TV WONT TURN ON
My tv is on child lock and wont turn on can u help me? I also have a universal remote instead of the magnavox original remote will that work?
  • aedanie Aug 22, 2008
    Have a Phillips Magnavox TV and it is on child lock. The TV is 2nd hand and has no manual - but I do have the remote. How do I turn the TV on?
    Problem Solver:
  • 7 Answers
Well the universal remote will need to have the ability to gain access to the menu so you can go and change the settings for the "v-chip" or what ever the child lock is that you speak of. I hope you know what the password is or it may be "locked" for a very very long time. I say this about the password because usually this control is password protected. Yours may not be but,.... Good luck. What you seek is in the menu sequences somewhere. Start pushin buttons!
Posted on Apr 09, 2008
27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
Did you try disconnecting the TV overnight to reset it?
Feb 09, 2008 | Philips Magnavox 27MS343S 27" TV
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
How can i turn on my tv which has child lock on with no remote?????
If you purchase a universal remote that can work with the philips magnavox, test and go through each codes until the tv comes on in which case you can navigate to the MENU, SET, and then CHILD LOCK to turn the feature off. With the tv plugged in, it can still receive signals from the universal remote and once you get the right code, it should be able to turn on.
You can even return the remote afterwards if you really dont want it. =]
Mar 12, 2011 | Philips Magnavox 27MS343S 27" TV
I have a magnavox 27MS343S and it is child locked, tv is off and do not have the original remote! What can be done?
I have a magnavox 27MS343S and it is child locked, tv is off and do not have the original remote and it wont turn on although the powered up red lighht is on. Tv has been reset to sleep mode by universal remote. What can be done?
Feb 01, 2011 | Philips Magnavox 27MS343S 27" TV
Unable to turn magnavox TV on. Child lockout is on and unable to turn on TV. Do not have original Magnavox remote. I do have a Universal RCA Remote. Can you give me the code for my RCA Universal...
What brand is your universal remote? Best thing would be to go on the universal remote manufactures website and they should have a list of codes for models based on what model number your universal remote is. Then you can look up possible codes for your tv found in the users manual (which you can print from online) and it gives you like 5-7 codes that you try and will give you instructions on how to enter the code and save that code to your remote. I hope that helps.
Aug 16, 2009 | Philips Magnavox 27MS343S 27" TV
Child lock on and tv wont turn on no remote
OMG it worked my tv was locked on child safety for 1 month you have to get any universal remote and try all the codes mine was 0224
Jul 24, 2009 | Philips Magnavox 27MS343S 27" TV
Need to program a universal remote but cant turn on tv
take ur tv to a local tv repairman, they will have a magnavox remote. use it and simultaneously press tv/av and enter
Dec 14, 2008 | Philips Magnavox 27MS343S 27" TV
Child lock
you will need your original remote control and go through the menu to unlock it. find your original remote control by typing in your TV model number in the search on www.replacementremotes.com and your original remote will pop right up. very easy to use.
May 31, 2008 | Philips Magnavox Learning Universal Remote
On those particular Magnavox TV's you have to use the original type of remote to power it back on then un-lock the parental lock. It is a bummer that nothing else will work. Here is a link to purchase a replacement remote.. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod
Feb 06, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
