Question about Zanussi 18 in. DA4342 Free-standing Dishwasher
Dishwasher not fully pumping out at end of cycle ,
  • 30 Answers
Check the control timer and inlet solenoid valve
Posted on Jun 04, 2010
Doesn't fully drain after cycle completed. How do I fix it?
most likely you have a lot of debris in the pump housing. you can remove the lower arm and then the cover from the top of the pump. clean out all the debris. and try again. if it does not drain replace the drain pump.
Sep 03, 2012 | Kenmore 24 in. 17269 Built-in Dishwasher
I have an E39927 Type 776-0 dishwasher. The problem began this week, in that water does not fully drain from the dishwashwer following the end of any of the washing cycles. The unit seems to be...
disconnect the drain hose from under the sink. place it into a bucket and put the dishwasher to drain. if it drains in the bucket fine then you know you have a problem with your drain. if it doesnt drain, then the problem is most likely the drain pump
Oct 23, 2011 | Maytag Dishwasher
Water isn't flowing in through the spinners in the dishwasher.
Look at the end of the wash and no water in the bottom, it is OK. The water is pumped out through the pump. Hence you would have found the water mid way. Pump will start after the wash cycle is fully finished it's function or as per the float level!
May 31, 2010 | Viking 24 in. Professional Series VUD141...
Hello, I have a Frigidaire Dishwasher, model FDB750RCC1. It will not fully drain. There is water in the bottom of the unit after the cycle is complete. As it is not full of water or leaking out of the...
On the drain hose at the connection to the dishwasher there is a one way check valve. If debris has gotten trapped water will drain back into the dishwasher at the end of cycle
Hope this helps.
Remove the connection and clear.
Jul 01, 2017 | Frigidaire 24 in. FDB750RCC Stainless...
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Older Kitchenaid Dishwasher doesn't fully drain and smells
Hi Jay. Remove the lower front panel and you will see the drain hose. On the machine end of the drain hose is a small drain pump. Disconnect the hose and the pump and you will most likely find a partial blockage in the form of a piece of glass or something preventing a total drain.
please mark this answer as a fixya!
Mar 09, 2009 | Dishwashers
Ge dishwasher
If your GE dishwasher is between 5-10 years old, you may try replacing the check valve piston & nut assy (about $14). It's located on the inside in the rear of the dishwasher behind a screen which is fastened by about 4 screws. Once the screen is off, you can easily unscrew the check valve assy by hand ... install the new check valve assy ... reinstall the screen with the 4 screws ... and save yourself $400 for a new dishwasher.
Apparently, the rubber cone in the check valve assy deteriorates over time and prevents the pump from fully draining all the water from the bottom of the d/w at the end of a cycle.
GOOD LUCK!!
Feb 02, 2008 | Dishwashers
Zanussi 18 in. DA4342 Free-standing Dishwasher Logo
76 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
