Question about Sony WEGA KZ-32TS1 32 in. Television
KZ-32TS1e cracked speaker grill.
The speaker grill on the front of my KZ-32TS1e is cracked and I want to know if I can source a new one.
    Scholar:
  • 121 Answers
If you can find a junker, you could rip one out of it. Try asking local repair shops if they have any dead units that they're just going to pitch. You should also figure out the dimensions of the grill, in case you have to find an improvised one from another set.
Posted on Jun 04, 2010
Boston acoustics repair
How did debris get into your speaker?
You might try taking the woofer out by unscrewing all the screws that are holding it in from the front.
As for the grill repair? Are you handy with a hot glue gun and stapler?
Try stretching the fabric over the speaker frame and securing it with hot glue and/or staples. If you use a stapler, get one that fires flat staples not the rounded ones.
If the fabric is torn, find speaker fabric that is "acoustically transparent" commonly available from many sources in many fashionable colors.
you will have to remove the existing speaker fabric without damaging the frame. Scrape off any adhesive residue and remove any and all staples install your fabric by stretching and gluing/stapling the new fabric over the frame.
good luck.
May 26, 2014 | Audio Players & Recorders
How do u hook up a set of 4"x 6" HD Scosche speakers in a 1993 GMC Suburban
i`ve got the the same truck,,pry up the corners of the dash grilles,carefully so not to crack them,usually the clips tend to break off,so grab some epoxy from hardware store first(gonna need it).Remove 4 7mm bolts and pull spkr out,,cut wires and strip,,,left side will have gray and tan,gray is positive,,right side will have light green and dark green,light green is positive(GM wiring is lights in the front,darks in the rear).Using connecters attach new spkr pigtails connect spkrs and re-install into dash. Using epoxy replace clips on grilles waiting for epoxy to set,,carefully replace grilles and your done. GOOD LUCK
Jan 24, 2013 | Car Audio & Video
How do I disassemble Sony SS-RG440 Speakers to fix a rattle?
If your Sony speakers are in sealed cabinets, the only way to get access inside is through the front by removing the grille and the speakers..BUT before removing the speakers check whether the speaker(s) themselves are the source of the rattle
Dec 26, 2012 | Audio Players & Recorders
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
I have a Jenn-Air model #720-0061-LT gas grill. All three burners cracked and I have received replacements but can not get their Tech. Support people on the phone to get installation instructions. Greg
How did you get your replacement burners, they are covered under the lifetime warranty.
They are east to replace, simply lift out of guide hole in back of grill slide off of the gas source. Then slide new burner on gas source and position back into guide hole.
Jun 11, 2009 | Jenn-Air Grilling
How do I remove the cloth grill cover from the front of speaker?
Some speaker manufacturers design their boxes with non-removable front grills. Be thankful that you can remove the back because I've seen these sealed as well. Once inside, the speakers should be mounted from the inside (mounting screws on inside) compared to front mounted. IF they are not then either you're not using the proper method to remove the grill OR it's glued in place and will require breaking the glue bond to release the grill. One note to remember...non-removable grills can mean the manufacturer has something to hide.
Mar 22, 2009 | Philips Audio Players & Recorders
Front doors pre wired for speakers?
on most models, Yes. pull off the grills and check for wires , be careful though , they break easy
Dec 06, 2008 | 1991 Volvo 740
Stress crack
What is the milage on your Ridgeline? If it has some miles on it, remember, it's a truck. It rides somewhat rough over the rough roads, andd this is going to generate more rattles that a sedan with soft suspension.
My 2006 with 16,000 miles has developed it's first rattle (except see below) somewhere on the right passenger side. Overall I'm happy with it.
Ridgelines, at least those of my model, are known to have a bad rattle from the small radio speaker grills in the dash top. This can be easily checked by just reaching up and holding the grill as you drive. If the rattle stops, this where is't coming from. It can also easily be fixed. Push the grill toward the front and pull the rear edge up. The grill, with the speaker attached, comes out. Put some kind of padding around the small clips on all 4 corners. The design has made these fit too loosely in their opening, and the grill/speaker will rattle. I used the small round fabric and adhesive backed pads sold to put on vases, etc to stop scratches on furniture. I cut one of these in half and put a piece on each of the clips and put the speaker back in. Stopped this rattle.
May 14, 2008 | 2006 Honda Ridgeline
Need to replace screen
the screen on my toshiba tp50g50 is cracked. where can I get a replacement screen?
Nov 29, 2007 | Toshiba TP50G50 50" Rear Projection...
Sony WEGA KZ-32TS1 32 in. Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
