Question about Dakota Scout OSD (1016-08) KVM Switch
Fuel filter problem
Location in a 1987 dodge dakota v6 3.9 l engine
    Top Expert:
  • Dakota Master
  • 79,189 Answers
It is located inside the frame rail on the drivers side under the truck in a metal bracket.
Posted on Jun 04, 2010
1987 dakota 3.9 surging and bucking when you give it gas
How long since a tune-up? Any applicable trouble codes? If engine issue and not tranny, I'd check for a blockage of some kind, fuel--air--exhaust. Something of that nature. Check throttle position sensor.
Oct 10, 2016 | 1987 Dodge Dakota
Manuel fuel pump on 1987 dodge dakota will not hold preaaure
u mean mechanical pump it does not like the electric fuel pump does ur pump depends on the rotation of the engine if engine stops d pump stop too
Mar 13, 2014 | 1987 Dodge Dakota
Which End Of Of Fuel Filter Connects To Manuel Pump On 1987 Dodge Dakota 6 cyl 3.9 ?
The filter should have three hoses. There should be an arrow painted on the filter showing the direction of fuel flow.
And you should be able to blow in one end and the air come out the other if direction is correct.
The line to the pump should be on the end without the extra hose.
1987 Dodge Dakota 3.9 engine, Holley 2 barrel. Having running issues. Bought the truck cheap cause it wouldn't run. Cleaned the carburetor and installed a rebuild kit. Starts right up and idles great....
Yes, the floats may be causing the fuel level in the carb. to be too high. The black plugs indicate running too rich. Clean the plugs and check the fuel level.
Sep 09, 2013 | 1987 Dodge Dakota
Where here 1997 dodge dakota fuel filter locate
On the 3.9L engine the fuel filter is located at the following location:
Under vehicle, center, below seating area, mounted ontop of fuel tank, in fuel pump module
If this is the wrong size engine let me know. Or, go to autozone.com and input your vehicle and look up the location.
Oct 09, 2010 | 1997 Dodge Dakota
Where is the fuel filter for a 1987 Dodge dakota and the fuel pump.
The fuel filter is under the hood, center, upper engine area, above intake assembly, mounted in fuel line.
The fuel pump should be in the tank or on top of the tank. Trace your fuel line back once you find your filter and you will find it.
Apr 08, 2010 | 1987 Dodge Dakota
Fuel pump location on 87 Dodge Dakota 3.9 V-6
Should be throttle body injected,if so in the gas tank. If it's carburated it's on the passenger side of the engine about mid-way down the front on the block,under the alternator.
Jun 27, 2009 | 1987 Dodge Dakota
Bad gas mileage l987 dodge dakota
new gas cap air up tires new air filter
Nov 29, 2008 | 1987 Dodge Dakota
1987 Dakota plugs
Check your 02 sensors and be sure that the air filter is clean. You also may be having trouble with the fuel pressure regulator.
Aug 25, 2008 | 1987 Dodge Dakota
Dakota Scout OSD (1016-08) KVM Switch Logo
203 people viewed this question
Top Dakota Computers & Internet Experts
David Payne
David Payne
Are you a Dakota Computer and Internet Expert? Answer questions, earn points and help others
