Question about Watches
Removing the watch stem
Hello, I was wondering just how to remove the watch stem on a quartz watch. do you need a special tool?
  • Gerald Helmke
    Gerald Helmke Apr 23, 2017
    Be careful on the advice ur getting becausit depends on the type of movement it is and that's very inportant because if u get it out it might not go back in and that can cost u serious money to take the stem out means there r other issues ur trying to address so just go to the pros and ask or Br more specific in ur online searches
Hi, it depends on the watch . Look carefully ,if there is a release button , somethin you can press on or lift up. Sometimes a needle is enough to do the job. On some quartz movements (the cheap ones) you just can't remove the stem ...
hope this will be helpfull!
K.
Posted on Apr 11, 2008
Remove back of Adee Kaye watch
If there are no slots all around, use a knife to pry case back. Make sure to use plastic pliers to remove battery to avoid possible short.
Apr 08, 2014 | Adee Kaye AK8027MB Watch
How do I remove the back of this watch?
I have seen other burberry watches and the back should pop out .
1- Locate a very small tab or recessed area on the edge of the back cover 2- Pull out the stem, which releases the back on some watches.3- Get a small flathead screwdriver it needs to be a thin inflexible tip 3- Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). 4- When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. This information is on wiki: http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools
Feb 19, 2013 | Burberry Authentic BU1321 Womans Swiss...
Hello I have two nixon men's wrist watches that
just bring your watch to Nixon watch experts. they have spare and tools to repair your watch.
Jul 14, 2011 | Watches
Ladies quartz watch stem winder knob lost lost how to remove from another to fix it?
mcdevito75 here, Best bet, look for a small watch repair shop in your area for another knob. As long as the stem is in place you just need the winding knob.
May 23, 2011 | Michael Kors MK5166womenGold Tone...
The hands have come off my fossil FS3087 wrist watch. I would like to know how to take off the glass in order to fix it myself. Thank you
mcdevito75 here, In most cases the glass (crystal) come off or out thru the back of the watch which means you"ll have to remove the quartz mechanism, and that means removeing the stem, thse quartz stems are very prone to breaking while being removed form the quatrz mechanism and the cost of a repair may be more expensive then a whole new watch, shop around get a price from a small watch repair shop on repair verses a new Fossil watch.
Feb 09, 2011 | Fossil FS3087 Wrist Watch
Hi, I found on a street market a MIYOTA T241 watch in original package, also a plastic shield on the glass. Now the problem: May be the liquid of the battery destroyed any power supply wires or contacts. I...
mcdevito75 here, Once the battery leaks it destroys the quartz mechanism. Even if you find a replacement quartz, you"d need special Jewelers tools to remove and replace the quartz, even with that you could destroy the new quartz if you can find one. Best Bet, see a small watch repair shop in your area for a quartz replacement approx. $75.00
Sep 29, 2010 | Watches
Hello, this may sound silly but I just bought a Timex Ladies watch and I can set the clock but it's not actually turning on when I push the side button in? It's a new watch direct from Timex so I...
mcdevito75 here, A brand new Timex quartz watch will come with a small piece of plastic just under the crown to keep the battery form working the watch, simply remove this small piece of plastic from under the stem (winder) push the stem in and your Timex will work. If your timex is push button you may have to hold down the Mode 2--3 seconds to see display.
Aug 02, 2010 | Timex 27191 Wristwatch
Im applying pressure in the right direction but the pin wont budge
mcdevito75 here, I'm thinking you mean the stem (winder) Make sure stem is all the way in (flat on the watch) now turn the stem a little both ways, it could be locked down, if the stem turns and doesn't seem to be locked down, simply put a fingernail just under the crown and lift to set the time. If you mean the pin or spring bar to change the band, you"ll need a special tool to remove these pins or spring bars, the tool is available on ebay called a spring bar removal tool, or you can visit a small watch repiar shop in your area.
Jun 29, 2010 | Relic 0504648FA
Removing the crown/stem of CASIO EF-321
Other case for a simple Casio quartz watch :
Jan 15, 2009 | Casio Edifice EF106D2AV Wrist Watch
Watches Logo
2,000 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
