Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Fi keeps beeping yet control still operates everything normally on my ge xl44 gas range model JGBP26GEN..it started last nite. Ive tried resetting the circuit breaker and pressing the keys in many combinations. Ive tried the oven broiler and self cleaning functions which all work as well as does the cancel button. Called GE service but they need 100.00 to look at it and to order a control panel will cost 300.00.
  • 619 Answers
The F1 code can be 1 of 2 things. Try disconnecting the ribbon cable from the touch pad to the clock. Then reconnect power and if the code comes back with 32 seconds the eoc is bad. If it doesn't the touch pad is bad.
Posted on Jun 04, 2010
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Ge xl44 range has an f8 error code and keeps beeping.
Component failure within Electronic Range Control (ERC) effecting temp processing circuits. Replace the ERC. Here is that part to order.
Jun 03, 2013 | Kitchen Ranges
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE XL44 Gas Range just started beeping and has F-1 on the screen. How do I get it to stop beeping?
Hi ......A f1 code indicate a stuck or faulty touch pad or button?Sometimes moisture or a spill will cause this problem,Unplug 12 -24 hrs and reset.If this does not cure your problem turn off power unplug touch pad from control board and turn back on. F1 still there? If yes replace control board if not replace touch pad.If components are not separate electronic control will have to be replace, Hope this helps .Please rate my answer/response :)
Dec 13, 2009 | GE JGBP24 Gas Kitchen Range
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE XL44 Gas Range JGBC15GER2. Can't see clock on stove; very dim. Do I need to replace the clock/timer?
yes it is called a electronic oven control go to ap wagner.com and enter the model number and you can get priceing
Oct 18, 2009 | Whirlpool GR460 Electric Kitchen Range
GE Profile XL44 beeps erratically!
You have a bad key pad. The main control (ERC) thinks you are pressing a button. It is possible (although remotely) that the ERC may be bad instead... I give it 95% chance bad keypad and 5% chance bad ERC
Nov 28, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
JGBP79 GE Spectra XL44
Yes I had the same problem on my JGBBP79. Change the lower igniter. About $75. Keep the range for a few more years and get rid of it. The next problem you'll mostly likely have is the touch pad F1 error. That stupid thing is +$300 and nothing more than a membrane touch pad attached to some glass. :-(
Nov 08, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
403 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
