Question about Casio Exilim Zoom EX-Z80 Digital Camera
Battery is not charging is it likely to be battery or charger
    Problem Solver:
  • 8 Answers
If you noticed the battery holding a charge less and less it is probably the battery...does the charger have a light? if it does and it doesnt turn on anymore it is likely the charger. Good luck!
Posted on Jul 02, 2010
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
Can i over charge my mobility scooter go go pride
Yes you can overcharge a battery, it all depends on the charger your using. Most chargers are single stage chargers. Most scooters come with a single stage charger. My scooter has a built in single stage charger What this type of charger does is output a constant 24v @ 4amps.The problem is batteries amperage requirements decrease as the battery charges. An overcharge will occur when the battery is charged. It requires very little amperage to maintain a charge on a fully charged battery. A single stage charger like mine will output 4amps regardless of the state of charge of the battery. Batteries bring charged with single stage chargers loose their electrolyte. What happens is overcharged batteries break down the electrolyte into oxygen and hydrogen. So overcharging will cause a battery to "boil-out" its electrolyte. Batteries don't work without electrolyte. In the old days there were only single stage chargers. That was the state of the art back then. So to cope with the constant overcharging batteries had refill ports where you could replenish the electrolyte using distilled water.
Scooter batteries are far and away different from the lead acid of the 1970's. Scooter batteries are sealed, they are deep cycle, they use a glass mat soaked in gelled electrolyte. These glass mat batteries optimize the electrolyte used so they can use allot less of it. These newer batteries have a lot more power in a lot smaller package but they have a draw back, they must be charged properly. You can absolutely can not charge these batteries with a single stage charger. Actually you can charge with this device but you will loosed electrolyte each time you charge.
I use a three stage charger 24v @ 5amp. This charger s different from a single stage. Its what they term a "smart charger" it monitors the state of charge of the battery. As the battery charges it turns down the amperage. When the battery is fully charged the amperage is turned low enough were the charge is maintained. The entire charging process is designed to preserve electrolyte. In short this type charger will not overcharge the battery.
Click here to see the charger i currently use.
http://www.amazon.com/Sealed-Battery-Charger-3-Stage-Fan-Cooled/dp/B0051WHAU0
Jul 30, 2012 | Health & Beauty
Problem with mobility scooter
Take the batteries down to a battery shop and have them load tested. Make absolutely sure they are DEEP CYCLE batteries. My 35a\h batteries put out 480 cranking amps. The battery shop can also test your charger. I have two chargers for my scooter the 4amp charger that came built into the chair, and a really nice three stage 5amp external charger. My scooters batteries have two 50amp quick disconnect connectors. I made up an external harness for the 5amp charger with the same connectors. I can now charge up my batteries out of the scooter. They say my built in charger is a 4amp charger, its slow in comparison to the 5amp charger. Batteries are expensive, regular chargers charge at one rate, full speed and can overcharge a battery. A three stage charger is by far way batter on your batteries. When you start to charge a depleted battery it put out full 5amps but as the battery nears being charged the charger backs off the amperage. When the battery is fully charged the charger goes into float mode and put out just enough amperage to maintain the charge. When i'm not using my scooter i keep the batteries connected to this charger. Deep cycle glass mat batteries don't stay charged very long when just sitting around. In about six months a dead battery will sulfate to the point where it will no longer take a charge. That happened to me once and cost me $200, never again will this happen to me. Battery shops are great places they have the instruments to tell you everything you need to know about the batteries. The batteries are the heart of your scooter unless you know there condition all kinds of strange things can happen. To make sure my batteries were good i have them checked against a known good set of batteries. BTW- Cranking amp is measured by putting a load on battery and increasing that load until the voltage falls off. At the point just before that voltage drop they measure the amperage output, that is you're cranking amps
Jun 22, 2012 | Electric Mobility Health & Beauty
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
The radio is not charging has new battery
Check your battery contacts on/in the radio, battery and charger. Clean with a pencil eraser if needed. If your charger will accommodate the battery alone, try charging the battery outside the radio. Does the charger's light (if any) come on and stay on when the battery/radio is attached? If so, your charger is working properly. If the light (if any) on the charger is flashing you may have a shorted or bad battery. Check your user guide to the radio/charger for more information. Finally, periodically a battery has too low of an initial factory charger to start charging on the charge immediately. Try placing the battery on the charger for 3 complete charge cycles, and see if it will then charge. If the battery is new, you might want to contact the vendor for a replacement.
Aug 22, 2009 | Yaesu Radio Communications
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Battery charge
Did you cleaning the contacts on charger, If so then go to a camera store with your battery and charger and try there battery in your charger, Then you can narrow down the problem, I think your charger is bad. TC
Dec 06, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Casio Exilim Zoom EX-Z80 Digital Camera Logo
60 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
