Remover Adapter 211-211 (T96P-3010-A1), separate lower ball joint from front suspension lower arm (3078) .
  1. Using Rotunda Spring Compressor 014-00781 or equivalent, compress front coil spring (5310) until lower ball joint clears front suspension lower arm .
  1. Using Front Hub Remover/Replacer 204-069 (T81P-1104-C), Two Stud Adapter 205-237 (T86P-1104-A1), Metric Hub Remover Adapter 204-085 (T83P-1104-BH) and Front Hub Installer 204-067 (T81P-1104-A), press front wheel driveshaft joint (3B414) from wheel hub . Wire front wheel driveshaft joint to body to maintain a level position.
    Item Part Number Description 1 204-085 (T83P-1104-BH) Metric Hub Remover Adapter 2 204-067 (T81P-1104-A) Front Hub Replacer 3 — Turn Wrench Counterclockwise 4 — Hold Wrench Stationary While Turning Other Wrench 5 204-069 (T81P-1104-C) Front Hub Remover/Replacer 6 204-067 (T81P-1104-A)1 Two Stud Adapter A — Make Sure Metric Hub Remover Adapter 204-085 (T83P-1104-BH) is Fully Threaded onto 1107 and is Positioned Opposite the Two Stud Adapter 205-237 (T86P-1104-A1)
  1. Remove and discard three hub and bearing retainer bolts from front wheel knuckle .
  1. NOTE: Wheel hub is not pressed into front wheel knuckle . Do not use slide hammer to remove a stuck wheel hub . Do not strike back of inner bearing race. Use of these methods will damage bearing internal parts.
    NOTE: If bearing carrier is corroded to front wheel knuckle , apply Rust Penetrant and Inhibitor D7AZ-19A501-AA or equivalent meeting Ford specification ESR-M99C56-A to the inboard and outboard wheel hub/knuckle mating surface and allow to soak.
    Remove wheel hub from front wheel knuckle .
Installation
  1. NOTE: If wheel hub is damaged or if any end play is detectable, replace wheel hub . End play is not adjustable. If wheel hub is disassembled, the assembly must be replaced.
    Remove all foreign material from knuckle bearing bore for correct seating of new wheel hub.
  1. Lightly lubricate mating surfaces of bearing corner and front wheel knuckle.
  1. ani_caut.gif CAUTION: Knuckle bore must be clean enough to allow wheel hub to be completely seated by hand. Do not press or draw wheel hub into place.
    Position wheel hub in front wheel knuckle . Install three new hub and bearing retaining bolts. Tighten to 83-107 Nm (61-78 lb-ft).
  1. Push front wheel driveshaft joint into wheel hub . Hand start front wheel hub retainer.
  1. Slowly release Rotunda Spring Compressor 014-00781 or equivalent while guiding lower ball joint into front suspension lower arm .
  1. Install new lower ball joint nut. Tighten to 68-92 Nm (50-67 lb-ft).
  1. Install tie rod end into front wheel knuckle . Install new slotted nut and tighten to 47-63 Nm (35-46 lb-ft). If necessary advance nut to install a new cotter pin.
  1. ani_caut.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Install stabilizer bar link to front shock absorber . Install stabilizer bar link nut. Tighten to 77-103 Nm (57-75 lb-ft). For SHO vehicles, install stud cover.
  1. NOTE: Remove rust from the rotor and hub mating surfaces with a medium abrasive pad.
    Install front disc brake rotor and disc brake caliper . Tighten caliper anchor bracket bolts to 88-118 Nm (65-87 lb-ft).
  1. ani_caut.gif CAUTION: The front axle wheel hub retainer must be tightened to specification immediately during installation. If the retainer is not tightened immediately, the nylon lock will set incorrectly, leading to incorrect torque readings and bearing failure. Any front wheel hub retainer that is not immediately tightened to specification or is loosened must be removed and a new retainer installed.
    Install front axle wheel hub retainer . Tighten to 230-275 Nm (170-203 lb-ft).
  1. Install wheel and tire. Tighten lug nuts (1012) to 115-142 Nm (85-104 lb-ft).
  1. Lower vehicle.
  1. Pump brake pedal prior to moving vehicle to position brake linings.
May 28, 2009 | 1999 Ford Taurus
Front Sway bar(Stabilizer bar)
please give good rating if this helps
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise vehicle on a hoist. Refer to Section 00-02 .
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut, or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Remove and discard nuts retaining stabilizer bar link (5K484) assembly to front stabilizer bar (5482) and front shock absorber (18124) with an 8 mm closed-end wrench and an 18 mm open-end wrench.
  1. Remove nuts retaining steering gear (3504) to front sub-frame, and move steering gear off the front sub-frame.
  1. With another set of support safety stands under front sub-frame, remove two rear subframe retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar U-bracket bolts and replacestabilizer bar brackets and/or front stabilizer bar as required. Discard lower suspension arm stabilizer bar insulator (5493) and bolts.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar insulator installation position.
  1. Lubricate inside diameter of new lower suspension arm stabilizer bar insulator with Rubber Suspension Insulator Lube E25Y-19553-A or equivalent meeting Ford specification ESF-M99B112-A. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber lower suspension arm stabilizer bar insulators.
  1. Install new lower suspension arm stabilizer bar insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on front sub-frames and install new bolts. Tighten to 30-40 Nm (22-29 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Position steering gear onto front sub-frame and install retaining nuts. Tighten to 115-135 Nm (85-99 lb-ft).
    Install stabilizer bar link to front shock absorber and to front stabilizer bar, making sure that the stabilizer bar link is properly positioned. The letters "Top LH" and "Top RH" are moulded into the stabilizer bar link for correct assembly to the front shock absorber strut.
  1. Install new nuts and secure stabilizer bar link assembly to front stabilizer bar and front shock absorber. Tighten to 77-103 Nm (57-75 lb-ft) at front shock absorber strut and 47-63 Nm (35-46 lb-ft) at front stabilizer bar.
  1. Remove safety stands.
  1. Lower vehicle.
Apr 11, 2009 | 1995 Ford Taurus
Front spring and shock assembly diagram
Item Part Number Description 1 5310 Front Coil Spring 2 18124 Front Shock Absorber 3 3A130 Tie Rod End 4 1104 Wheel Hub 5 3K185 Front Wheel Knuckle 6 3078 Front Suspension Lower Arm 7 5482 Front Stabilizer Bar 8 5K484 Stabilizer Bar Link 9 N806899-S60 Bolt (4 Req'd) 10 5486 Stabilizer Bar Bracket 11 5484 Rack and Pinion Mounting Bracket Insulator (2 Req'd) (Position Slits Toward Front of Vehicle) 12 W520214-S60 Nut (2 Req'd) 13 N807144-S60 Nut (2 Req'd) 14 N803990-S60 Bolt (2 Req'd) 15 N806364-S60 Nut (2 Req'd) 16 N808466-S428 Nut (2 Req'd) 17 N808391-S100 Bolt (2 Req'd) 18 N807089-S101 Nut (2 Req'd) 19 W500746-S426 Bolt (2 Req'd) 20 W520214-S60 Nut (2 Req'd) 21 N804608-S1428 Nut (2 Req'd) 22 N804002-S100 Washer (2 Req'd) (Dished Side Up) 23 18183 Front Shock Absorber Mounting Bracket (2 Req'd) 24 3B455 Front Suspension Bearing and Seal (2 Req'd) 25 N811008-S100 Washer (2 Req'd)(Dished Side Up) 26 N803766-S60 Nut (6 Req'd) A — Install With Color Code at Bottom of Link — Green—RH Side, Red—LH Side B — Tighten to 30-40 Nm (22-29 Lb-Ft) C — Notches and Stamped "Front" Toward Front Of Vehicle D — Tighten to 47-63 Nm (35-46 Lb-Ft) E — Tighten to 77-103 Nm (57-75 Lb-Ft) F — Tighten to 98-132 Nm (72-97 Lb-Ft) G — Tighten to 68-92 Nm (50-67 Lb-Ft) H — Tighten to 53-72 Nm (39-53 Lb-Ft)
Dec 30, 2008 | 1995 Ford Taurus
Schwinn Midmoor 700c Men's Hybrid Bicycle Logo
53 people viewed this question
Top Schwinn Cycling Experts
Tony
Joseph Hoffmann
numbers819
Level 1 Expert
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
