Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Hi, how do i get change out from under the agitator? Is there a way to get it out? Is there something down there that collects all the stuff that falls in there? Please and thank you.
  • dedeflowers2 Jun 04, 2010
    thanks but the thing does not just pop off, i kinda bent it trying to pull it off, and when i poped off the little cap on top it had a screw. Maybe if i unscrew it but then what if there is nothing supporting it?
    President:
  • 1,902 Answers
You have to pull the agitator. It is a pressed fitting, meaning that you will need to carefully pry on the bottom while pulling up on the agitator. It will pop off, then you can retrieve your items. There is not a collection can or anything like that. Please rate
Posted on Jun 04, 2010
Clothing gets caught under the agitator wings like sleeves on shirts, strings on clothing ie hooded sweatshirts.
This is something that happens with most top-load washing machines. As long as the agitator has wings, stuff will get under them. That is one reason that front-load machines are becoming more popular.
May 10, 2015 | Crosley Washing Machines
I have something stuck under the adjatator. How
Hi, depending how old you GE washer is will determine how difficult the agitator will be to remove. However, all GE made ( hotpoint, baycrest, some kenmore, moffat, mcClary, etc. ) washer's of the past 50 yrs. or so have agitator's that are pressed onto a drive block and need to be pulled off, sometime's by hand, sometimes by a greater force, i.e. "agi-tamer" or "hammer". ( of course the hammer method will require you to by a new agitator ). The "agi-tamer is a real tool which slides under the agitator and by way of being pressurized with "cold" water ( hot will burst it ) will push the agitator up off the spline/block...don't stand over it looking down or you'll potentially get "knocked out" ha ha ! Hope that help's. At least you know it does "pull off" and it isn't bolted in place. Good luck, macmarkus :)
Feb 16, 2010 | GE Washing Machines
Agitator problem
It sounds like the agitator dogs are worn (in your case they have likely broken into little pieces) and need to be replaced. Remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
This part is common among most Kenmore/ Whirlpool models. If it doesn't look like the right part, please post the model number and I will try to assist you further.
Mar 25, 2009 | Kenmore Washing Machines
Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Mar 13, 2009 | Washing Machines
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
How to remove the agitator??
remove agitator cap ,,looking down in agitator removre the plastic seal with a firm yank,,now you can see the agitator hold down nut,,remove that bolt with 1/2 inch nut driver or wrekit,,pull agitator..if clothes is jammin it down take you belt and slide under agitator,,and pull booth ends ,,but away from your fast ,may come up fast..always unplug
Oct 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kenmore Elite Calypso Washer agitator malfunction
you either have too much stuff in it or something that gets under
the agitator or it has a weak transmission
Mar 16, 2008 | Washing Machines
GE WBXR2060V1WW won't agitate...
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. You can get this from www.partselect.com. PS1517844 KIT - AGITATOR COUPLING
Cost is $7.15 plus shipping.
Jan 12, 2008 | GE WDSR2080D Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
133 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
