Question about Electrolux 37 in. Designer Series E36IC75FSS Electric Cooktop
What does the 'E73' error mean for Electrolux ICON 36" Induction Cooktop E36IC75FSS? I bought a demo model on eBay, and it does not work.
  • 516 Answers
1. Make sure that you have placed a metal container on the device which is compatible with the Induction cooker. 2. Try reseting the breaker, the instruction are available in the user manual.
Try these. I will be there to help you!
Posted on Jun 04, 2010
  • ortenberg_m Jun 04, 2010
    Tried both resetting power (and switching breaker on/off), and making sure an appropriate pot was on the cooktop. This is a new install. Was able to boil a pot of water successfully, then fried an egg on a different pan. Then the E73 came up. It has been there for 2 days. I have moved/replaced pot/pan that worked at first. Whether or not there is a pot/pan on any of the burners, the E73 comes up, followed by 8's.
    I even switched to another circuit, to verify that the wiring was correct. Using 50-amp circuit in both cases. E73 comes up every time.
Power went out. reset circuit breaker and all the lights keep flashing 8.8 and won't stop
Hello Heidi, thank you for your post!
From my understanding your Electrolux cooktop is displaying an error code of 8.8. The error code of 8.8 means there is a shift register issue on the middle touch board. This could a possible issue with the control board or the middle touch board. You may need to have a professional technician out to your home for proper diagnosis. We hope this information is helpful to your repair. -Matt
Jan 23, 2016 | Electrolux 36"" Induction Cooktop
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
Electrolux Induction Cooktop E36IC75FSS Error Code 41
Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
Aug 27, 2012 | Electrolux 37 in. Designer Series...
Error 11 Electrolux induction cooktop
You will need to consult a professional to have the following repaired:
1. Test flex cable betweenboards.2. Change right board.3. Change center board (on 36"models only).4. Change left board.
Jul 23, 2012 | Cooktops
I have an induction cooktop model EW36CC55GS and when I plug it, it shows an error E95, I look for a error code chart but there is none. Can someone know what is this error?
hi i could not find this model in the uk european models but i do no that e90 codes usually relate to configuration problems possibly between user interface and powerboard . solutions are usually expensive. just check that bridging connections at the terminal block are correctly in place.
Aug 13, 2010 | Electrolux 37 in. Designer Series...
Error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
Electrolux 37 in. Designer Series E36IC75FSS Electric Cooktop Logo
191 people viewed this question
Top Electrolux Cooktops Experts
Paul Carew
Lawrence Oravetz
gbob59
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
