Question about Kitchen Ranges
We are installing a water softener system to our entire house. We have two water heaters in the attic and a detached garage. We have a long driveway and the main water inlet comes in on a wall behind our kitchen sink along that driveway. Our question is where do we set up the water softener? In the attic or garage? We've heard garage, but the inlet is not in there at all. If we do the attic, how do we install it to cover both water heaters? Will the cold water be covered too? Any advice is welcomed. Thank you.
  • 229 Answers
Hi I don't know where you live, but it sounds like you don't have a basement. If that is the case do you get below 32F or 0C out side?
You need to put the softener in a place that doesn't freeze and that is accessable to put your softener salt.
Sound like I would do some piping to bring the water from the inlet to a spot (shed out side or to your garage). I don't know the lenth of pipe that you need to run but that would be a part of my calculation.
Thanks
Posted on Jun 04, 2010
  • tgpettit Jun 04, 2010
    We don't have a basement. It can occasionally get below freezing-- not too often. We have a two story house. As I mentioned the water heaters are in the attic.
    That's a good idea running the pipe. So, I guess you're saying run the pipe from the main inlet which is along the long driveway to the detached garage and install the system in there?
    I guess then the water comes in from the main inlet filters through the pipe and system then flows back into the house-- is that the concept?
    Thank you for your help!
Had three 50-gal American Standard water heaters installed Dec. 2009 Two upstairs in attic, one downstairs at ground level. Attic location used because heaters being replaced were up there. Upstairs...
Plumber is right.
Problem is not amount of air in attic. Problem is how hot the air is.
Oxygen molecules separate apart in very hot air and pilot light goes out since there is not enough oxygen density to support combustion.
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
More ventilation is needed.
Plumber is not ventilating expert, and not responsible for attic ventilation that builder failed to install. Plumber should do a survey of location before installation to make sure gasoline vapors are not stored nearby, but summer attic ventilation is gray area until more general-public folks become aware of problem. Hotter summers temperatures will spread that information.
Hire local home center to install roof vents AND soffit vents.
Note: You also need soffit vents.
Remember a vent on the roof is like sucking air out of a coke bottle. The roof vent is no good unless air can also enter the attic from another vent located in the soffit.
Another solution is electric water heater for very hot locations.
Or install solar-assisted water heater.
http://www.hotwater.com/products/residential/cirrex_solar.html
Jul 28, 2011 | American Standard 40 G Natural Gas Water...
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Nov 16, 2010 | GE Security Simon 3 Wireless Home Security...
I have culligan house water softner. after i changed my hot water heater my softner stopped working. I dont have a manual to check. any suggestions?
Unless the softener was bypassed when the water heater went in, installing a water heater has no bearing on the softener working or not. Is it unplugged?
RJ
Aug 27, 2010 | Culligan 34" Whole House Water Filter...
We have a gas water heater but no hot water. What happened? Our house was built in 1994. Don't know the make - It's in the attic. Do we need to replace the thing? Is it safe? Thanks
gas appliances in the attic are never safe.
a water heaters life is 7 to 10 years. if maintained, lifespan can be a lot longer.
would need to know what brand, and model number to help repair, but most likely the thermocouple needs to be replaced.
I would actually relocate out of your attic. the only water heaters I install in attics are electric.
Jun 25, 2010 | General Electric GE SmartWater Household...
We are trying to install a water softener system for the entire house. We have two water heaters in the attic. Where is the best place to install the water softener system? Is it o.k. to install it with...
My brother had a system installed a few years ago, and he had it installed in his garage, which worked out well. You want to have it installed somewhere where there is easy access, if possible, since you will have to add chemicals occasionally. He only has one water heater, but there is no reason you cannot install it with two heaters- all you need to do is make sure the water softener device goes between the main inlet line and the lines to the water heaters and rest of the house, of course. This is about all I can say, without knowing more about the house layout, but hope it helps, and good luck- they can really be a blessing in certain areas of the country, and will make a big difference in the quality of the water, for drinking as well as everything else.
Jun 02, 2010 | Kitchen Ranges
How do you remove a heater core from a 2000 GMC JImmy
2000 GMC Jimmy heater core replacement in order to replace a heater core in a 2000 gmc jimmy the coolant must be completely drained and the entire dash including radio, vents and panel covers must be removed. four screws hold the top portion(closest to the windshield) in place. they can be found under the windshield defrost vent. after the entire dash is removed a safety harness under the steering column must be removed and the steering column must be dropped to the driver seat. the heater core housing(black plastic) is located right center of the dash and is a two part housing one piece on top of the other. the housing is attached to the fire wall and must detached before replacement can continue. after detaching the housing from the fire wall separate the housing by unscrewing the six screws that hold it together. the heater core is now exposed. disconnect the heater core from the two hoses and discard. installation is the uninstall process in reverse. it is a very long and drawn out process that is not accomplished in just an hour or two . make sure you have most of the day or several afternoons to finish . Good luck and take pictures with your cell phone to use as reference.
Nov 27, 2009 | 2000 GMC Jimmy
Got heater core need to put it in,want to now how to do it the right and fastest way
In order to replace a heater core in a 1998 gmc jimmy the coolant must be completely drained and the entire dash including radio, vents and panel covers must be removed. four screws hold the top portion(closest to the windsheild) in place. they can be found under the windshield defrost vent. after the entire dash is removed a safety harness under the steering column must be removed and the steering column must be dropped to the driver seat. The heater core housing(black plastic) is located right center of the dash and is a two part housing one piece on top of the other. the housing is attached to the fire wall and must detached before replacement can continue. after detaching the housing from the fire wall separate the housing by unscrewing the six screws that hold it together. the heater core is now exposed. disconnect the heater core from the two hoses and discard. installation is the un installation process in reverse.
Good luck, it is a very long and drawn out process that is not accomplished in just an hour or two . make sure you have most of the day or several afternoons to finish . i started this and it took me 2 afternoons to take apart and put back together
May 29, 2009 | 1998 GMC Jimmy
Is an oil burner efficient for a detached 2 car garage w 1 BR apt
the best oil burner to use would be of the condensing combination type as this would be abt 96%efficient and only heat water as you needed it probably saving you abt 30% on your oil bill
Nov 12, 2008 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
