Question about Vacuums
Hose will spray solution - Vacuums
    Problem Solver:
  • 15 Answers
Posted on Apr 10, 2008
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Bissell big green clean machine extention hose not spraying
Hey, sorry you're having difficulty with the spray on the hose.
Here's a quick link to troubleshooting steps to assist you:
Feb 28, 2013 | Bissell Big Green Deep Cleaning Machine...
How can i remove the dust from vacum hose?
If you can take it apart and remove the hose then I would flush it with a hose with a nozzle. I would also spray the inside of the hose with an all purpose spray.
Jul 21, 2012 | Bissell Vacuums
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
How can we avoid the odor that we usually have with other vac exhausts? will cleaning the filters as suggested really keep that from happening?
Bagless vacuums have a real problem with bacterial growth. That is what produces the odor you are smelling. Wash the cup in an enzyme and the filters too if they are the washable type. Make sure everything is dry before you reassemble the vac. Then turn on the vac and pull the hose out like you would be using the tools. Holding the hose end that has the suction, spray a small burst of Lysol Spray into the hose opening so the vacuum "sucks" the Lysol through it's interior. This will kill the bacteria in the hose and the plastic housing of your vacuum. Usually 3 bursts works fine. If you spray too much and get your machine "wet" with the lysol you could damage your motor so small bursts are better than a long spraying action
Oct 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell carpet shampooer
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Can't get water to spray out of the hand tool nozzle
When you attach the main suction hose to the front of the machine, you also have to connect the soultion hose to a valve located on the side of the machine. When the machine is running, take a small screwdriver and depress the centre of this valve. You should get a spray of water out of the valve which will confirm the valve and pump is working. Now, connect the small solution hose, making sure you push it on all the way. When you pull the trigger on the handle of the hose, you should get spray. If it does not, you may have a plugged nozzle sprayer.
Feb 16, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
