Question about Metz 54 MZ-4 for Nikon TTL Flash
I've had 2 Metz 54MZ4 flash units with my Canon 1Ds and 10D cameras and none of them work in TTL mode. They give full output power in TTL. What is problem?
  • 3 Answers
If your Metz is for Nikon it will not work in TTL on Cannons. Metz makes different flashes for Nikon and Cannon. I have a Metz 54 that I use with my Nikon D200 and it works as well or better than the NIkon SB800 in TTL.
Posted on Jun 04, 2010
Can I connect a METZ 45 CL-1 to my CANON D600
Yes, this is the way the flash can be used with the contemporary digital cameras. The camera has to be set to Full Manual mode (in point of the exposition), Exposure Time to 1/100 sec (or the shortest exposure that still assures full opening of the shutter). Aperture on the camera must suit the working aperture on the flash, also ISO speeds must match. The computer in the flash measures the reflected from the subject light and quenches the flash, creating the correct exposure. Mecamat sensor, having narrower reception angle and a sight, helps in achieving the correct illumination even on a relatively small subject. Sync voltage of Metz 45CL1 does not make harm to any digital camera, so you can use even the cheapest hotshoe-to-PC adapter available at many camera shops or you can buy one online. No need to spend much on sophisticated adapters.
Mar 31, 2015 | Metz 45 CL-1 Flash
Is the nikon d60 compatiable with a metz 45 ct4
Will a Metz 45 CL 4 FLASH a SCA 346/2 AFR module work onTTL mode for a Nikon D 70 & D 40X DSLR cameras
Dec 02, 2010 | Nikon Speedlight SB-80DX TTL Flash
I've mislaid my manual for my Metz 54. I haven't used it for a while and can't remember how I set the thing to shoot in ttl with my Fuji S6 Pro. When I'm in ttl mode on the flash the camera doesn't fire....
Not sure what S6 pro is, but if the flash doesn't fire in TTL then the flash is not support the type of TTL in the camera. I had the same problem with Nikon flashes on Nikon bodies. Perhaps you need a newer SCA adapter? Please go on http://www.metz.de/en/photo-electronics/sca-adapter/archive.html to check which adapter you need
Jul 02, 2010 | Metz 54 MZ-4 for Nikon TTL Flash
I HAVE NIKON D1X CAMERA AND METZ 45CL4 FALSHGUN. WHICH ADEPTER I NEED TO WORK TTL. THANKS. GOLA.
Im not sure that you can get full TTL with this analogue flash. If you can then SC300 should be OK. (I have the Nikon D80 and TTL is not possible with metzcl4 but who needs it)!
Sep 21, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Sunpak PZ 4000AF for Canon EOS 35mm SLR body
Canon digital uses E-TTL metering for best flash results, the older Sunpak unit isn't compatible with this, so it is not fully compatible. It may work in manual mode - but won't be as good as a more modern compatible digital flash like the Canon or Metz (eg 58AF1 Canon) versions.
May 11, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Canon Macro Settings for 100mm lens and Sunpak 12R ring flash
Firstly, be sure to check flash voltage. Your 30D may accept max 6V so that your camera can be shot if the flash unit has higher voltage than 6V.
1. Use low ISO to keep low noise....around f/8 or more depends on your need and how much DOF you want.....Set the shutter speed around 1/125 to your max speed to stop any movement (your subject or camera itself shaking).
2. Above is set in Manual mode (iso100, f/8 1/125 or 1/250), then you just need to leave the flash to work in TTL mode.
3. It needs battery, the connection is for syncing to trigger and release a proper flash power (in TTL mode).
Hope this help!
Mar 26, 2009 | Sunpak DX-8R TTL Ring Light Flash
Metz 45CL-4 Service Manual wanted..
Hi !
Here is a link to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will be to some help.
Regards Lars
Jan 27, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Canon 1D MK-II plus Metz 60CT4 set
Massimo,
Yes, the 60CT-4 works with the Pocketwizards.
Yes, they will work by connecting the Metz's cable into the PC of your camera.
To get longer life out of the flash tube, don't use full manual all the time. Like shooting more than 300 in less than 15 mins/day.
Just dail those number down.
eltroman
atdlee@netzero.com
Nov 14, 2008 | Metz Mecablitz 60CT4 TTL Flash
D200 compatibility ?
Metz says yes: Metz
Certainly Nikon will say no. I would double check the fit of the shoe on the camera. The pins on the flash should be springy to the touch.
Feb 13, 2008 | Metz 44 AF-4N TTL Flash
External Flash for 3000Z
I have tried a couple of external flashes on the 3000Z. It is my understanding from reading various Internet posts (and I am sure someone will correct me if I am wrong) that, other than triggering the flash to go off, there is no communication between the external flash in the hot shoe of the 3000Z and the 3000Z itself. Settings need to be made manually in the manual mode to set the f-stop and the aperture to get good exposures. The Metz flashes are expensive. Most have opted to use less expensive flashes such as the Vivitar 283/383, or a Sunpak, or even a "Wal-mart" flash. I chose an inexpensive bounce flash with a secondary "fill-in" flash to get rid of the shadows sometimes seen with indoor bounce flash pics. I purchased the Phoenix 82ZBDA Multi-dedicated twin flash from Porter's Photo Catalogue for $37.95. This flash works fine, but is not that powerful (GN 79 ). If you need a more powerful flash, you might consider the Vivitar 383.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Metz 54 MZ-4 for Nikon TTL Flash Logo
253 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
