The model is a SoundPoint IP450. The problem is
The model is a SoundPoint IP450. The problem is that the phone connection keeps dropping and when it does my computer screen also goes offline. This only happens when the phone is in use. My computer connection is stable when the phone is idle.
  • 29 Answers
Are you using this ip phone as your computers internet switch?is your internet cat-5 cable going straight into the ip phone, then another from the ip phone to the computer to supply the internet? if so whoever ran the lines for the ip phone did it wrong. the tech should have run a seperate cable for the ip phone, and plugged the other end into a 4, 8, 24 port switch. he also should have run another seperate line to your computer for your internet, and had the other end plugged into the same switch. apparently he was too lazy. the ip phone is not meant to be a switch. the person who made the ip phone figured you would use ither the internet or the phone, not both at the same time. have a seperate line run to your ip phones and you will never have this problem again.
Posted on Jun 04, 2010
Soundpoint ip 501 cannot acees via browser
Are you using config files loaded from the server? If so, make certain they are properly configured. Also, make certain the phone does not already have an alternate configuration in it that points elsewhere...
Jul 21, 2012 | Polycom SoundPoint IP 501 IP Phone
How to fix Polycom soundpoint IP 335 with surge damage
The IP 335 is an entry level phone so it is doubtful that there would be anything like a fuse in it. From what you've described here I would say the phone is fried. Moving forward I would recommend to always keep your important electronics on a good quality surge suppressor and/or a UPS. Good luck.
Jun 26, 2012 | Polycom SoundPoint IP 335 IP Phone
How much internet speed is required to run polycom soundpoint 330
For one line, you need both upstream and downstream of 90kbps for good quality.
Mar 02, 2011 | Polycom SoundPoint 330 IP Phone
What is the default password for Polycom Soundpoint IP 320 SIP?
Default Passwords:
To get into the web interface, the default username/password is "Polycom"/"456" (Note that this does not work with Safari 1.2.2.)
To get into the Admin interface on the hard phone, the password is "456". (Prior to v1.3.1, the web interfaces to the phone uses "Polycom"/"SpIp" as the username/password.)
The "user password" (not used much) defaults to "123".
To reset a lost admin password to default: at phone boot, during the 5 second countdown, push/hold 468* on the phone. Enter the phone's MAC address as the password. This will reset network info but keep peers loaded. Tested on Soundpoint IP 650.
Dec 22, 2009 | Polycom SoundPoint IP 320 SIP IP Phone
I has polycom soundpoint ip33, while booting its giving error " error loading 0004f220429c.cfg" and its not booting at all.pls guide me how to fix this problem.
Can you pls check the configuration file on the tftp server
some wrong information is there
pls compare with any other ip phone
Oct 30, 2009 | Polycom SoundPoint 330 IP Phone
"Couldn't contact DHCP" error
Check on the router if you are distributing enough IP addresses.
Jul 30, 2009 | Polycom SoundPoint
Connection Problem
I think you have to have the upgraded cable modem with the rj11 on the back in order to pull the voip dialtone. Hope this helps
May 14, 2009 | Polycom SoundPoint IP 501 IP Phone
Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Nov 11, 2008 | Polycom SoundPoint IP 501 IP Phone
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
