Question about Vizio L32 32 in. LCD HDTV
Visio flat screen wont work with basic cable Why?
I recently moved and use to have TW cable box, but my new room mate has only basic cable and for some reason I connect it and put it on tv mode it use to be on 13 mode but now it says no signal found even thoe on her sony flat screen it works perfectly whats wrong?
    Scholar:
  • 121 Answers
Make absolutely sure that you've selected the right inputs and have them connected properly. Many times, even with people who know what they're doing, wires end up in the wrong places and settings can get messed up.
If it's not the wiring or setup, then it's possible that that particular input is fried or otherwise messed up.
Posted on Jun 04, 2010
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
Cant hook up dvd or super nintendo to newer visio flat screen?
The system is reasonably old and I don't think they work on newer screens, sorry
Jun 01, 2013 | Televison & Video
Intermittently my Vizio model e370va volume will rise on its own and get distorted then turn off and in a few seconds, turn on the TV. Visio tried replacing the power board. Same problem. Replaced the TV...
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Dec 06, 2010 | Vizio VU42L 42 in. LCD TV
Using cable remote when box is in another room
The IR detector of the remote will work only with a direct visual contact. hence it si important that the cable box must be located in the same room so as the remote works perfectly.
The remote might work with a deflection by it might not be a good solution.
You can move the cable box to the position of the TV so that it works well.
Nov 19, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
TW cable remote does not work after Mitsubishi LCD TV turn on
Yes, try that. It is easy to do and doesn't cost anything. You've tried new batteries in the remote as well right? There are two types of remotes, IR (Infrared light LED is used) and RF (Radio Frequency). With an IR unit I do not see any way there can be interference as long as you don't have an IR lamp around the TV and TW DVR box. On the other hand, with RF, depending on where you live and other factors, there could well be RF interference. You'll have to locate the interference and remove it. In this day and age, things such as LED and CF light bulbs DO cause RF interference. If you use these kinds of lights in the room AND you know that the remote is an RF remote then try turning all the lights off in the room and try again.
Oct 05, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Moving TV's from one room to another
tSounds like you have a PIP window open. Is everything else black excpet for that small "internet box?"
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
Pay tv cable
you may bypass the box by using a straight connector, find the cable that lead to the TV room and connect it to the cable from the aerial antenna.
Mar 06, 2008 | Televison & Video
Visio TV and Direct TV remote
I bought a 42" Visio LCD from Costco and used code 10030 and it worked. It is the code for Goldstar TV.
Nov 17, 2007 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
353 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
