Question about Furuno 1623 Radar 16nm Range
No heading pulse
My 2 years old furuno 1623 has a fault no heading pulse.the scanner sweep is also intermittent sometimes juddering to a halt from phoning furuno uk i get the feeling this is a well known fault anyone else had this?
Pete
  • 64 Answers
Open the dome cover and check the belt that spins the array. Sometimes the gear on the motor that holds the belt comes loose and will not spin the array. I have seen this on 4 radars and all were about the same age. The gear has a small allen head set screw. Move the gear down and tighten the screw down. If you are still having issues there are some more troubleshooting techniques you can do, but you will need a multimeter to test voltages coming from the display.
Posted on Jun 14, 2010
Testimonial: "thanks will get on to it and hopefully cure the problem"
  • 3 Answers
Got the same problem, but they tried to fix it 3 times w/o success, See here:
http://www.thehulltruth.com/marine-electronics-forum/278966-furuno-1623-no-heading-pluse.html
Posted on Jan 13, 2011
Hi my furuno radar 1623 ,is not working proper,it is showing no heading pulse where do i go to repair this problem or what do i have to do .this unit has about 700 hr thanks dale
OPEN RANDOM , START THE RADAR TX , NOW MOVING THE IN SIDE SCANNER REFLACTOR ? IF YES CHECK MAGNET FOR THIS MOVING PART OF SENSORE, NOW ME BE FOULTY, REPEIR POSSIBLE TO INDIA EMAIL : KAPERBVC@YAHOO.COM
Aug 14, 2011 | Furuno 1623 Radar 16nm Range
NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Apr 27, 2010 | Furuno 1623 Radar 16nm Range
IS THERE A EXTERNAL ANTENNA AVALIBLE . IF SO WHAT MODLES CAN I USE THANKS MODLE 1623 FURUNO .
I would assume you're talking about the radar? it's a RSB0093-074 it's just for the 1623. There are no other options. If you're referring to gps antennas then any antenna that outputs nmea can be used.
Jan 25, 2010 | Furuno 1623 Radar 16nm Range
Hi, Furuno 1731 radar - no sweep/echo seen on screen. Scanner is rotating and other display is normal.
Go to longest range and full Gain min Rain and Sea Clutter
Do you have speckle? Yes = Receive OK, Wiring OK,No transmit (magnetron or modulator) No = Most likely a broken wire
There is a very tiny coax (shielded wire) that is know to lose its' center conductor, which is very delicate
Oct 18, 2009 | Furuno 1623 Radar 16nm Range
No radar target images
Sounds like your video cable inside your radar cable. Also brings your Gain back to zero, STC back to Zero and rain back to zero. Next increase your gain until you see a picture. If none of that is working, check your cable then finally call a dealer.
Oct 15, 2009 | Furuno 1715 Radar 24nm Range
Furuno Radar 1623 and 1715
Hello.
According to the operating manuals of the two radars (found on Furuno's Website (www.furunousa.com), they do use the same antenna cable.
Hope this was helpful.
Dec 03, 2008 | Furuno Fr8062 12.1 Color Lcd 6kw 15 Meter...
Furuno 1623 Radar reading "no heading pulse"
The messages “NO HEADING PULSE” and “NO BEARING PULSE” means that the display is not communicating with the scanner (antenna). Both of these signals are generated in the scanner if you get this error check that the antenna cable is firmly connected and that the contacts are clean and corrosion free.
If the connection at the display looks good and feels like it’s properly connected, check the cable for any damage If you find damage you could try to repair the wires BUT (because of corrosion and moisture problems) IT IS STRONGLY REMENDED that the cable be replaced, but it’s kind of expensive $275.00.
The Part number is 000-130-034. Depending on the marine shops in your area they may have it in stock (or they can order one) but you can get it directly from Furuno at;
http://www.furunousa.com/Furuno/Rooms/Search/ProductPropertySearchResults?_webrFormIdentity=com.webridge.layout.FormLayoutExImpl%5BOID%5B47F81E95CB197F4C8708859EA0E22F08%5D%5D&_webrFormUniqueID=0&_webrCharacterEncoding=iso-8859-1&_webrLocale=en-us&_webrClusterUpload_2=&ptype=com.webridge.entity.Entity%5BOID%5BE670694808555649838ED263AA4CAB0A%5D%5D&productname=000-130-034&searchOption=normal&searchOption_webrHidden=radio
I hope it’s just a loose connection. Good luck!
Apr 28, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Furuno 1623 Radar 16nm Range Logo
498 people viewed this question
Top Furuno Boating Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Furuno Boating Expert? Answer questions, earn points and help others
