Question about Kenmore 24642 Top Load Washer
Won't fill, no cycling noises
Out of the blue, my washer won't fill. If I advance the cycle knob to another part of the cycle, there is no response or noise at all, even in the spin cycle. This machine is 4 years old and has no warranty. Sears wants to charge me $140 to look at it. Not sure if I should go ahead with that, try to fix it myself, or look for another washer. Can you give me any direction??
  • 327 Answers
Hello, try to see if there's a good water volume coming through the hoses attached to the washing machine.If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to). If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Thanks
Posted on Jun 04, 2010
Testimonial: "Thank you for your help. I'm embarrassed to tell you the diagnosis made by the repair man...it was the power source at the house. No blown fuse, but the outlet is dead. Bummer is I still had to pay for the repair man's visit. :( "
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
    Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
    Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
    Whirlpool Washer will not progress to the rince cycle.
    that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
    I quote from : The cycle doesn't advance
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washer won't advance from cycle to cycle
    * It's the timer, if your washing machine fills with water and begins agitating, but the timer never
    the timer.
    * It may be a cold-water supply problem, if the washing machine fills with water, agitates,
    Nov 16, 2008 | Danby DDW1805W Designer Series...
    Won,t drain on rinse cycle
    Ok mc we need a timer at this point. You see the timer doing several steps different than before.
    Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Ammana nav8805e
    If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
    Sep 02, 2008 | Amana NAV5800A Top Load Washer
    There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
    Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
    Kenmore 24642 Top Load Washer Logo
    46 people viewed this question
    Sal DeAngelo
    fordexpert
     Brian Main
    Brian Main
