Question about Sharp MX-2300N Color Copier
Needs developer Where to I order the developer for the copier
  • 47 Answers
Sharps website
Posted on Jun 04, 2010
Developer power cannot put over the Magnet roller correctly. some gabe on the magnet roller
It sounds like either you contaminated the mag roller or there is a loose connection that causes the mag roller to charge. You might have to just order a new developing unit.
Jul 09, 2014 | Toshiba 2060 Copier
We have a ricoh FW770 that keeps leaving toner on the print, we have to keep cleaning the drum in order to get a good copy
probably you need to change the drum cleaning blade. Its a long silicon rubber stripe that cleans the excessive toner from the drum surface.Also replace the developer units seals to prevent the developer and toner leak.
Hope that helps.
Mar 22, 2011 | Ricoh FW870 Black and White Copier
What is the difference between the toner and developer on this printer? The manuals we have don't give any info on installing developer, but you can purchase both toner and developer for this...
Toner provides the color, Developer consists of magnetic particles that carry the color on the outside of the developer drum, which is magnetic. Some developer is lost on each copy, although most stays in the developer unit. When you run low on developer, your image gets lighter and lighter, until the machine reports an error because it can no longer self calibrate. One change of developer suffices for many changes of toner. There is a procedure involving various actions and codes to flush the developer material out and load new developer in. This is not difficult, but there are a couple of reasons you might not want to do it if you are unsure why or if you should. First, developer for these estudio copiers, is very expensive. Second, unless you know how many copies have been made on the existing developer, you might change the developer, and fail to correct the problem. There are related service items, involving the cleaning blades, and seals, servicing charging grids, corona wire, and general cleaning of the 4 developer units and opc drums. Including dusting with zinc sterate, etc., etc. Its hard to know where to begin or where to stop. If you really want to know all about it, order a manual from any of a variety of on-line sources. Good luck
Aug 30, 2010 | Toshiba E-Studio 310c Laser Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Minolta Di 181 developer change
Minolta Di 181dont print from pc
Dec 02, 2008 | Minolta DiALTA Di181 Printer
COPIERS - AR-5316
The developer unit is inside the cartridge where the toner sits in. usually if you remove the toner hopper out of the copier and remove the top cover off you will see one compartment with toner and one with developer in it. The carrier is the the type of developer to use. All old developer needs to be removed from the machine as well as the mag roller in order to replace it.
Once it is removed the developer is placed evenly into the comparment. The hopper is reinstalled. Then a service mode is performed to calibrate the developed to make sure that the mixture is equal with the toner.
It should be done by a technician because if it isn't done properly, it will result in light copies being produced. The developer may get contaminated and have to be replace if it isn't done in the proper order.
Oct 20, 2008 | Sharp AR-5316 Advanced Digital Imager...
Dell 5100cn leaving line only on full color pages
There is more then likely damage to one of the photo developers. This is what transfers the toner to the imaging unit. The Developer frame assembly has to be totally removed in order to change one or all of the developers.
The only other posibility is that the printhead needs to be cleaned, however, in order to clean the printhead you would still need to remove the developer frame assembly to access the front of the printhead.
Sep 26, 2008 | Dell 5100cn Laser Printer
Sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Sep 16, 2008 | Office Equipment & Supplies
Adding developer
If you buy a new toner cartridge the developer is already in it.
Are you mixing ink and toner to rebuild cartridges?
If your just a user, once you replace the toner cartridge you have added new ink with the developer in it.
If you are not mixing and rebuilding the toner cartridge, and installing a new one, You do not need developer.
Apr 03, 2008 | Sharp AL 1631 Copier
Sharp MX-2300N Color Copier Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
