Question about NRS Paslode 501000 Powermaster Plus Clipped Head Nailer
Paslode PowerMaster Plus F350S drive pin won't reset all the way back up? Any step by step instruction fix it or clean it up?
    President:
  • NRS Master
  • 1,388 Answers
Most common cause for driver not returning is a worn or missing blade seal which is a washer with a slot found under lower bumper. Remove head and cylinder. Check that driver is not bent and slides snuggly thru slot in washer. If washer seems ok then check for missing check seal oring found at lower end of cylinder. Clean the holes under check seal. Finally check oring at driver piston. Oring should just hold piston in place without sliding down cylinder. The driver should not be too tight nor too loose. Re-assemble using silicone paste on all orings (small tube of silicone available at Lowes plumbing department, used to lube faucet orings). Good luck and post again if you have other questions.
Posted on Jun 22, 2010
Why is it shooting 2 nails @ a time?
Your driver could be broken or worn down and may need to be replaced.
Mar 15, 2015 | Paslode F350s "powermaster Plus" 30...
Why is my gun bending nails?
Adjust the Work Contacting Element. See page 4 in the manual...
http://www.paslode.com/owners-manuals.html
Adjust the depth of drive.
Make sure correct fasteners are being used.
Use fasteners that meet Paslode specifications only.
Increase air flow to tool -- use larger air lines
(3/8 ID minimum).
Increase Air Pressure. DO NOT EXCEED 120 PSI.
Jul 23, 2014 | Paslode F350S PowerMaster Plus 30-Degree...
Paslode PowerMaster Plus air nailer, model F350S. Air valve in trigger appears to be stuck open. air blows all the time when air line is attached. I cleaned and blew out all interior components and air...
Part # 097746 valve pin has a rubber surface that seals when under pressure. To replace this part, remove the trigger then two roll pins in the body of the gun just above the trigger valve. Remove the valve and check for debris or faulty part, replacing as needed (verify the the orings on the outer part of trigger valve are not cut, there also should be a spring pushing down on the valve pin ). If the valve pin is worn, also check orings within the gun for wear, including the largest oring around the cylinder seal. Good luck
May 25, 2012 | Air Tools & Compressors
Paslode framer when you depress trigger there no resistance and it does not fire
Paslode framer has a lever inside of trigger that may be bent or missing. Easy to check. Remove air line and nails. Remove trigger by pulling pin. Check under trigger for missing parts. Test gun by connecting to air and place nose of gun against wood or hard rubber and then depress firing pin. If gun fires then problem is with lever under trigger or safety mechanism which is in two parts. Check safety for bent or broken piece, usually upper part will be missing lip that actually pushes on the lever. If however gun does not fire when firing pin is depressed, time for replacing orings in gun. Parts are available at www.toolpartsdirect.com . Good luck with your repair and post again if you have other questions.
Jun 30, 2010 | NRS Paslode 501000 Powermaster Plus...
I dropped my Paslode F350S framing nailer on concrete and it has a pin hole air leak in the outer casting. Where can I get a replacement outer shell? Also can a pin hole air leak be repaired? The nailer is...
You will have to take it to your nearest paslode repair agent(check for your nearest repairer on the paslode web site). It sound like you have damaged cylinder or comb. chamber. the orange casing is just that a casing to hold the internals together. The gas framing gun is just like your car motor. Fuel(gas cell),spark(spark plug), motor(piston moving up and down a cylider) and filter/air( fan to move air around evenly and filter for tool to breath)
Dec 22, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I have a Paslode framing gun. When you connect the air hose, air comes out of the rear of the gun. What would cause this issue?
There is a large diaphram inside the nailer (inside) that is out of place or damaged.
Remove the 4 screws to access the diaphram and inspect it.
Oct 24, 2009 | NRS Paslode 501000 Powermaster Plus...
CAN'T LOAD STAPLER Hava a power master stapler model apm125n but can;t re load staples as have losr instructions
You should just be able to pull the cartriage slide at the back of the loader. it sometimes sticks, give it a good yank/
Aug 08, 2009 | NRS Paslode 501000 Powermaster Plus...
Paslode air nailer fires continually when trigger is pulled
Sounds like you need a trigger repair kit. That`s around $15
Thanks,
Jeff
Apr 07, 2009 | NRS Paslode 501000 Powermaster Plus...
Paslode framing nailer won't shoot
Take 4 bolts off of head . Clean and lube head valve with air nailer oil. Not wd40
Apr 05, 2009 | NRS Paslode 501000 Powermaster Plus...
NRS Paslode 501000 Powermaster Plus Clipped Head Nailer Logo
658 people viewed this question
Top NRS Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
 Kenneth
Kenneth
Are you a NRS Air Tool and Compressor Expert? Answer questions, earn points and help others
