Question about Cell Phones
Samsung F480i I stupidly typed in the master reset code into my phone while messing about. I have lost all my info and pics etc. I desperately need to recover these. I have tried recovery programmes, but they don't recognise the phone as a drive and hence cannot access it. I have also tried BitPim, but that doesn't read my phone properly, doesn't even recognise what is currently on the phone. Can you help me with another option, or show me how to allow my PC to recognise my phone as a drive. regards Chris
  • 4 more comments
  • cv72 Jun 04, 2010
    Hi
    Your colleagues have heled quite a bit, but I was hoping you could assist me with some more info.
    Cheers
    Chris
  • cv72 Jun 05, 2010
    Hi
    Please see previous thread... Any further suggestions?
    Cheers
    Chris
  • cv72 Jun 05, 2010
    Hi I think the last expert misunderstood my problem, can you help?
    Cheers
  • cv72 Jun 08, 2010
    Please assist, your colleagues have made some valuable suggestions, but it hasn't quite gotten where I need to be yet.
    Regards
    chris
  • cv72 Jun 08, 2010
    Hi please help.
    Please read message thread as it explains all of my problems.
    I would like to bypass the Samsung softwareon the phone itself so that I can read it as a drive and then try and recover lost data.
    I have replaced the phone with a new and and am willing to sacrifice this phone in order to get the data back...
    Suggestions?
  • cv72 Jun 08, 2010
    Hi
    Please looking for creative solutions.
    Cheers
    Guru:
  • 1,049 Answers
If you have stored the data on the phones internal memory, you have absolutely no options. This memory is volatile and dependent on the phones power to be maintained; as a result, rather than wiping the data's index, like on a PC; the phone cycles the entire data pool on a master reset and actually rewrites everything in memory to zero.
However, if you have an SD card or Mico-SD card installed and the data was stored there, you have several options. You simply need an SD card reader or Micro-SD Card adapter to view the media and not the device as a drive, then you can do the usual deleted PC file recovery steps.
As an added note, I recommend to all my users for multiple reasons (including this one) that they always purchase and install an SD card on their smart phones. Not only will it make recovery easier, in many cases it makes the smart phone work more like a computer - having a physical drive and working memory. Without this media, the phone operates purely using RAM and as a result, your memory for applications will decrease as you install new programs and store more data.
Posted on Jun 08, 2010
  • cv72 Jun 08, 2010
    Hi
    So you are saying that even if were to get my pc to read my phone as a drive and ran recovery software, it still wouldn't help?
    oh ****.
    Thanks for all your help!
  • NA NA
    NA NA Jun 08, 2010
    Yep...If you do not have an SD card installed or maybe one of the very old smart phones, I'm afraid so. Only the firmware is hard written to the device.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
There is no solution for this, phone data is stored in nvm memory, when you enter an reset code like *2767*3855# or *2767*2878# it will hard format the NVM and set it back to factory default.. so there is no way to get back your old info from the phone..
I'm sorry..
    President:
  • 1,469 Answers
Hello, problem can be solved. First trying to restore back data when has been master reset ted, am sorry not possible to recover and restore any file back, except the files that came with the phone when been bought new.
Secondly,how to make your PC recognize your phone.
Things to have:
Data cable for connection and Samsung installation software (that comes with the phone when bought new).
Install the software and connect the cable after installation, i think your PC will recognize the phone now. You can try that out.
Take care.
  • 713 Answers
Hi,here is a detailed solution on how to connect phone to the pc via usb,which allows your phone to be recognized as a drive,
1.Locate the mini-USB port on your phone. This is usually found on the left or right side of the phone, so look there before checking the top or bottom.
2.Use a standard size mini-USB to connect the phone to the computer. Plug the end of the small cord into the phone's mini-USB port and then plug the big end into a standard-size USB port on your computer.
3.Install drivers. Once your phone is connected physically, an software link must also be made. Your computer will not automatically recognize your phone, and a window will pop up asking if you want to install some drivers. Click the "yes" or "OK" button to continue.
4.A status window will pop up once your OS has found suitable drivers. Once the status window fills up, your computer will be ready to interact with your phone. The phone should now be charging. Check the phone screen to make sure.
5.Install any relevant software. Branded smartphones from Palm, BlackBerry,samsung and Motorolla all have specific software that comes bundled with the phones. Once the software is installed, you can launch it and interact further with your phone.
Thanks and take care
Posted on Jun 05, 2010
  • 2 more comments
  • cv72 Jun 05, 2010
    Hi
    Thanks for that. I have been able to do all that, but unfortunately the phone reads as seen above. It hasn't been issued a drive letter and can therefore not be picked up by data recovery programmes.
    How can I change the way the pc reads the phone?
    Regards
    Chris
  • cv72 Jun 05, 2010
    Hi
    Thaks for that. I have been able to install everything as descibed, but the phone doesn't read as a drive in that it hasn't been issued a drive letter. It does show as a seperate folder. Please see below.
    Because it doesn't have a drive letter the data recovery programmes cannot read the phone. How can I allow the phone to be read as a drive?
    thanks
    chris
  • cv72 Jun 05, 2010
    Hi
    Thaks for that. I have been able to install everything as descibed, but the phone doesn't read as a drive in that it hasn't been issued a drive letter. It does show as a seperate folder. Please see above.
    thanks
    chris
  • cv72 Jun 05, 2010
    Hi
    thanks
    chris
    Genius:
  • 1,416 Answers
there are two ways of solving this problem which are follow
sansung phones has only one unlocking code which is *2767*2878# punch in this code in your phone then the problem is solve only if you have not change the master reset code but
if you have done than you will have to contact your service you will be ask just two questions 1).your phone number. 2).and your phone imei serial number which you fine at the back of your phone put off the phone ,remove the battery and see the imei serial number (you can write it out ) then you will directed on how to go about it .
please do't give out the imei serial number apart fro then service provider .
Good lock and thanks for using fixya.
  • Oloyede Monsuru Jun 08, 2010
    hello,
    chris have you apply the information giving to you before now ?
    is seam you have not been able to get what am saying if the explanation could
    not solve your phone problem then the next thing to do is to flash up your phone
    with a software you can do this in your area locate your self a very good phone
    work shop around you because the soft ware is has to do with computer with the
    code giving to you earlier then your phone will be able to respond to your command
    thank you once again and good lock.
    Genius:
  • 1,040 Answers
Dear Friend,
It is very hard to recover lost files. But still if those file are stored on memory card then you can take help of card reader while running data recovery software.... but to be frank, data recovery software does not guarantee 100% data recovery....
Posted on Jun 04, 2010
  • 881 Answers
You're saying you tried all recovery programs. have you tried Samsung's RC Studio?
Your photos are not saved on the memory card? Because as far as i know, resetting the phone will not erase anything from the memory card (external memory) which normally contains your photos, videos and music.
You can actually take the external memory card out, and use a card reader to connect that to a computer.
  • 2 more comments
  • cv72 Jun 04, 2010
    Hi
    Thanks for that.
    I hadn't purchased a memory card yet, so all the info was stored on the internal memory.
    I will try Samsung RC and see what happens.
    Do you have any other suggestions if that doesn't work?
    Cheers
  • cv72 Jun 04, 2010
    Did you mean Samsung PC Studio? Can't seem to find anything about RC Studio.
    PC studio is already installed and working properly.
  • kid_ant
    kid_ant Jun 04, 2010
    sorry, YES, its PC studio, not RC..
  • kid_ant
    Oh, you don't have an external memory. Boy, that's a fatal decision.. to master reset without external backup. I'm not sure if you can recover those data but you can try this:
    Try connecting your phone on a Mac (Apple computer) using your phone's USB cable. Coz, almost everything i plug in my Mac was recognize as a drive. If you don't know anybody who has a Mac, try going to Apple Store, they have sample units there, free to use, but be sure to ask somebody that you'll be trying it out with your phone. Make this as your excuse: "I just want to see my photos from your computer"
    Again, I'm not sure if that will work, ok.
    It's a desperate move, but at least you tried everything. It'll be better if you know someone who has a Mac.
Plz send the master reset code & reset code of samsung gt c3303
i think the code is 2552 but i am not sure this code is worked on sgh f480 and sgh f480i and sgh f490 thanks
Jun 30, 2011 | Samsung Cell Phones
How do i resest my samsung SGH f480i if i dont know the phone lock password
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or
000000
type *#06# on your phone to get it.
hard reset *2767*3855# All Samsung Hard
Reset Codes In those steps: 1.)
*2767*3855# 2.)
*7465625*638*00000000*00000000# 3.)
#7465625*638*00000000#
Mar 25, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
My samsung sgh-f480i is cannot be open, always keep on restarting and cannot access on my pc, what is the possible solution for this kind of problem, is there anyone can help me? thank you and god bless
Do a Samsung Master Reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter *2767*3855# from the standby screen. (You may need to remove the SIM before it will allow you to type the code in)
Jan 03, 2011 | Samsung Cell Phones
Sir,i lost my samsung star 3g S5603(mobile phone) password. i want to reset my password.what should i do?plz help me.......
Do a Samsung b3310 Master Reset:
Dec 24, 2010 | Samsung Cell Phones
Unlock code for samsung sgh-f480i mobile phone
Default 6 Digit Security code: 123456 or 000000
hard reset *2767*3855# All Samsung Hard Reset Codes In those steps: 1.)*2767*3855# 2.)*7465625*638*00000000*00000000# 3.)#7465625*638*00000000# Now your phone is unlock forever Permanent
Jul 12, 2010 | Samsung Cell Phones
Restart problam
Master reset code for u600 type in as if making a call
*2767*3855# this will delete all pics music etc
May 23, 2010 | Samsung SGH-U600 Cellular Phone
I got a phone and i put in a password to lock the phone well i lost the phone then i found it but i don't know what the master reset code is its a samsung jack
You can get the Master reset code from your service provider. Usually a defauly code like 1111 or 0000 but could be something else if it has not been manually change. If it is not default code then only the manufactuer may be able to unlock phone. Be advised with entering in a Master reset you are wiping out all the info on the phone including pics and numbers stored in phone.
Apr 13, 2010 | Samsung Jack Cell Phone
To reset phone settings for samsung sgh u600
As if you were going to make a call
type in *2767*3855#
this is Master reset code and will delete all files
so try and back up your numbers pics etc.
Mar 04, 2010 | Samsung SGH-U600
To deblock samsung U600 password
*2767*3855# this will reset to factory settings all pictures music etc will be lost
Apr 21, 2009 | Samsung SGH-U600 Cellular Phone
Cant unlock my phone
If you know your original lock code, take it in to your service provider, each code is diffrent and can only be programed manually, if you dont know your original lock code you will have to sacrific all info pics,mess,numbers, etc. by a reset... I can guide you through the steps to erase all if you lost your Unlock code, or switch back to nam1 if you know your lock code, ( when you switch back, if security is on automatic lock, password is required) intial programing code is not your Unlock code.
Apr 03, 2008 | Samsung SPH-M500 Cellular Phone
Cell Phones Logo
73 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
