Question about Evenflo Symphony Convertible Car Seat Heathrow
Is it necessary to use the locking clip. - Evenflo Symphony Convertible Car Seat Heathrow
  • 87 Answers
The locking clip is according to an USA standart that states that the car seat must not be oppend with one press so all american seats have the chest clip. the rational is that child cans open it.
in European standart it stated that it must be opened with one click so all Europien seats are without the chest clip. the rational is that in rescue situation child can be take out fast.
its up to you to decide what your prioreties are.
any way it is not advised to use the seat different then the manufacture specifications.
Posted on Jun 14, 2010
The drivers side door lock does not respond to the remote key fob. The other door do respond. What is the cause? What is the solution?
Most likely a defective power door lock motor/actuator failure. The door will have to be disassembled and the lock motor tested for power and ground. Not uncommon for these lock motors to wear out in time.
Jul 08, 2015 | 2008 Hyundai Entourage
How to open bonnet on focus 08 without the key
THE LOCK ACTUATOR ROD HAS COME UN-CLIPPED.
REMOVE DOOR PANEL, FIND LINKAGE, REATTACH USING NEW CLIP IF NECESSARY
Nov 14, 2013 | Vehicle Parts & Accessories
Trunk lock replacement
William,
Most all vehicle Lock Cylinder assemblies are held in place by a Spring Steel Retaining Clip. It may also be necessary to carefully remove the Emergency Release Cable and the Solenoid that opens the trunk electrically. The retaining clip is usually a "U" shaped Clip with a flange on the Closed End. If you cannot find what holds the Lock Cylinder in place, I strongly suggest that you take it to a Certified Mechanic that is totally familiar with your brand of vehicle. It is most often better to pay a professional a reasonable fee to avoid causing damage to other components surrounding or attached to the part requiring replacement.
Fastest Robe
Dec 27, 2011 | 1993 Dodge Spirit
Remove hub assy. 84 bronco 4x4, manual lock outs
if you are talking about taking the manual lockout hubs off, then first take tire off then if the clips are still on the lugs use a screw driver and pry them up so you can spin them off the lugs, then the hub will come right off. when putting them back on the clips are not really necessary because the wheel will hold it on.. hope that helps..
Oct 26, 2011 | 1985 Ford Bronco
How to replace headlight assembly
  1. Open the vehicle's hood and secure it in an upright position.
  2. Unplug the harness connector that attaches to the rear of the headlight.
  3. Unfasten the locking ring which secures the bulb and socket assembly, then withdraw the assembly rearward.
  4. If necessary, gently pry the socket's retaining clip over the projection on the bulb (use care not to break the clip.) Pull the bulb from the socket. To install:
  5. Before installing a light bulb into the socket, ensure that all electrical contact surfaces are free of corrosion or dirt.
  6. Line up the replacement headlight bulb with the socket. Firmly push the bulb onto the socket until the spring clip latches over the bulb's projection. WARNING
    Do not touch the glass bulb with your fingers ! Oil from your fingers can severely shorten the life of the bulb. If necessary, wipe off any dirt or oil from the bulb with rubbing alcohol before completing installation.
  7. To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. (If this is a combination low and high beam bulb, be sure to check both intensities.) If the replacement light bulb does not illuminate, either it too is faulty or there is a problem in the bulb circuit or switch. Correct if necessary.
  8. Position the headlight bulb and secure it with the locking ring.
  9. Close the vehicle's hood.
Feb 09, 2011 | 1998 Nissan Maxima
How do I change the speaker in 2007 sierra
This procedure work for door lock, but necessary you need take off the trim panel, then could helpfull...
Fig. Exploded view of the front door trim panel - 2005-06 and 2007 Classic models (click image for zoom)
  1. Disconnect the battery ground cable.
  2. Disable the Supplemental Restraint System.
  3. Remove the door trim panel. Refer to the illustration for the mounting screw and lock tab locations. After detaching the hardware, carefully pull it away, then lift it off the door just far enough to detach the electrical connections from it.
  4. Carefully detach the water shield from the door; this will be reused upon installation.
  5. Disconnect the inside door lock rod from the handle retainer clip.
  6. Detach the door lock rod from the retainer clip.
  7. Remove the rubber plug to access the outside handle rod. Disengage it from the clip and disconnect the lock cylinder rod.
  8. Detach the electrical connector and remove the lock from the vehicle.
  9. Installation is the reverse of removal. When installing the lock, tighten the screws to 89 inch lbs. (10 Nm).
Dec 09, 2010 | 2008 GMC Sierra 1500
How to put a head light in
Release the locking ring, then withdraw the halogen bulb from the headlamp assembly
Removal & Installation
This procedure only applies to replaceable halogen headlight bulbs (such as nos. 9004 and 9005); it does not pertain to sealed beam units.
  1. Open the vehicle hood and secure it in an upright position.
  2. Unfasten the locking ring which secures the bulb and socket assembly, then withdraw the assembly rearward.
  3. If necessary, gently pry the socket's retaining clip over the projection on the bulb (use care not to break the clip.) Separate the bulb from its socket.
To install:
  1. Before installing a light bulb into the socket, ensure that all electrical contact surfaces are free of corrosion and dirt.
  2. Line up the replacement headlight bulb with the socket. Firmly push the bulb into the socket until the bulb is seated. If so equipped, make sure the spring clip latches over the bulb's projection.
WARNING Do not touch the glass bulb with your fingers. Oil from your fingers can severely shorten the life of the bulb. If necessary, wipe off any dirt or oil from the bulb with rubbing alcohol before completing installation.
  1. To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. (If this is a combination low and high beam bulb, be sure to check both intensities.) If the replacement light bulb does not illuminate, either it too is faulty or there is a problem in the bulb circuit or switch. Correct if necessary.
  2. Position the headlight bulb assembly and secure it with the locking ring.
  3. Close the vehicle hood.
Apr 23, 2010 | 1998 Ford Windstar
Anywhere to find a breakdown to change the door handle that broke off on a 94 pathfinder?
Very easy to do...I have a 1990 and they are interchangeable....88-94: Door Panel
  1. Fully lower the door glass.
  2. Remove the arm rest, door lock knob and inside door handle escutcheon.
  3. For vehicles with manual windows, remove the regulator handle which is retained by a spring clip.
  4. Gently pry the door panel away from the door.
Interior side and floor trim removal procedures-Pathfinder
Remove the lock button first before removing the door panel
Remove the plug to gain access to door panel retaining screws
Remove the trim cover
Remove the door handle trim
Remove the power window switch trim panel
After loosening the power window switch trim panel, disengage the electrical connection
Remove all the necessary trim panels before removing the door panel clips
View of the door panel retaining clip-clip must be installed in the hole straight
Make sure the watershield plastic is in place before installing the door panel
Dec 10, 2009 | Nissan Pathfinder Cars & Trucks
Power sliding door will not open at all manually with remote or with door locks tried to remove iod fuse and sliding door fuse but still dont open thanks
either something jammed in track/lock-- or actuator rod broke or disconnected from lock --need to remove interior door panel to get to lock release and latch check all rods and clips for damage or missing repair or replace as necessary u can manually unlock the door at latch if something was jammed or stuck in latch
Nov 26, 2009 | 2007 Dodge Caravan SXT Minivan New Cars
Evenflo Symphony Convertible Car Seat  Heathrow Logo
76 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
