Question about Acer AL1715 17" LCD Monitor
Vertical lines in the monitor
I have at least 10 acer monitors that have vertical lines through the screen
  • 11,361 Answers
Vertical lines from the top to the bottom of the screen are due to failing T-CON board (part of the LCD panel assembly). You can try reseating the ribbon cable attached to the T-CON board, otherwise new screen will be needed, these failures are due to cheaply made screen by company such as Chi Mei. It willget worst with more lines.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Posted on Jun 04, 2010
  • John D Aug 10, 2013
    Not really the answer - the monitor is OK with another computer
I had a acer lcd monitor al1716 that has a vertical lines in a block running across the screen with horizontal lines inside
If you have tried a different monitor and still get the vertical lines the problem lies either with your cable or graphics card or motherboard (if you don't have a graphics card).
If you are running a graphics card take it out and put it back in and check if it still shows you the lines, if so remove it and try using the on board graphics from the motherboard. 'f the problem disappears its the graphics card if not its the motherboard.
May 26, 2015 | Acer AL1716 17" LCD Monitor
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
Display vertical line
Turn off the monitor and disconnect it from the back of the pc. This way you will isolate the monitor from the PC. Now turn on the monitor, if you still see the vertical line then that means the screen is bad and you would need a new monitor.
If the monitor doesn't have the vertical line then that means your video card is the issue or if you have an integrated vga port on the back of the computer then the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Acer V173 Monitor
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
Lto much colors vertical lines
hi
if your getting vertical lines in you screen it means you have problem with screen you have to go to services center
this is display issue
Oct 12, 2010 | Acer AL1912 19" LCD Monitor
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
The screen is like a ghost -- plus there are lines coming down vertical???? I tried restoring the system... no luck-- the monitor is a acer 203 only 2 months old... I paid cash at best buy-- lost my...
vertical lines on a screen means the screen itself is bad. If you can find your receipt, return that monitor to Best Buy cause there is no way to resolve it except to replace the screen and that costs as much as buying a new monitor.
Aug 11, 2009 | Computers & Internet
Vertical Lines in Monitor
This is usually a screen problem and cannot be fixed however to verify if this is from the screen or from the video card you can connect a normal monitor to the back output connector of your laptop and check the display on the external screen.
This will tell you if it is the video card on the board or the actual screen. In either case it would be a hardware issue.
Sep 20, 2008 | Acer TravelMate 2300 Notebook
Thin red vertical line length of screen(right side)
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 20, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 17" LCD Monitor Logo
1,218 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
