posted by ajk025 on Apr 09, 2008
no paper feed
3 Other Users Have The Same Problem
Comment by Guest, posted on Aug 17, 2008
Paper guide is tight, paper aligned right - not feeding into printer. It just stopped feeding. The right side seems to try and go in - but the left won't.
Comment by bar101, posted on Jul 25, 2008
My printer sounds as if it is printing but paper does not feed. When it tries to feed it jams.I don't stuff paper in and the guides are adjusted proprly.
Comment by gjmt8110, posted on May 06, 2008
ZEBRA 105SE, RIBBON GETTING STUCK ON LABELS. I lightened the print until it almost does not appear and the ribbon still sticks to the lable. Right now I can not print anything. I also tried loosing tension on ribbon.
Solution #1
posted on Apr 09, 2008
what is the printer brand and model#? also try making sure the paper is in far enough and isn't sticking, and the paper guide is tight
hope this helps
hope this helps
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP Photosmart D7160 InkJet Printer
HP OfficeJet 4215 All-In-One InkJet Printer
HP PhotoSmart C4280 Laser Printer
HP Business InkJet 2800 Printer
HP Photosmart 3210 All-In-One InkJet Printer
HP PhotoSmart C4180 All-in-One Color Ink Jet Photo Printer/Scanner/Copier, 2.4" LCD InkJet
HP LaserJet 2840 Printer
Can you Help with these Printers problems?
Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4300 InkJet
My ip4300 just sends blank... Answer This...
Repair Service
Find Printer Repairman Near You:
