Question about Fellowes Powershred 420 Shredder
Shredder will not operate. Both red and green light always come on and I cannot tell why
  • mark729 Jun 12, 2010
    I am looking for a local repair outfit. Thanks for the input.
  • 679 Answers
First open the drawer or bin and see if it's stuffed to the top, that is the usual cause. Then reset it if it has a reset button, Then if still no good with it unplugged, take a pliers and pull out any stuck paper or plastic stuck in the grinder. That is really all you can do with these things. Some times they just burn out from use. But with both lights on it sounds like its over full. also try to run it in reverse if you have that feature. If you are sure it's empty and there is nothing jammed up inside. Then it probablly just burned out. The directions on these things say don'y use for more than 15 minuted on the ones that cost under $300.00, we have burned out a few ourselves.
Posted on Jun 04, 2010
  • 2 more comments
  • mark729 Jun 05, 2010
    I have tried all this; nothing works.
    The shredder will operate in reverse, but not forward, is it possible they burn out in one direction only?
    This shredder originally cost approx. $700, so it is not an inexpensive shredder; I have also burned out cheap ones...
    There is no reset button of any kind
    Any other ideas?
  • George Bill
    George Bill Jun 07, 2010
    I just saw your comment, That is really an anomally, "it works one way only. Then I am going to look at a schematis of this machine, but try allowing it to run if possible, it may have a bad switch, or the polarity somehow got reversed. Is the a way for you to reverse the wires on the switch itself. I am thinking something may be stuck in there , like a paper clip. If we could crank it the other way for just a minute it would probablly clear. I am assuming this is off warantee before we start fooling around with it yes?
    I will do some research asap and get back to you, sorry it wasn't an easy one.
    Gymowner
  • George Bill
    George Bill Jun 08, 2010
    After re thinking this, the motor is working as it runs in reverse. So there has to be something stuck in the intake area of the machine. It can't be anything else, this just using logic. If it wasn't running at all I would say it could be something else, but these things are constructed to reverse the direction should something jam them up. Please take another look. Try a magnifying glass and some WD40, and then let me know, thanks.
    Gymowner
  • George Bill
    George Bill Jun 12, 2010
    I read the owners manual and technical manuals on this machine for a hour last night, and other than something being stuck in the shredding area, they don't offer any other solutions, it may just be that the motor went, but I's unlikelly, it sounds more like an auto reversin solonoid or switch. Now I can't physically see this, so if it's possible that it's under warantee, That may be the way to go. Or a local repair shop, since it is such an expensive piece.
RED Light is on (left of the green light)
Reverse shredder and clean out as much paper shred as possible. Use some lube oil. Hairclipper oil and canola vegetable oil are good choices.
Aug 26, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
Rexel RSS1627/RSX1227 Red light always on when
I have an Acco Rexel RSX 1227 shredder. Can you use any oil to oil the shredder or must it be a special oil
Aug 22, 2011 | Office Equipment & Supplies
I have an Ativa AT120DC. It won't operate
I have an Ativa AT120DC Shredder. When it is switched to auto there is dim green light and it doesn't start. If I feed paper in it makes no difference. For some time it always started up when you switched it to auto and didn't wait for paper to be fed through. If you remove the basket the Door Open light comes on. can you help?
Mar 18, 2010 | Office Equipment & Supplies
Red light on as well as green,what is the red light
The red LED can mean one of two things -- either the shredder head is not assembled correctly (did you take the shredder apart recently?) or there is a paper jam inside the machine. Sometimes the jammed paper is far down and hard to see.
Jan 30, 2010 | Fellowes PS60-2 Shredder
Green and middle red light go on but motor does not. does not shred
Check the sensors on top and bottom of cutters. Clean with cotton swabs and compressed air. If this does not help, bad sensors or main board.
May 14, 2009 | Fellowes DM8C Cross-Cut Shredder
Shredder Beeping
The motor would always turn the cutters.
You likely have a broken chain or a loose gear on a shaft. If you hear the motor running and the cutters are not spinning something in the drive is broken. Likely the chain.
hope this helps.
Mar 20, 2009 | Dahle High Security 20634EC Shredder
Red Light on, but no jam
Your problem is probally with the safety interlock switch on your machine. On the PS-65c It is located on the right hand side of the unit. There will be a tab of plastic on the inside lip of the basket that goes into a slot on shredder head. If plastic piece is bent or broken machine will not operate. If it does not appear broken make sure when you put shredder head on that it fits flush all the way around on the basket. If none of this helps contact Fellowes Customer Service at 1-800-945-4545 and we will be glad to assist you further.
Jan 28, 2008 | Fellowes Powershred PS-65C Medium-Duty...
Red light on with green light
This is more than likely a sensor issue. Fellowes Customer Service can advise you on a solution with a little more info than provided. 1-800-945-4545
Oct 16, 2007 | Fellowes PS70-2CD Shredder
Fellowes Powershred 420 Shredder Logo
111 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
